16th February 2015, 20:39 | #22301 | Link | |
16th February 2015, 21:49 | #22302 | Link | |
And no. Thank YOU!
16th February 2015, 22:50 | #22303 | Link |
@emilio99
I tested BD-RB doing a 3D backup of an alternate angle. I had to go through about 30 discs looking for a disc that was 3D and alternate angles, but I finally found one. I had no problem doing the backup. Historically you'll find that most reports of "Reading buffer overflow. Possible container..." have ended up being the result of a corrupt source. But since I hadn't tried any movie-only backups of 3D sources from alternate angles, I thought I should test it before coming to that conclusion. I'd suggest that you might try re-ripping. |
16th February 2015, 23:20 | #22304 | Link |
BD Rebuilder v0.50.04
I have updated the first post of this thread with a link to the most recent update of BD-RB (v0.50.04). Changes for this release:
February 16th, 2015 - v0.50.04 - Added an option to keep play-all sequences to the IMPORT settings. Rarely a disc may contain a structure that can mask some of the wanted playlists/PGCs that appear to be redundant. This option tells BD-RB to list all playlists/PGCs even it one or more may appear to be a "Play All" sequence. You can then remove or keep after reviewing in the menu/title editor. - Corrected an issue in which imported DVD sources with audio delays could create sync issues when a discontinuity is detected. - Fixed an issue in which PGS subtitles that are a result of an import of an MKV were not working when attempting to remux into a DVD format. - Fixed an error that could result in report of "ReencodeAudio() 00009 1801" on multipart sources that have leading audio anomalies. - Corrected an error in which attempting to do 3D backups in batch mode could result in "Run-time error '55': File already open". - Fixed an error in which 3D sources might experience a "Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta" and "Can't open file" when rebuilding. - Updated the included version of MKVMERGE and MKVEXTRACT to a newer version (v7.5.0). - Other minor corrections and cosmetic fixes. |
16th February 2015, 23:58 | #22305 | Link |
I currently have a job about to finish. While it was reencoding audio to aac (MP4 output), it reached 115% of "Current progress". Not sure how you feel about that. I think that was the maximum. Because right when I attempted to capture the screen shot, it finished. JUST missed it lol. Probably just cosmetic, but I figured I better let you know, in case that could incur a problem.
Only one rooster, need be in the hen house... Last edited by omegaman7; 17th February 2015 at 00:00. |
17th February 2015, 05:10 | #22309 | Link | |
17th February 2015, 22:43 | #22310 | Link |
@ Lathe
Why is it "sad"?? Isn't it...what it is because of Camera is moved too quick...and it happens? It does look funny to the eye(s), though. @ JD This is for 50.01 to 04...as much as I've tested so far. Ghostbusters revisit... Using DGIndexNV 2048 or 2047 it fails. LAVF..it goes well. Code:
- [10:36:44] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - Track 4353 (eng): Keeping original audio - Track 6656 (eng): Keeping original audio - [10:39:07] Multiplexing M2TS - Error in attempt to multiplex: MUX_00276.meta - Can't open file: D:\OUTPUT\WORKFILES\VID_00276_2.AVS.264 [10:39:11] - Failed to build structure, aborted - [12:03:18] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - Track 4353 (eng): Keeping original audio - Track 6656 (eng): Keeping original audio - [12:05:41] Multiplexing M2TS [12:07:32]PHASE ONE complete [12:07:32]PHASE TWO - Rebuild Started - [12:07:32] Rebuilding BD file Structure [12:07:49] - Encode and Rebuild complete
17th February 2015, 23:11 | #22312 | Link | |
18th February 2015, 00:20 | #22313 | Link |
Yeah...it's from the Double Pack at Amazon. Pretty cool to revisit..or watch anew. I really liked Dan's personal interview..and what he shares with his siblings. Same subjects I've enjoyed all my life and continue to do. There are more extras, but I don't wait to "spoil" (slime?) anything.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 18th February 2015 at 00:24. |
18th February 2015, 01:52 | #22314 | Link | |
This is absolutely NOTHING wrong with making it more clearly available for people to notice it and (passively) to remind them. "Do it now JD... You are starting to feel sleepy... It's starting to sound good to you... Many lives will be saved... God will smile upon you... Do it now..." |
18th February 2015, 01:57 | #22315 | Link |
Well, what I mean is that to me it is 'sad' because either as you say it is camera error, which by now with any quality film should NOT happen. Or, if it is something inherent and unavoidable with any Blu-ray no matter what, then it is sad that with all this sharp new technology, no one has found a solution to that yet... It just seems like a rather primitive thing to have happen in modern Blu-rays.
18th February 2015, 04:47 | #22316 | Link | |
No....Camera user is aware, not the Camera. That's what JD typed.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 18th February 2015 at 04:51. |
18th February 2015, 05:03 | #22317 | Link | |
18th February 2015, 05:57 | #22318 | Link |
@ Lathe
That was commented about in my last reply, as well as my suggestion to JD's original question.
18th February 2015, 19:41 | #22319 | Link |
@all
I have a problem with Batman Begins BluRay. I backed up with BDRebuilder no error, but the movie does not start. I see WB logo and then when it goes for the movie, the Panasonic home cinema crash... I tested a movie only backup and it works. The movie has a PiP feature. To make it stranger it works normally on PC with PowerDVD. Anyone has a similar experience or idea abou the problem ? Thanks |
19th February 2015, 03:11 | #22320 | Link |
1. You didn't post a Log & config...
2. If the Warner Bros logo shows, then the movie has started...? Or, does the WB logo show before the Movie attached WB logo shows? 3. Several possibilities.. 4. I agree with JD, PowerDVD is a program that is more open to "bypassing" errors than a Standalone Player will usually. This has to do with experience.
