5th November 2010, 12:41 | #10022 | Link |
While I was backing up my Planet Earth Blu-Ray I encountered a problem.
I selected each of the episodes as separately and put them into the batch. I then ran the batch and instead of 3 folders each with a separate episode, I had 1 folder with the last episode in it. I looked at the batch and each playlist was named the same name. My assumption is that BD-Rebuilder overwrote each folder because they were named the same thing in the batch. I found a work around by editing the batchbd.ini externally and renaming each play list separately. The fix would be to either 1) Allow the renaming of each batch entry in the batch tab 2) Have BD-Rebuilder automatically rename a folder with numbers to denote a different one. |
5th November 2010, 14:14 | #10023 | Link | |
5th November 2010, 17:53 | #10024 | Link |
I had a similar thought with Dvd rebuilder. I ran Batch once upon a time, with the output to the same directory. Needless to say, batch mode ran 4 jobs, and I ended up with only the final one completed. I learned my lesson that night LOL! ALWAYS change the ouput directory LOL! Or create an image file
5th November 2010, 20:01 | #10025 | Link |
BD Rebuilder v0.36.01 (beta)
I have updated the first post of this thread with a link to a new version of BD-RB (v0.36.01). Changes for this release:
- Added the ability to create DVD backups of your blu-ray disc. The backup can be selected under the "Alternate Movie-Only Output" when movie- only mode is in effect. A ready-to-burn structure is created in the working folder. Subtitles are not supported, expect them in a future release. - Added a new selection to the SETUP dialog called "Assume PAL for DVD Output". This auto-converts non-PAL sources to 25fps, 720x576 (for DVD output only). - Increased the BD-25 target size value slightly to use more of available space. - Corrected an issue in which stopping BD-RB during audio encoding would leave the WAVI and AFTEN processes running. As a result, restarting soon afterward could cause unpredictable anomalies in the audio, including sync and size issues. - Changed an option in X264 command line that may have caused "crash" on certain types of sources. - Added check to ensure original video is not kept intact when filter use is enabled. - Removed inverse telecining from the streams menu. Too many people don't understand IVTC and are using it incorrectly. If you wish to IVTC, just select it in SETUP. If you want it back -- add the hidden value "IVTC_SELECTION=1" to the BD-RB configuration (INI) file. - Added 720x480 and 720x576 as output options to Alternate output choices. Note that you cannot use this size for iPOD output as it is larger than the 640x480 maximum for that device. - Corrected an error in which the frame rate was set incorrectly for MP4 output when using ALTERNATE output and IVTC was active. - Fixed incorrect pass reporting during alternate output to MKV. - Updated the included version of X264.EXE to the latest release (r1745). - Updated the included version of X264-54.EXE to the latest release (r1745). - Other minor corrections and cosmetic fixes. |
5th November 2010, 20:46 | #10027 | Link |
Disney Blu-Ray artifacts
When I backup my kids Disney Blu-Ray discs there are what I call "artifacts", what looks like the picture being a bunch of squares with the playback.
When I look at the original stream folder I notice that the Disney Blu-rays have a lot more files than most of my other Blu-Rays. My guess is that the artifacts are occurring where the files are meshing together. |
5th November 2010, 20:53 | #10028 | Link | |
5th November 2010, 21:04 | #10029 | Link | |
Here are my options: $$$$$Beauty_and_the_Beast-1, Movie-Only, CUSTOM, Extreme Quality [Options] FORCE_NOENCODE=1 MODE=1 ENCODE_QUALITY=4 ONEPASS_ENCODING=0 AUTO_QUALITY=0 TARGET_SIZE=23450 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP= SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=80000 PRIORITY_CLASS=2 MOVIEONLY_TYPE=0 ALTCRF=0 ALTMETHOD=0 QUICK_EXTRAS=0 [Paths] SOURCE_PATH=G:\RAW_BRAY\BEAUTYANDTHEBEAST\ WORKING_PATH=E:\BLU-RAY\ [Batch] MAIN_MPLS=00803.MPLS FORCED_SUB=0 FORCED_AUD=0 AUDIO=1001100110011001100110011001 SUBS=000000000000000000000000000000000000000000000000000000000000000000000000000000000000 |
5th November 2010, 22:19 | #10032 | Link |
Just updated to 36.01, and ran 'inspect' just to check all was well. It's not. I'm getting: "FFDSHOW_RAW_AUDIO: Not recommended setting" I've read and re-read the first post and cannot find anything saying what the recommended setting is. I've just looked in Start-All Progs-ffdshow-audio decoder config. It's a rather bewildering array of options! The most likely candidate I can see is the very last one 'uncompressed', which is currently set to 'disabled'. Hoping that I could just 'enable' it, I clicked the drop-down and was presented with a long list of possible data types. So which parameter do I actually need to change, and what value do I need to change it to? <edit>: Yes, I found a post that says it should be set to 'all supported', and inspect seems happy. Would it be possible to update the first post to include a more comprehensive list of 'recommended settings'? Thanks, SC Last edited by Stormcrow; 5th November 2010 at 22:27. Reason: Answering my own query. |
5th November 2010, 22:35 | #10034 | Link | |
I'll update the first post. |
5th November 2010, 22:38 | #10035 | Link |
I am but a novice in this you are the expert and the coder. All I can report is what I have observed in my use of the product, which I am a big fan of.
Every one of my Disney Blu-rays have the same problem. I will do a little more investigation to try and isolate the problem. |
5th November 2010, 22:43 | #10036 | Link | |
6th November 2010, 14:43 | #10039 | Link | |
[Edit] I'm trying it again with some different settings... Last edited by jdobbs; 6th November 2010 at 17:12. |
6th November 2010, 18:02 | #10040 | Link |
DVD Output Option
Thanks for the DVD output option. I just did a BD25 to DVD5 re-encode of Toy Story 3. There are a few of things I noticed.
1. The target BD size says 22.90 GB. 2. The final output was only 4.06 GB (4,367,894,528 bytes) in size. 3. Would it be possible to have the HCencoder window visible while the re-encode is happening? Code:
[08:04:37] BD Rebuilder v0.36.01 (beta) - Source: TOY_STORY_3 - Input BD size: 21.54 GB - Approximate total content: [01:42:33.344] - Target BD size: 22.90 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-5, 720x480/576, AC3 Audio - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [08:04:37] PHASE ONE, Encoding - [08:04:37] Extracting A/V streams [VID_00000] - [08:08:55] Reencoding: VID_00000 (1 of 1) - [08:08:55] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 147,533 frames - Bitrate: 5,123 Kbs - [08:08:55] Reencoding: VID_00000 - [10:38:15] Video Encode complete - [10:38:15] Reencoding audio tracks (if req'd) - [10:39:29] Multiplexing M2TS [10:39:29]PHASE ONE complete [10:39:29]PHASE TWO - Rebuild Started - [10:39:29] Rebuilding stream 00000 [1 of 1] - [10:39:29] Building ALTERNATE OUTPUT Structure - [10:41:40] Starting MPLEX. - [10:44:07] Building DVD File Structure. [10:46:22] - Encode and Rebuild complete [10:46:22]JOB: TOY_STORY_3 finished.
There are 11 kinds of people in the world, those who know binary, those who don't, & those who think they do. Proud member of America’s most distrusted minority!! |
