Old 7th February 2011, 21:55   #11181  |  Link
BD Rebuilder v0.37.04 (beta)
I have updated the first post of this thread with the newest release of BD Rebuilder (v0.37.04). Changes for this release:
- Added a new option in the ALTERNATE output
  selections.  You can now choose a target size
  in addition to CRF or bitrate.
- Made some minor improvements in the way IVTC
  is handled that can improve picture quality.
- Added a hidden option "DEINTERLACER_TYPE" that
  will allow you to set the type of deinterlace
  algorithm to use (when selected from SETUP).
  The settings are:  1=Decomb w/o blend,
  2=Decomb w/blend, 3=SmoothDeinterlace, and
  4=Progressive.  The last option (4) should be
  used when the source is progressive -- but it
  needs "fake-interlaced" to be asserted during
  encode.
- Added a new hidden option "EXTENDED_GOP".
  Setting this value to "1" will instruct BD-RB
  to use a 48 frame GOP size when writing to
  BD-5 OR BD-9.
- Inserted temporary code to prevent streams that
  contain IGS from being processed.  Since these
  are normally menus and by nature are small,
  they will be kept intact.  This should prevent
  the rare "Menu without buttons" issue until
  IGS reintegration routines are completed.
- Changed setting for "Use X264 Internal LAVF" to
  "on" as the default.
- Corrected an error in which using BATCH mode
  can sometimes incorrectly set the audio and
  subtitle selections.
- Corrected a bug in which under very rare and
  specific circumstances LAVF could be selected
  even though IVTC is in effect.
- Corrected an error in the ALTERNATE OUTPUT
  dialog that could cause checkboxes to be set
  at the same time.
- Corrected a problem in which some VC-1 sources
  might be incorrectly IVTC'd.
- Updated the included version of X264.EXE to the
  latest release (r1990).
- Updated the included version of X264-64.EXE to
  the latest release (r1884).
jdobbs.softworks@gmail.com
Old 7th February 2011, 22:41   #11182  |  Link
HWK
HWK's Avatar
Jdobbs, On first page it says January 7 instead of feburary release.
Old 7th February 2011, 23:21   #11183  |  Link
setarip_old
setarip_old's Avatar
What is the effect?
@jdobbs
Re: v.37.04
BD-5 OR BD-9.
What is the effect/benefit of this option?
Old 7th February 2011, 23:48   #11184  |  Link
Whoops. I'll fix it.
Old 7th February 2011, 23:50   #11185  |  Link
@jdobbs
Re: v.37.04
It was a request. If going to BD-5/9 you will probably squeeze out a little more quality at the same bitrate because you're using more P & B frames and fewer I frames.
I'm using it for all my BD-5/9 backups now. It's one of those things that's only allowed on Blu-ray if the maximum bitrate is below 15Mbs (as in BD-5/9).
Old 7th February 2011, 23:54   #11186  |  Link
laserfan
Aging Video Hobbyist
Look at the three posts starting here.
Old 8th February 2011, 01:50   #11187  |  Link
I'd say the only thing I'd disagree on is whether a longer GOP will help pulsing to any appreciable degree. I think it would probably slow it down (from 1 second to 2), but ipratio and pbratio are a better fix for pulsing. In fact the reason BD-RB uses 1.1 on each rather that the defaults of 1.4 and 1.3 (ipratio/pbratio) is in response to early reports of pulsing at low bitrates. As shon3i suggested in our previous discussion on pulsing, selecting open GOPs will probably help as well.
Old 8th February 2011, 01:53   #11188  |  Link
j_m_min
setarip_old
"Quote:
- Pes packet len too large ( >100Mb). Bad stream"
If you had done a search of this thread, you'd have seen that "jdobbs" (The author of BD Rebuilder) has stated that this is an error generated from within tsMuxeR - and could only be due to a bad rip.
Is your source material an original, commercial Blu-ray disc, or is it something else?"
_____________________________________________________
Wow, thanks for trying to help. I get so ignored on sites (like afterdawn) looking for help usually that I am surprised I got a couple responses.
Both the eat pray love, avatar and dinner for schmucks were original blu-rays that I got from Netflix. I doubt it matters, but that is where they are from. I tried eat like 8 times, avatar like 5 times and dinner 3 times.
I paid close attention, I get through 100% encoding, but as soon as it gets to re-encoding it fails. Why is this?
I did research that error message and many many threads and I found one post where a guy said his menu file or something was too big (greater thatn 100 mb) and when he unchecked that for recording it worked. I am guessing it could be that picture moving around in the menu. It seems it only records one big file or something, and if there is another greater than 100 mb it gets an erro. But I can't find anywhere where you can pick and choose what files to copy like on CloneDVD. If I could stop trying to record that file that is greater than 100 mb, it might work.
What is "tsMuxeR?" I don't have this program downloaded and its not in the instructions.
Maybe my bad for not posting the whole giant log, I just know it said everything was OK up until re-encoding.
Thanks a lot again. Sorry for the delay.
j_m_min is offline   Reply With Quote
Old 8th February 2011, 02:01   #11189  |  Link
Originally Posted by j_m_min View Post
setarip_old
"Quote:
I've done all the movies you mentioned -- and didn't get that error. So it's related to some setting you've made or something unique to your setup.
As was mentioned -- that error is almost always the result of a bad rip. Are you using AnyDVD? That's the only truly reliable decryption/ripping package out there (in my humble opinion).
TSMUXER is a 3rd party multiplexer used to demultiplex the streams from the original M2TS files and to create the new M2TS files after reencoding. It is included in the BD Rebuilder zip files and is in the TOOLS folder.
Old 8th February 2011, 02:50   #11190  |  Link
JJB
Quote: Both the eat pray love, avatar and dinner for schmucks were original blu-rays that I got from Netflix. I doubt it matters, but that is where they are from. I tried eat like 8 times, avatar like 5 times and dinner 3 times.
Quote: I get so ignored on sites (like afterdawn)
Jeeze, I wonder why?
Is the basement wet or dry?
JJB is offline   Reply With Quote
Old 8th February 2011, 04:26   #11191  |  Link
setarip_old
@jdobbs
Thank you for the explanation regarding "EXTENDED_GOP" ;>}
Old 8th February 2011, 18:03   #11192  |  Link
Capsbackup
@jdobbs;
Regarding:
I have tested my source Blu-ray that has IGS menus with this latest version, BD Rebuilder v0.37.04 (beta), and though it does skip reencoding the IGS menu files and does copy them as is, if the selected output is BD5/9, the finished backup has audio skipping issues while on the menu pages on my S360. The movie plays back fine though! I presume this is because of to high a bitrate for DVD media.
However, when I burn that same backup to BD-RE media, it plays back perfectly.
Old 8th February 2011, 19:27   #11193  |  Link
Originally Posted by Capsbackup View Post
@jdobbs;
Regarding:
Ugghh... I'll have to address that. I wasn't thinking of BD-25 backups when I implemented it.
Old 8th February 2011, 23:01   #11194  |  Link
Ch3vr0n
@jdobss: ya probably misread there. Caps is stating that using the new method BD25 works fine, its the BD5/9 that has the audio offsync
Old 9th February 2011, 00:38   #11195  |  Link
Yeah... but the skipping etc. is caused by the fact that the bitrate is too high for BD-5/9. In previous versions they were forced to be reencoded for that reason. I failed to consider that there could be an issue with BD-5/9 when you keep a stream intact.
Old 9th February 2011, 00:59   #11196  |  Link
LowDead
Elit Amans
BD-5 OR BD-9.
Does this mean I can safely leave it on and not think much about it later?
//LD
Old 9th February 2011, 01:02   #11197  |  Link
Capsbackup
Not a problem, but maybe just change your update/changes log info to reflect "only for BD-25 backups" at this time!
Old 9th February 2011, 01:08   #11198  |  Link
//LD
Yes. It will only be used for BD-5/9. It may become the default in the future.
Old 9th February 2011, 02:19   #11199  |  Link
setarip_old
Overlooked?
@jdobbs
Based on the fact that you've reponded to all subsequent reports, I'm guessing that my post #11180 "fell down a crack" and eluded what has to be your very tired eyes ;>}
Old 9th February 2011, 03:10   #11200  |  Link
dfsooner
Please don't do this.
I am testing for a custom size larger than DVD-9 (11000 to be exact). If it works for that, I'll be a happy camper. Besides my menus are not motion, so I don't anticipate any problems of that nature. I'll know in a few hours and will post the results.
Just for the record, I don't use DVD-9 size much any more because I no longer trust double layer DVD media. I have opted for 110000 for most of my rebuilds because it still gives me pretty good PQ and allows enough room to retain the HD audio (which BD-RB apparently allows for anything larger than [BD-9] - thanks for that, by the way - I wish it were optional for any size).
dfsooner is offline   Reply With Quote
