16th October 2019, 00:12 | #1081 | Link |
Noob
here
i used all decoding methods, and in all of them "normalization" option was set. i prefer "pipe" but i think it doesnt normalize. or maybe audio was normalized by ffmpeg and not qaac? Last edited by Natty; 16th October 2019 at 15:26. |
17th October 2019, 21:21 | #1083 | Link |
Inspector Gadget
Do we have an approximate date for the next stable release? I've seen a lot of useful commits from 2.0.4.0 but I would like to avoid beta build as I modify each release adding scripts/plugins/encoders before use which would make weekly upgrades time consuming.
17th October 2019, 21:47 | #1084 | Link |
Why is it a must to have Avisynth+ installed when the programm tells me, it can run with Avisynth+ or Vapoursynth? Vapoursynth is installed, all pathes are correct in the settings, Python is installed, everything is freaking there.
But whenever I want to open a video source, it wants to force me to install Avisynth+. Why? I wasted an hour now to check all settings 10 times in all dialog windows I could find in Staxrip 2. All I could find in this thread was "you have to create a template" Nowhere in the template I can tell "Use Vapoursynth". This really should be pointed out much better how to even use Vapoursynth. I'm close to uninstall Python and Vapoursynth again because I don't need it when the program can't use it. Btw. same with "Included Two versions of exe file, One targets 4.7.2 framework and other targets the newer 4.8 framework." Yes. I started Staxrip.exe out of the 4.8 folder and got a ton of error messages, because he couldn't find the Apps folder, because it was not in the same folder like staxrip.exe, which I couldn't read anywhere. |
17th October 2019, 22:54 | #1085 | Link |
@Bahamuth
That would be a bug, I will examine it if you create a ticket on the tracker. In your startup template I assume that your filter setup is vapoursynth and not avisynth?
18th October 2019, 00:30 | #1086 | Link | |
About modifications, isn't everything covered by the settings, we didn't do any breaking changes or resets for a long time.
18th October 2019, 04:20 | #1087 | Link |
Inspector Gadget
When I change builds I have to move my custom scripts and plugins into the new install's directory and point the settings to them. I also have customized encoder profiles I need to reconfigure each time.
Also, unrelated but is there a way to use an image batch as an input? Like FILENAME[000-999].FILETYPE Ex. Animation000.jpg,Animation001.jpg...Animation999.jpg At the moment I am losslessly muxing the images into an mkv before importing into StaxRip with "ffmpeg -framerate FPS -i FILENAME%03d.jpg -codec copy output.mkv", is there a way to do this without running through external ffmpeg first? |
18th October 2019, 08:45 | #1088 | Link |
You could put your scripts inside staxrip's settings directory or somewhere else outside of the install/startup directory. It should be possible to keep profiles when updating to a new version.
Regarding image input, I don't remember if there is already a mechanism, there is probably a way, it might need a powershell script. Create a ticket if you like.
18th October 2019, 16:41 | #1090 | Link |
FFT3DFilter has a newer version than what is in the Staxrip package.
If possible please update. FFT3DFilter v2.6 https://github.com/pinterf/fft3dfilter/releases |
19th October 2019, 06:14 | #1093 | Link | |
x265 error message
While trying out my new System (Ryzen 3700X, RT5700) I'm fighting with this error using x265
Kind regards, Tom |
19th October 2019, 07:14 | #1095 | Link | |
a full log is required to help you with your problem. Gesendet von meinem HMA-L09 mit Tapatalk |
19th October 2019, 10:40 | #1096 | Link | ||
------- Error Video encoding using x265 3.2+5-gfbe9fef31 Patman ------- Video encoding using x265 3.2+5-gfbe9fef31 Patman failed with exit code: -1073741819 (0xC0000005) The exit code might be a system error code: Die Anweisung in 0xp verwies auf Arbeitsspeicher bei 0xp. Der Vorgang s konnte im Arbeitsspeicher nicht durchgeführt werden. I do hope it gives the needed informations. I'm thankful for every hint!! |
19th October 2019, 22:06 | #1097 | Link | ||
i've done an encode with nearly the same setting as yours. Quote:
19th October 2019, 22:33 | #1099 | Link |
@TomSmith
In error in the middle of an encoding could be a hardware issue, an issue with the source or with the source filter, that are the most likely causes, I've not seen this happening before. I googled for "fwrite() call failed when writing frame" and found that other staxrip had this error using VapourSynth before but I did not really understand what was the cause, can be found here: https://forum.videohelp.com/threads/...de-vpy-scripts
19th October 2019, 22:35 | #1100 | Link | |
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
