15th December 2008, 06:24 | #1441 | Link | |
-------------------------------------------------------------------- x264.1055M.exe - Alternate Download Patches used: x264_hrd_pulldown.09_interlace.diff x264_win_zone_parse_fix_04.diff x264_mingw_aligned_03.diff gcc 3.4.5 fprofiled build with -march=pentium2. |
16th December 2008, 00:04 | #1442 | Link | |
Compiling Encoder
due to the way the mingw libraries are setup as ar packages. |
16th December 2008, 04:04 | #1443 | Link |
x264-r1056.rar
Patched with, x264_hrd_pulldown.09_interlace.diff x264_mingw_aligned_03.diff x264_win_zone_parse_fix_04.diff |
16th December 2008, 21:58 | #1444 | Link | |
Compiling Encoder
(in other words, tell me if it says it didn't work with supplying what didn't work) files: install_strtok_r.sh: "./install_strtok_r.sh /mingw" - should work for most (requires base directory prefix of lib and include dirs as a parameter - which for most is /mingw) x264_mingw_check_strtok_r.diff: recognize existence of strtok_r to not define it as strtok if strtok_r does exist. Edit: oh right, here's a patch for msvc users to use its version of reentrant strtok (and thus have zone support). x264_msvc_zones_fix.diff Last edited by kemuri-_9; 16th December 2008 at 22:21. |
16th December 2008, 23:45 | #1445 | Link |
Thanks again, kemuri; the script worked like a charm.
x264.1057M.exe - Alternate Download Patches used: x264_hrd_pulldown.09_interlace.diff x264_mingw_aligned_03.diff x264_mingw_check_strtok_r.diff gcc 3.4.5 fprofiled build with -march=pentium2. ----------------------------------------------- x264.1057M.x64.exe - Alternate Download Patches used: x264_win64_support.01.r1057.diff x264_win_zone_parse_fix_04.diff (as the custom strtok_r patch likes to crash with the 64-bit build, unsure as of why but it crashes upon reaching 100% completion. I suspect gcc being stupid, personally.) x264_mingw_aligned_03.diff x264_hrd_pulldown.09_interlace.diff Last edited by skystrife; 19th December 2008 at 08:52. |
20th December 2008, 21:58 | #1446 | Link |
What do these two uncommitted? patches do?
http://akuvian.org/src/x264/satd.diff http://akuvian.org/src/x264/sea.diff The second one has some SSE4 references |
20th December 2008, 23:14 | #1447 | Link | |
x264 developer
The second one is a prototype of an attempt to make exhaustive a little bit faster. Wait for them to be finished and committed |
20th December 2008, 23:27 | #1448 | Link |
What would a 60 percent faster SATD function result in overall for speed, using typical settings (as an estimation)? I realise its not nice to annoy developers with such questions, but I think its justified in this case .
Keep up the great work! Its appreciated by a lot of people. Merry Christmas/Seasons greetings! |
20th December 2008, 23:29 | #1449 | Link | |
x264 developer
Do the math. (By the way, we define "60% faster" as "60% more SATDs can be done in the same period of time", not "takes 60% less time").
Follow x264 development progress | akupenguin quotes | x264 git status ffmpeg and x264-related consulting/coding contracts | Doom10 Last edited by Dark Shikari; 20th December 2008 at 23:31. |
21st December 2008, 04:31 | #1450 | Link | |
Compiling Encoder
1. it might be crashing due to the mingw aligned patch, since the function names are different for mingw x64.*1 2. the win zone patch also includes a memory allocation change since 03, this change is meant to fix possible incorrect allocations, which could rear it's ugly head in data manipulation and when freeing the data which would result in seg faults. the strtok_r patch does not include the supposed memory allocation fix, as it's never crashed for me in mingw builds, only in msvc builds. *1 I'm holding on releasing the updated patch, since I'm not sure what's going on with mingw x64 having the necessary aligned memory prototypes commented out in the header file. (options are that the methods are not implemented or not needed, but i'm not exactly sure which one it is - current patch assumes the latter) you can try out my build listed in the win x64 support thread to see if it proceeds to crash so i can determine if the patches are ok to release or need some working. Last edited by kemuri-_9; 21st December 2008 at 04:37. |
21st December 2008, 23:36 | #1451 | Link |
I have a question that may be very simple, may be not
I use VFW version of h264 encoder for using in TMpg Express 4.0 Encoder. I use default settings, just set up ABR mode and bitrait. What h264 codec settings can I change to get much better output quality WITHOUT big decrease of encoding speed? I've got not a superb CPU. Only Athlon64 X2 4000+ |
21st December 2008, 23:55 | #1452 | Link | |
Why this patch was not accepted in main code?
22nd December 2008, 00:37 | #1453 | Link | |
Granted it was not in this thread but it wasn't hard to find by searching for posts by akupenguin that contain hrd
x264 log explained || x264 deblocking how-to preset -> tune -> user set options -> fast first pass -> profile -> level Doom10 - Of course it's better, it's one more. |
22nd December 2008, 00:47 | #1454 | Link | |
Max consecutive B-frames: 0 -> 3 Threads: 1 -> 0 Max frame refs: 1 -> 3 |
22nd December 2008, 13:48 | #1455 | Link |
I thought www.x264.nl was self updating? I see there's rev 1058 up on git for 12 hours and www.x264.nl still shows build 1057...
I don't use ESA for which the patch pertains to, however I'm still curious why it hasn't self updated in case the same thing happens later! |
22nd December 2008, 13:53 | #1456 | Link | |
Software Developer
[EDIT] Yup, something seems to be wrong with r1058 This happens with "make fprofiled" on my system: [EDITē] Seems like "-me esa" causes a crash, as soon as the encoding process reaches 100%. Can't post backtrace, because GDB encounters an "internal error" right at the beginning with my r1058 debug build
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 22nd December 2008 at 14:11. |
22nd December 2008, 14:26 | #1457 | Link |
At a guess I'd presume the output file is fine? It may be related to the issue that I and someone else mentioned a few days ago under the x64 x264 thread, that rarely and unreproduceably the x86 x264 crashes right at the end, exactly the same fault as in your screenshot!
22nd December 2008, 14:38 | #1458 | Link | |
Software Developer
22nd December 2008, 14:47 | #1459 | Link |
No problems here.
x264-r1058.rar Patched with, x264_hrd_pulldown.09_interlace.diff x264_mingw_aligned_03.diff x264_win_zone_parse_fix_04.diff |
22nd December 2008, 15:06 | #1460 | Link | |
Software Developer
h.264, x264, x264 builds, x264 patches, x264 unofficial builds |
