Old 23rd March 2010, 14:05   #221  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
JoshyD 64bit MT AviSynth
MuLTiTaSK is offline   Reply With Quote
Old 26th March 2010, 19:32   #222  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
you gonna include a all inclusive tools package .7zip for the next release?
how is coding coming along i see you've been busy keep it up buddy the buzz is spreading just like i told you
x64 bit support in the video community is getting better thanks Windows 7
Old 26th March 2010, 19:40   #223  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
Yeah, it is! Although, I'm still holding off until all of the programs that I use on a daily basis support 64-bit. Last time I tried to get it all to work was a total nightmare.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Adub is offline   Reply With Quote
Old 26th March 2010, 20:01   #224  |  Link
turbojet
Originally Posted by _hawk_ View Post
Yes, when I have time I'll add 64bit support.
If anyone has some links how to use 64bit x264 in scripts please let me know..
Technically all a gui has to do is check %PROCESSOR_ARCHITECTURE% (windows variable) for AMD64 and if it finds it check registry for HKLM\SOFTWARE\AviSynth if found use 64 bit dll\exe.
Aviysnth64 users need this beta of haali media splitter otherwise they won't be able to split VC-1 (latest release) or won't have a 64 bit splitter. There's no real easy way to check the version other than to calculate crc or check the file modified date for Feb 1, 2009.
They'll also need 64 bit decoders like ffdshow64. You can check for this by checking for AMD64 in %PROCESSOR_ARCHITECTURE% and registry for HKLM\SOFTWARE\GNU\ffdshow64.
Piping 32 to 64 bit with avs2yuv or vfw4x264 is always slower then 32 bit if using faster then --preset fast with slower settings it can be up to about 15% faster with placebo but default x264 settings is only about 5% faster. Whereas avsiynth64 is just as fast for the fastest x264 settings and with heavy filtering and slow x264 settings expect up to about a 40% speed increase, x264 default is about a 10% speed increase.
Old 27th March 2010, 06:18   #225  |  Link
coldhammer
two questions:
1) is there a way to disable autocrop?
2) i thought i remembered seeing a reference to 2 pass encoding and setting an output file size. has this been implemented yet?
coldhammer is offline   Reply With Quote
Old 27th March 2010, 20:41   #226  |  Link
blubberbirne
hm, pic in startpost shows 0.4.7. Available for download ist only 0.4.6.1 ?!?
blubberbirne is offline   Reply With Quote
Old 28th March 2010, 00:38   #227  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@blubberbirne
it's a test version stable should be available on google code soon stay tuned
Old 28th March 2010, 21:41   #228  |  Link
willisurf
28.03.2010 22:25 Uhr MESZ 1001 downloads of BluRip
http://code.google.com/p/blurip/downloads/list
Congratulations and a huge Thank You to _hawk_
willisurf is offline   Reply With Quote
Old 29th March 2010, 14:26   #229  |  Link
_hawk_
BluRip author
Originally Posted by coldhammer View Post
two questions:
1) not yet. Maybe I'll add this.
2) You can use a 2-pass profile but have to calc the bitrate yourself. I plan to add a bitrate calculator later.
BluRip : 1-Click BluRay/m2ts to h264 mkv converter
_hawk_ is offline   Reply With Quote
Old 29th March 2010, 16:14   #230  |  Link
coldhammer
being able to disable autocrop is definitely a needed feature. those of us with auto lens changing projectors need to be able to feed in the source with the appropriate cropping for the lens changers to work correctly.
Old 29th March 2010, 17:27   #231  |  Link
_hawk_
BluRip author
So you would like to enter crop/resize values manually? Or something else?
Old 30th March 2010, 01:09   #232  |  Link
coldhammer
i personally dont see the need to enter manual crop sizes. i see it as either you want it cropped or you dont. if you do then the autocrop feature works just fine. if you dont i would like to see an option to simply disable autocropping and leave the material as is.
Old 30th March 2010, 01:19   #233  |  Link
coldhammer
ironically on another note I am getting "error could not get frame rate" immediately after the eac3to process ends and the autocrop process starts.
Old 30th March 2010, 04:30   #234  |  Link
archaeo
Banned
archaeo's Avatar
Not getting too far - couldn't open the program after downloading:
the application failed to intialize properly (0xc000135) Click OK to terminate the application
Do you need NET framework installed? If so, would 2.0 suffice?
archaeo is offline   Reply With Quote
Old 30th March 2010, 04:43   #235  |  Link
Adub
Adub's Avatar
@archaeo
What version of windows are you running?
Site:Adubvideo
Old 30th March 2010, 08:59   #236  |  Link
_hawk_
BluRip author
You will need .NET 3.5 + VC++2008 runtime. Atm I don't use any 3.5 specific features so it would be easy to switch to 2.0.
Old 30th March 2010, 14:53   #237  |  Link
archaeo
Banned
archaeo's Avatar
@Adub: I'm running XP Sp2
@hawk: I was hoping to avoid the NET 3.5 install. So it sounds like the 2.0 (SP2) version might work?
Old 30th March 2010, 18:23   #238  |  Link
_hawk_
BluRip author
Not sure, I guess it needs the 3.5er dlls even if no 3.5 specific function is used. I can switch to 2.0 with next version until I use 3.5 features.
But I think that more and more programs will use 3.5 so you will have to install it sooner or later..
Old 30th March 2010, 22:12   #239  |  Link
coldhammer
any ideas on the cant find frame rate error i am getting?
Old 31st March 2010, 13:46   #240  |  Link
M3n747
How much "later" are we talking about? I'm asking because the bitrate calculator is the feature I'm looking forward to the most.
blu-ray, blurip, eac3to, ffms2, mkv, mkvtoolnix, x264
