#221 | Link | |
Suptitle, MediaPlayer.NET
As a workaround, just have ffdshow output to YV12 for now. |
#222 | Link | |
#224 | Link |
Software Developer
Zachs,
Any plan to release just the renderer as a separate filter? Why limit the renderer to only support a locked-in GUI and player feature set? If you release the renderer as a stand-alone filter, I'll be happy to add support for it in Zoom Player. |
#225 | Link |
I explained before that it's not possible as it's not written as a DirectShow renderer. .NET is not friendly when it comes to writing DirectShow renderers unfortunately. Believe me when I said I have tried. It will take some c++ shims and a lot of effort to turn it into a DirectShow renderer.
#228 | Link |
Troubleshooter
Anything special people should know about configuring it for use with MPDN?
I had never used SVP before, and just downloaded and installed it getting the results shown in the picture below. Here is what I did: Downloaded SVP_3.1.6 from the SVP website, installed SVP unchecking everything except SVP 3.1.6 and Options (since there is no need for the SVPTube player, or anything MPC, LAV, or MadVR related (since LAV is already installed, and none of the other things would be used with MPDN and SVP)), left Install AviSynth and Install FFDShow checked and left the other Extras unchecked. Launched MPDN, Options, DirectShow, Video and added ffdshow raw video filter to selected filters. What (if anything) is wrong or missing compared to your (patul) setup? ![]()
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. |
#229 | Link |
Make sure you use YV12 as "Primary output color space" in ffdshow under "Output" tab, and you could try to turn off the "Set interlaced flag in output media type" check box. In fact, to make it simple, I use YV12 in the whole DS graph.
#231 | Link | |
Troubleshooter
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. Last edited by Anime Viewer; 23rd October 2014 at 03:55. |
#233 | Link | |
Troubleshooter
I also tried setting other things in the ffdshow video decoder configuration program to only use YV12 (like AviSynth), but that made no difference. Prior to that test I was running with all the boxes in the left column of the configuration program unchecked. I experimented with checking and changing settings in Postprocessing and codec. I also tried unchecking all output formats except for Yv12 in LAV video decoder. None of those experiments worked either. I noticed if I hover over the ffdshow video decoder raw square on the startbar while video is playing it reads: Input: YV12 (uncompressed) Output: NV12
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. Last edited by Anime Viewer; 23rd October 2014 at 06:14. Reason: added reading from ffdshow video decoder raw when hovered over |
#234 | Link |
Guys, I'm about to release the next version in the next half an hour and it should fix that problem. Might wanna save your time testing the newer version instead.
EDIT: Version 2.8.0 is now released. I've tested ffdshow with 2.8.0. Working fine now. Last edited by Zachs; 23rd October 2014 at 07:18. |
#235 | Link | |
Troubleshooter
Screen shot taken from MPDN 2.8.1: http://postimg.org/image/71jxvhiqt/ Edit: I found the issue causing the SVP blurring (aka double contours and interpolated frames issue). Unfortunately the solution talked about on the linked page doesn't entirely get rid of the problem since SVP removed some of the options from their profile options. (Decrease grid step and search radius are no longer selectable options). http://www.svp-team.com/wiki/Watching_anime
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. Last edited by Anime Viewer; 23rd October 2014 at 10:17. Reason: added SVP partial workaround for anime and subtitles |
#238 | Link | |
direct3d, mpdn, nnedi3, opencl, reclock |
