Old 9th September 2024, 03:39   #32001  |  Link
Hooman
There is other useful information in the log... for example, was it a full backup or a movie-only? But I guess you decided it wasn't needed and provided something I didn't ask for instead.
I sincerely apologize for the misunderstanding. When I saw ‘encode log,’ I assumed it referred to the process of x264/video encodings and their stats, rather than the project’s log.
Hooman is offline   Reply With Quote
Old 9th September 2024, 12:22   #32002  |  Link
No biggie.
Old 12th September 2024, 10:11   #32003  |  Link
Hooman
It’s not an issue with the encodes. Whenever the clip (the streams) contains a part at its start that is to be skipped according to its corresponding playlist file, BD-RB doesn't retain the (PlayItem's) IN_Time at its original value and changes it to 00:00:00:00. This could be due to the commands BD-RB sends to tsMuxer (Or the "Rebuilding BD file Structure"). The attached image shows the original structure as imported into Scenarist by a BD-Reauthor script. The black frame that reads ‘Cinerama Everywhere, RT 8:20…’ is a shot of the short part at the start of the clip that is not intended to be played back.
If I rebuild the same title (even with the FORCE_NOENCODE=1 flag?) and then import the rebuilt version into Scenarist for re-authoring, the aforementioned IN_Time is not the same as in the original MPLS. When that playlist/clip is called from the disc menu, those few frames at the start of the clip play back because the IN_Time has changed. Maybe something like BDTools can correct it in MPLS files.
PS
For this particular clip, the “IN_time” of the PlayItem and the “mark_time_stamp” of the first “PlayListMark” in the original playlist MPLS (converted by BDTools to readable JSON) is 27167041. However, in the BD-Rebuilt version, it has changed to 27000000.
    "MPLS": {
        "version_number": "0200",
        "reserved_header": [
            0
        "AppInfoPlayList": {
            "reserved01": 0,
            "PlayList_playback_type": 1,
            "UO_mask_table": {
                "menu_call_mask": 0,
                "title_search_mask": 0,
                "chapter_search_mask": 0,
                "time_search_mask": 0,
                "skip_to_next_point_mask": 0,
                "skip_back_to_previous_point_mask": 0,
                "play_FirstPlay_mask": 0,
                "stop_mask": 0,
                "pause_on_mask": 0,
                "pause_off_mask": 0,
                "still_off_mask": 0,
                "forward_play_mask": 0,
                "backward_play_mask": 0,
                "resume_mask": 0,
                "move_up_selected_button_mask": 0,
                "move_down_selected_button_mask": 0,
                "move_left_selected_button_mask": 0,
                "move_right_selected_button_mask": 0,
                "select_button_mask": 0,
                "activate_button_mask": 0,
                "select_button_and_activate_mask": 0,
                "primary_audio_stream_number_change_mask": 0,
                "reserved01": 0,
                "angle_number_change_mask": 0,
                "popup_on_mask": 0,
                "popup_off_mask": 0,
                "PG_textST_enable_disable_mask": 0,
                "PG_textST_stream_number_change_mask": 0,
                "secondary_video_enable_disable_mask": 0,
                "secondary_video_stream_number_change_mask": 0,
                "secondary_audio_enable_disable_mask": 0,
                "secondary_audio_stream_number_change_mask": 0,
                "reserved02": 0,
                "PiP_PG_textST_stream_number_change_mask": 0,
                "reserved03": 0
            "reserved02": 0,
            "PlayList_random_access_flag": 0,
            "audio_mix_app_flag": 1,
            "lossless_may_bypass_mixer_flag": 0,
            "MVC_Base_view_R_flag": 0
        "PlayList": {
            "reserved01": 0,
            "PlayItem": [
                    "Clip_Information_file_name": "00018",
                    "Clip_codec_identifier": "M2TS",
                    "ref_to_STC_id": 0,
                    "reserved01": 0,
                    "is_multi_angle": 0,
                    "connection_condition": 1,
                    "IN_time": 27167041,
                    "OUT_time": 49802154,
                    "UO_mask_table": {
                        "stop_mask": 0,
                        "pause_on_mask": 0,
                        "resume_mask": 0,
                        "reserved01": 0,
                        "popup_on_mask": 0,
                        "reserved02": 0,
                        "reserved03": 0
                    "PlayItem_random_access_flag": 0,
                    "reserved02": 0,
                    "still_mode": 0,
                    "still_time": 0,
                    "STN_table": {
                        "reserved01": 0,
                        "number_of_PiP_PG_textST_stream_entries_plus": 0,
                        "stream": [
                                "type": 1,
                                "pid": 4113,
                                "stream_coding_type": "H.264",
                                "video_format": "1080p",
                                "frame_rate": "23.976",
                                "reserved01": 0
                                "type": 1,
                                "pid": 4352,
                                "stream_coding_type": "AC-3",
                                "audio_presentation_type": "Stereo",
                                "sampling_frequency": "48 kHz",
                                "language_code": "fra"
                                "type": 2,
                                "subpath_id": 0,
                                "subclip_id": 0,
                                "pid": 5120,
                                "stream_coding_type": "IGS",
                                "language_code": "eng",
                                "reserved01": 0
            "SubPath": [
                    "reserved01": 0,
                    "SubPath_type": 3,
                    "reserved02": 0,
                    "is_repeat_SubPath": 0,
                    "reserved03": 0,
                    "SubPlayItem": [
                            "Clip_Information_file_name": "00016",
                            "ref_to_STC_id": 0,
                            "reserved01": 0,
                            "is_multi_Clip_entries": 0,
                            "sp_connection_condition": 1,
                            "SubPlayItem_IN_time": 27000000,
                            "SubPlayItem_OUT_time": 27001876,
                            "sync_PlayItem_id": 0,
                            "sync_start_PTS_of_PlayItem": 0
        "PlayListMark": [
                "reserved01": 0,
                "mark_type": 1,
                "ref_to_PlayItem_id": 0,
                "mark_time_stamp": 27167041,
                "entry_ES_PID": 65535,
                "duration": 0
                "reserved01": 0,
                "mark_type": 1,
                "mark_time_stamp": 49800277,
                "duration": 0
I believe this issue can only be resolved by a reverse conversion of the JSON file back into an MPLS playlist after BD-RB’s work.
BDEdit can also revert the PlayItem IN_time from the initial setting to the original authored value. However, I am curious as to why this behavior occurs in the first place. Is "Rebuilding BD file Structure" a process similar to what IfoUpdate did during the DVD era? Does it fail to read the original IN_time value, or is the issue caused by the muxing process when the main clip of the PlayItem is changed?
Old 20th September 2024, 20:14   #32004  |  Link
ROB271
Originally Posted by ROB271 View Post
Hello, i would like to report a bug thats been present in BD-RB for a couple of years now
When dolby vision support was first added to BD-RB there was an initial release where the dolby vision track was given the wrong stream ID, this bug was promplty fixed by the author BUT was never fixed in the internal routine that handles the correction of bitstream exception errors returned by tsmuxer, resulting in the m2ts file where bitstream exception occured being unplayable with dolby vision enabled.
If i then demux BD-RB output the dolby vision track on an affected m2ts file where bitstream exception occured demuxes as track_4114 rather than track_4117.
Im hoping this is just a code correction for the author.
Thankyou
I'll take a look at it.
Hello j dobbs, did you get chance to look at the above bug, Regards
ROB271 is offline   Reply With Quote
Old 21st September 2024, 21:53   #32005  |  Link
DoctorM
New Win OS and installation of BD Rebuilder first being used today and I received the "TSMUXER ERR: 0xFFFFFFFF" error trying to do a movie only rebuild.
I saw a few instances of it mentioned here but never a solution. Digging around I found that one of the .M2TS files was accidentally missing so the .MPLS couldn't find ALL the video files in the main movie's playlist.
Putting the missing video back and the error went away.
I don't know if that's why anyone else got that error, but I just thought I should mention it in case it helps others.
Old 22nd September 2024, 17:20   #32006  |  Link
I have it on my list of things to do. Unfortunately I haven't had a lot of time recently to work on BD Rebuilder, but I hope to address the things on my list soon.
Old 29th September 2024, 23:03   #32007  |  Link
Lathe
Lathe's Avatar
Just a quickie... (as is my known usual style... )
I THOUGHT I remembered in the past that using TSMuxer the box 'Continually Insert SPS/PPS' was always checked, unless I am misremembering. But, I'm using a newer version of TSMuxer now (still from aways back) and I notice that be default the box is UNchecked.
I'm ALWAYS creating playable Blu-ray compatible discs to play in my OPPO player, so, should I leave the box unchecked now or should I use it? I am rather confused... (what else is new....?)
And, in answering, if someone could kindly please explain exactly what that does and why that is there and why it is (UN)necessary?
Thanks!
***EDIT
Oh, I also notice that the older version I use sometimes (2020) also defaults to 'Insert SEI and VUI data if absent'... Uh, what is that about, and why does the newer one default to 'Do Not Change' that? AND... Again, PLEASE, what are the differences, why do both versions default differently, and how should I set these to make the most compatible playable Blu-ray discs for hardware players?
thanks again!
Old 2nd October 2024, 23:10   #32008  |  Link
Lathe
Lathe's Avatar
Anyone home...?
Old 3rd October 2024, 17:13   #32009  |  Link
gonca
https://doc-kurento.readthedocs.io/e...edge/h264.html
https://forum.videohelp.com/threads/...SMuxer-SEI-VUI
Nobody home.
Idea...
Try default and if you have no problems with playback, great.
If you have an issue just remux with options checked. and see if that worked.
I used to go with defaults and didn't have any issues.
Old 3rd October 2024, 19:25   #32010  |  Link
Lathe
Lathe's Avatar
Nobody home.
Idea...
Thanks Bro! I'll check out those threads and see if I can understand what the difference is. Sounds like you just tried trial and error, that would suggest that there is no true definitive answer if one was indeed better than the other.
The older version of TSMuxer defaults to having both 'on' so to speak. The newer version (2020) has them 'off' by default, so that doesn't help one know...
Old 3rd October 2024, 20:12   #32011  |  Link
gmipf
Does anyone know how to run with wine?
gmipf is offline   Reply With Quote
Old 3rd October 2024, 20:26   #32012  |  Link
Lathe
Lathe's Avatar
Old 3rd October 2024, 23:55   #32013  |  Link
gmipf
You know?
Old 3rd October 2024, 23:59   #32014  |  Link
Lathe
Lathe's Avatar
You know?
Heh, no, sorry... I just liked your post as it reads literally...
Old 5th October 2024, 10:15   #32015  |  Link
musiclover
I am making a quick-play blu-ray using mkv's with a framerate of 24. After the first try the audio was out of sync. This problem was solved after having written ''IMPORT_FORCE_FRAMERATE=24'' in the config file. But now the subtitles are out of sync. BD-Rebuilder converted them to 23,976 fps. Is there an easy fix for that?
Old 5th October 2024, 10:35   #32016  |  Link
musiclover
I have a computer with both NVIDIA and INTEL gpu's. Starting GPUENCC v0.01.17 and selecting ''INTEL Encoding GPU'' the constant quality settings read 27, 24, 18. After switching to ''NVIDIA Encoding GPU'' and switching back again the constant quality settings have changed to 34, 29, 23. I have to restart the program to get the original 27, 24, 18 again. The NVIDIA settings are kept constant after switching at 31, 28, 23.
I think it's a bug.
Old 5th October 2024, 15:52   #32017  |  Link
I think it's a bug.
Weird. I'll look at it.
By the way, you can set those values to whatever you like. Just edit GPUENCC.INI from within the program and add one or more of the following examples (using values you choose):
NV_HEVC_Q_VALUES=34,29,23
NV_AVC_Q_VALUES=31,28,23
QSV_HEVC_Q_VALUES=34,29,23
QSV_AVC_Q_VALUES=27,24,18
also
HEVC_BR_VALUES=1000,2000,3000
AVC_BR_VALUES=1500,2500,4500
Just a warning... any illegal or other strange settings will revert to the defaults.
Old 6th October 2024, 07:46   #32018  |  Link
iambryanknowles
Is there a way to force FFMPEG Frameserving for an HEVC source file when encoding to x264? (My GPU doesn't decode HEVC) DirectShowSource is extremely slow, and lavf through x264 doesn't allow crf prediction.
Also, on occasions I'm trying to encode by bitrate, is there a way to force the program to calculate the average bitrate based on the whole playlist. I've been using DVD2BDExpress to convert DVDs to BDs retaining menus, then IVTC and reencoding to DVD-5. Seems to give a different bitrate for every file encoded; even though they're episodes roughly equivalent in size, sometimes DVD2BD splits them up awkwardly. Same change in bitrate for quickplay playlists.
Last - could you either add a warning when FLAC audio tracks are ignored on import, or have them automatically convert to ac3?
iambryanknowles is offline   Reply With Quote
Old 6th October 2024, 13:19   #32019  |  Link
musiclover
Is there a hidden option to prevent BD-RB from converting the subs to 23,976 fps?
Old 6th October 2024, 16:04   #32020  |  Link
The bitrate used is relative to the original bitrate (and size) for that file.
