10th February 2020, 00:38 | #18341 | Link | |
Grumpy Old Man.
10th February 2020, 01:49 | #18342 | Link |
I don't see four "tabs", but I see four buttons... I understand what the two on the left do, (connect and auto-reconnect) but have no clue what the other two do. There's no tool-tip or documentation on what they do. I don't like to randomly click buttons that don't say what they do
edit: I'm assuming the yellow one is to put the server to sleep, and the red one is to shutdown the server, but I have neither button highlighted on any of the servers, yet they still go to sleep. Last edited by ImEverlasting; 10th February 2020 at 01:55. |
10th February 2020, 02:45 | #18343 | Link | |
Grumpy Old Man.
TBH, I don't really see too much point in the Yellow button, and the Red one, activates after the chunk it is working on, completes, so if you have ONLY 1 server for that chunk / IP, then that WILL shutdown that server.
10th February 2020, 05:46 | #18344 | Link | |
ByteShare
And, Hi by the way |
10th February 2020, 07:00 | #18345 | Link | |
Grumpy Old Man.
I was going to mention if he had some old jobs in the queue from before the update, but then when I read that his servers were going to sleep, I deleted that post.
10th February 2020, 15:12 | #18346 | Link |
My new PC is up and running and is much quicker to encode x265. The GPU decoding seems to give a decent improvement too - thanks for all the hard work that has gone into RipBot recently.
One question - I see there is an option to skip the demuxing process. Can someone explain what this does? Why would I want to skip demuxing? |
10th February 2020, 15:22 | #18347 | Link |
Skips demuxing of audio and subtitle streams.
10th February 2020, 16:14 | #18349 | Link | |
ByteShare
I use it because I mux in the subs manually (with a batch file) and process audio externally and mux it back in as well (with a batch file). |
11th February 2020, 16:52 | #18352 | Link | |
ByteShare
RipBot won't process the subtitles or audio of a file, so you only deal with the video. Speeds up adding jobs for sure but you'll have to deal with the subtitles and or audio with another program. To answer your question directly, You will not be able to remux an audio stream at all with that feature on. I use it because I mux in the subs manually (with a batch file) and process audio externally and mux it back in as well (with a batch file). |
12th February 2020, 00:31 | #18353 | Link | |
Grumpy Old Man.
12th February 2020, 09:55 | #18354 | Link |
ByteShare
I use MKVToolNix as well for the muxing, but I do it with a batch file and with the option "Run command script after finished job" It all happens for me. The only part not automated is processing the audio. You can 1:1 rip-mux the subs from the source.
12th February 2020, 10:06 | #18355 | Link |
Grumpy Old Man.
I'll stick with using the GUI, as I'm no good with batch files...
14th February 2020, 17:06 | #18356 | Link |
File name bug
When I select an output filename e.g. file.mkv in the 'save file as' dialog the created filename is file.mkv.mkv.
I noticed this bug after i had to rename and re-edit titels of some files manually. Please add a check if file extension already exist in dialogs result string before add it automatically. Thank you. |
16th February 2020, 09:47 | #18357 | Link |
Hi Atak, my distributed encoding has suddenly stopped working. It was working fine 2 days ago. I'm on 1.25.1. Encoding client starts and connects with all the servers but no processing starts. All Encoding Servers report the same errors: y4m (error) bad sequence header magic and x264 (error) could not open input file.
17th February 2020, 01:29 | #18358 | Link |
Well I re-installed the latest Ripbot264 in all the servers to make sure everyone on the same installation. Rebooted and DE is back up again. It was strange to see that Encoding Server was giving me an error even in the host computer.
21st February 2020, 05:39 | #18359 | Link |
I have some 4k videos that I previously encoded to 3840x1920 (2.00 AR with no borders). I am reencoding them to 1280x640 for more portability to take on trips on my tablet. I am able to do that one at a time by selecting "Custom Resize" and use x,xx:1 in the Avisynth tab, enter my preferred width and height directly, and it resizes and encodes them correctly witout adding borders which is exactly what I want. No issue there. But if I try to expedite things by using the Batch feature, it doesn't give me that option, the only custom option for resize seems to be "Custom Auto Height", which first of all guesses incorrectly at the height for some reason and sets it to 692 instead of 640, which stretches the video, and the resulting encode also adds black bars to pad it out to 1280x720. Neither of these are what I want. Am I missing something in the Batch encode settings, or can I customize the resize selection so I can directly enter 1280x640 and have it NOT add the black bars? Either way I can get the result I need but it would be way more efficient if I could enter the correct settings once in the Batch interface and not have to do this one by one 10 times...
Cheers, The REAL Joe |
21st February 2020, 13:46 | #18360 | Link | |
Atak, can you change the default to remove padding when selecting a size. I'm making small versions of 4K to 1080p and HD to 720p. It would be nice just to select HD-Full or HD-Ready and have it scale the width and height appropriately to fit within those dimensions while keeping the aspect correct. I think it's actually fairly rare that anyone would actually want the padding added. |
