Old 13th May 2010, 07:07   #8181  |  Link
bessmertni
I noticed something strange when i ripped Lord of the Rings: Fellowship of the Ring. I have it set to rip to bd-25 and I'm using version 0.33.06. When I tried to rip the whole disc the tsmuxer would crash. But, ripping just the main movie works just fine. Something about stream 5 it doesn't like. Is it possible it hangs on the BD-Live portion?
Here is the log if it helps.
[23:32:34] BD Rebuilder v0.33.06 (beta)
- Source: LORD_OF_THE_RINGS_FELLOWSHIP
- Input BD size: 38.19 GB
- Approximate total content: [03:13:39.641]
- Target BD size: 22.66 GB
- Windows Version: 6.0 [6002]
- One Pass ABR Mode enabled
[23:32:37] PHASE ONE, Encoding
- [23:32:37] Extracting A/V streams [VID_00005]
- Error in attempt to extract audio/subs.
- SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net
[23:32:54] - Failed to retrieve audio, aborted
bessmertni is offline   Reply With Quote
Old 13th May 2010, 14:43   #8182  |  Link
Capsbackup
I had no problem with a full backup to BD25.
Your log indicates something is not set up right, with haali or ffdshow.
Old 13th May 2010, 16:06   #8183  |  Link
bessmertni
I feel sheepish, I forgot to turn on AnyDVD. Doesn't do much good to try an rip a blu-ray while its encrypted.
Old 13th May 2010, 16:25   #8184  |  Link
worknstiff
@bessmertni, Are you trying to run BD_Rebuilder on a BD disk that is in the tray? If so then you need to right click fox and copy video file to harddrive. BD_Rebuilder takes forever to copy from disk and takes up a lot of cpu cycles to copy and then encode. If you are just running BD_Rebuilder from a BD_Folder you don't need AnyDVD HD running anymore.
Old 13th May 2010, 23:51   #8185  |  Link
stinman
How can I keep the HD audio,all of it not just the core when using something other than BD25? Sometimes it would be nice to use the custom target size and take a 20gb movie only and compress it down to 10Gb but keep DTS-MA.Can this be done,if so how?I know BD5 or BD9 you can't do this with BDRebuilder,but what about custom target size,or the hidden options?
stinman
stinman is offline   Reply With Quote
Old 14th May 2010, 13:17   #8186  |  Link
Bystander
Feature Request - Option to use different drive/directory for work folders vs. final output drive/folder.
Status update - Any fix for Sin City BD?
Bystander is offline   Reply With Quote
Old 14th May 2010, 19:35   #8187  |  Link
wensteph
Good Luck Chuck on Other Movie Only is one tough movie to code
I'm past the point of caring about this particular movie; I'm asking this in general terms. I know BD-RB works to code an iPad size movie. I've coded several and successfully had them recognized by ITunes and they play back fine.
The audio for Good Luck Check is giving me fits. The audio choices are LPCM Multi-Ch, AC3 Multi-Ch and AC3 Stereo. The first two give me the soundtrack and effects without character dialogue. In AC3 stereo I get soundtrack, dialogue and the directors comments. Is it just this particular movie or is there something I'm missing?
Edit. I guess my real question is when doing a Other Movie Only, in general terms, is there a particular audio stream or combination of streams I should select? Or is it all trial and error?
wensteph is offline   Reply With Quote
Old 15th May 2010, 01:15   #8188  |  Link
Originally Posted by EDUDE View Post
Hello .. a doubt about "audio" ..
I mostly do 50 BLU to 25 BLU fullbackup..so if a BLURAY, has DTS ENGLISH and DTS ENGLISH SPANISH .
it is posible to leave the ENGLISH track of DTS and just reencode the SPANISH track to 5.1??
since by the choices you can leave both tracks (dts) untouched or reencode both in 5.1...
any help is welcome!
ps: sorry for my english!!
Not yet, but that'll be added eventually.
Old 15th May 2010, 03:04   #8189  |  Link
raul124
raul124's Avatar
backup not the movie only instead the making of the movie!!
Jdobbs, Here is a weird situation , I backup Day Breakers the Movie only to BD9 through the night, head it to work, came back home a tried to play the movie Day Breakers.The funny thing was the only thing on the disk was
the making of the Day Breakers for 2 hours. for a moment I thought I had backup the wrong disk, I try again full movie onto a BD-Re and sure enough> menus and movie and the making of the movie fully completed. why did BD-Rebuilder copied just the making of the movie and not movie it self on BD9..here is the log to the movie
[23:18:16] BD Rebuilder v0.33.06 (beta)
- Source: DAYBREAKERS
- Input BD size: 17.11 GB
- Approximate total content: [02:01:38.332]
- Target BD size: 7.72 GB
- MOVIE-ONLY mode enabled
- Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640
[23:18:16] PHASE ONE, Encoding
- [23:18:16] Extracting A/V streams [VID_00396]
- [23:22:41] Reencoding: VID_00396 (1 of 1)
- [23:22:41] Collecting video information
- Rate/Length: 23.976fps, 174,985 frames
- Bitrate: 8,203 Kbs
- [23:22:41] Reencoding: VID_00396, Pass 1 of 2
[07:45:34] BD Rebuilder v0.33.06 (beta)
- Resuming from previously started job.
[07:45:45] PHASE ONE, Encoding
- [07:45:45] Reencoding: VID_00396 (1 of 1)
- [07:45:45] Collecting video information
- [07:45:45] Reencoding: VID_00396, Pass 1 of 2
- [09:29:11] Reencoding: VID_00396, Pass 2 of 2
- [11:10:45] Video Encode complete
- [11:10:45] Reencoding audio tracks (if req'd)
- [11:11:25] Multiplexing M2TS
[11:15:57]PHASE ONE complete
[11:15:57]PHASE TWO - Rebuild Started
- [11:15:57] Rebuilding AVCHD file Structure
[11:20:45] - Encode and Rebuild complete
[11:20:45] BURNING BD structure to disc
- ImgBurn completed successfully
[12:20:56]JOB: DAYBREAKERS finished.
raul124 is offline   Reply With Quote
Old 15th May 2010, 03:15   #8190  |  Link
DGenerateKane
Former Kanenite
jdobbs, any idea why both disc 6 and 7 of Star Trek Season 2 has parts of spanish and french audio and no english when english was the only language selected to keep?
DGenerateKane is offline   Reply With Quote
Old 15th May 2010, 03:26   #8191  |  Link
Capsbackup
This extra just happens to be longer than the main movie, thus BD-RB chooses it first. Though, for the most part, BD-RB is fairly simple to use, it does require some user intervention on some discs like this.
If you select mode, then Alternate Movie-Only Playlist, you will then see the other options available for the movie. It is usually a good idea to check this on movie-only backups, since some movies have multiple playlists that may have different chapter counts, so you can try to be selective for the correct one.
Old 15th May 2010, 07:01   #8192  |  Link
pkho
I have been using BDRebuilder for some time but recently my desktop failed to load so I have to delete the user and create a new one. After that I can't use BDRebuilder anymore. I have tried to reinstall all the components but still no luck. Everything seems to check out OK. Any particular area I need to look for fix? I wish the info can point out the where the problem is.
[15:52:18] BD Rebuilder v0.33.06 (beta)
- Source: INKHEART
- Input BD size: 16.64 GB
- Approximate total content: [01:46:01.396]
- Target BD size: 4.27 GB
- RESIZE 1080p to 720p enabled
[15:52:19] PHASE ONE, Encoding
- [15:52:19] Reencoding: VID_00000 (1 of 1)
- [15:52:19] Collecting video information
- Rate/Length: 23.976fps, 152,521 frames
- Convert: 1280x720, 23.976fps, 152,521 frames
- Bitrate: 4,620 Kbs
- [15:52:19] Reencoding: VID_00000, Pass 1 of 2
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.33.06 (beta)
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: Ok
- FFDSHOW: 3326, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[15:52:35] - Failed video encode, aborted
pkho is offline   Reply With Quote
Old 15th May 2010, 20:25   #8193  |  Link
Ch3vr0n
Originally Posted by SoniG View Post
Ch3vr0n : Yep let us know. I want my 1 cent!
Looks like i can keep my 1 cent. The recoded disc with disabled secondairy stream also hanged at the point where the movie should start playing, but the pop-up menu was able to get pulled up. Weird
Anyway, i've seen the movie by now. Its just a weird issue
Old 16th May 2010, 11:40   #8194  |  Link
borivoje
Hello
I'm having trouble with a custom BD size in BD Rebuilder ... In the last try with a version 33.04 I got a file with the size of 21.9 GB (23,607,061,476 bytes) after I put 23800 in the custom field. I had trouble with one of the earlier versions, when I was getting the same size several times, no matter the input in the custom size field. Whatever custom size I chose, it seems that somehow the final file is far from the real capacity of 25gb BD-R. Or maybe I'm totally mislead with the amount of space on BD-R disc. I think it should be something like this: 25 GB / 23866 MiB / 25025314816 B. Forgive me if I'm talking rubish, but I'm far from expert on this. And maybe there was a discussion about some similar problems (if this is a problem at all), but 400+ pages is too much for me.
By the way, THANKS for this great program ... The quality of BD movie, even when it's shrinked more than it should be, is just amazing ...
CHEERS
borivoje is offline   Reply With Quote
Old 16th May 2010, 12:14   #8195  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
You're getting about 5% undersize, which is not bad at all. If you use high-quality or/and two-pass settings it is possible that x264 didn't need more bitrate to encode your movie. + you get about 1mm off the edge of the disc unused and it is one of the areas which can be easily scratched.
Old 16th May 2010, 13:46   #8196  |  Link
colinhunt
It is also the area where burn quality deteriorates rapidly. It's not a problem if you have a good BD writer (e.g. Pioneer BDR-205, LG BH08) and high quality media. I've had the misfortune of buying media made by OTC which under no circumstances should be written faster than 2x and no more than 21GB, unless one wishes to have playback problems.
Old 16th May 2010, 18:47   #8197  |  Link
borivoje
Thanks for the answers ...
Well, in that case it's better to use predefined BD-R 25 size, which puts the file to 22.6GB as I remember ... By the way, I'm using Pioneer BD203 with the latest firmware and I use only Verbatim and Panasonic DL media. I never had any problems, even with a full capacity burns.
CHEERS
Old 16th May 2010, 19:02   #8198  |  Link
BD Rebuilder v0.33.07 (beta)
I've just updated the first post of this thread with a link to the newest beta release of BD-RB (v0.33.07). Changes for this release:
- Modified the AVS format so that  AssumeFramerate() is
  always used. This is meant to prevent mistaken or
  miscalculated rates during the reencoding process and
  also avoids possible rounding errors.
- Changed settings on the iPad ALTERNATE settings to take
  advantage of CABAC and B-FRAMES.
- Corrected an "ExtractAudioSubs() 00053  1605" error that
  could occur in movie-only mode for features that consist
  of a large number of combined M2TS files.
- Corrected an issue in which frames could be lost and a
  "stutter" could be seen between segments of a seamlessly
  branched film when doing a full backup.
- Added a hidden option "SHUTDOWN_SLEEP=1" which will make
  the "Shutdown after Rebuild" option on the FILE menu to
  "Sleep after Rebuild" instead.
- Updated the included version of X264.EXE to the
  latest release (r1583).
Sorry for the delay between releases. I managed to fit a short holiday in there...
Old 16th May 2010, 20:27   #8199  |  Link
ggab_
You're awesome. Thanks for the software.
ggab_ is offline   Reply With Quote
Old 16th May 2010, 20:28   #8200  |  Link
tekmobile
Webmaster
Error in movie only output (first ever attempt at one normally do Full BD25s)
Fully run to the error on the previous version but noticed you just uploaded a newer version downloaded that and tried to continue with the same error.
Don't really want to do the full encode with the latest version just posted unless something has changed that will correct this.
[20:18:29]PHASE ONE complete
[20:18:29]PHASE TWO - Rebuild Started
 - [20:18:29] Rebuilding stream 00390 [1 of 22]
 - [20:18:29] Rebuilding stream 00391 [2 of 22]
 - [20:18:29] Rebuilding stream 00392 [3 of 22]
 - [20:18:29] Rebuilding stream 00393 [4 of 22]
 - [20:18:29] Rebuilding stream 00394 [5 of 22]
 - [20:18:29] Rebuilding stream 00395 [6 of 22]
 - [20:18:29] Rebuilding stream 00396 [7 of 22]
 - [20:18:29] Rebuilding stream 00397 [8 of 22]
 - [20:18:29] Rebuilding stream 00398 [9 of 22]
 - [20:18:29] Rebuilding stream 00399 [10 of 22]
 - [20:18:29] Rebuilding stream 00400 [11 of 22]
 - [20:18:29] Rebuilding stream 00401 [12 of 22]
 - [20:18:29] Rebuilding stream 00402 [13 of 22]
 - [20:18:29] Rebuilding stream 00403 [14 of 22]
 - [20:18:29] Rebuilding stream 00404 [15 of 22]
 - [20:18:29] Rebuilding stream 00405 [16 of 22]
 - [20:18:29] Rebuilding stream 00406 [17 of 22]
 - [20:18:29] Rebuilding stream 00407 [18 of 22]
 - [20:18:29] Rebuilding stream 00408 [19 of 22]
 - [20:18:29] Rebuilding stream 00409 [20 of 22]
 - [20:18:29] Rebuilding stream 00410 [21 of 22]
 - [20:18:29] Rebuilding stream 00411 [22 of 22]
 - [20:18:29] Building ALTERNATE OUTPUT Structure
 - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta
 - Can't create output file C:\BD_REBUILDER\WORK\WORKFILES\VID_00390+VID_00391+VID_00392+VID_00393+VID_00394+VID_00395+VID_00396+VID_00397+VID_00398+VID_00399+VID_00400+VID_00401+VID_00402+VID_00403+VID_00404+VID_00405+VID_00406+VID_00407+VID_00408+VID_00409+VID_00410+VID_00411.track_4113.264
[20:18:30] - Failed to REBUILD
TsMuxer Meta contents below
MUXOPT --no-pcr-on-video-pid --new-audio-pes --demux --vbr --vbv-len=500
V_MPEG4/ISO/AVC, "C:\BD_REBUILDER\WORK\WORKFILES\VID_00390.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00391.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00392.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00393.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00394.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00395.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00396.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00397.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00398.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00399.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00400.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00401.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00402.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00403.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00404.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00405.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00406.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00407.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00408.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00409.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00410.AVS.264"+"C:\BD_REBUILDER\WORK\WORKFILES\VID_00411.AVS.264", fps=23.976, insertSEI, contSPS, track=4113
I believe the problem to be the output filename being too long
tekmobile is offline   Reply With Quote
