19th September 2016, 10:11 | #24901 | Link | |
[Options] VERSION=0.50.0.18 MIN_M2TS_SIZE=5 ENABLE_TEST=1 DEFAULT_LANG=spa MULTIPROCESS=6 THREADS=12 TWEAK_X265=--pmode --pme --uhd-bd IMPORT_PAL_TO_FILM=1 EXTENDED_GOP=1 NEW_CRF_PREDICTION=1 B_PYRAMID=1 ARCHIVE_ENABLE=1 ARCHIVE_CRF=13.7 ARCHIVE_QUALITY=3 ARCHIVE_LIMIT=0 ARCHIVE_265=1 ENCODER=0 MODE=0 ENCODE_QUALITY=3 ONEPASS_ENCODING=0 AUTO_QUALITY=0 AUDIO_TO_KEEP=all SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=1 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AUDIO_DRC=0 DECODER=3 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=24315 QUICK_EXTRAS=0 ENABLE_BLANKING=0 SUPPRESS_FF_WARNING=1 TARGET_SIZE=24315 [Paths] SOURCE_PATH=M:\ DGIndexNV=C:\Users\Desktop\BD_Rebuilder\dgdecnv2052\DGIndexNV.exe DGDecNV=C:\Users\Desktop\BD_Rebuilder\dgdecnv2052\DGDecodeNV.dll WORKING_PATH=Q:\REBUILDER10\ Last edited by lauguru; 19th September 2016 at 10:14. |
19th September 2016, 14:31 | #24903 | Link |
It certainly isn't BD-RB. It doesn't even us Windows Installer. Search the thread... I seem to recall someone else experiencing this at some point -- if I recall correctly it was caused by another program's installation.
19th September 2016, 21:39 | #24904 | Link |
Is BD Rebuilder supposed to keep subtitle depth settings for Blu-ray 3D? In my case I tried in Movie-Only mode.
I rebuilt a movie that according to tsMuxeR GUI has "3d-plane: 2" for the english subtitle track and "3d-plane: 0" for the german subtitle track. If I load the rebuilt Blu-ray into tsMuxeR GUI both 3d-planes have 0 as their value. In this thread I found some information about the 3d-planes in tsMuXeR. I also found some posts here concerning subtitle depth but am not sure if it's supposed to be fully implemented now or not, or maybe just in Full Backup-mode, which I didn't try? |
19th September 2016, 22:32 | #24905 | Link | |
In that case it was MS Office messing up MSCOMCTL.ocx. ggtop |
21st September 2016, 20:05 | #24906 | Link |
Just out of curiosity why you have --uhd-bd, do you have Ultra HD player to play them?
22nd September 2016, 06:37 | #24907 | Link |
Sorry to ask about this again, but I remember everyone here was talking about how the newest version of x264_64 in BDRB was for some inexplicable reason slower and not utilizing the full CPU, right...?
And, I have been noticing that my encodes do seem to be taking longer (I always use LAVF) So, was the suggestion then to go back to an older version of BDRB and take the x264_64.exe out of one of the folders and replace the new version with it...? I can't remember... |
22nd September 2016, 09:46 | #24908 | Link | |
Full backup incl. burning is ~ 1 hour. |
22nd September 2016, 11:19 | #24909 | Link | |
http://x265.readthedocs.io/en/default/cli.html |
22nd September 2016, 14:12 | #24911 | Link | |
I would be careful, as you don't want to get stuck using an old version of X264. Frankly I'm surprised that the X264 team hasn't gotten complaints about this and fixed it by now. |
22nd September 2016, 14:21 | #24912 | Link | |
@jdobbs Should BD-Rebuilder Keep 3D subtitle depth?? |
22nd September 2016, 15:13 | #24913 | Link | ||
In you case you want to know what --uhd-bd does Quote:
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 22nd September 2016 at 15:23. |
22nd September 2016, 16:07 | #24915 | Link | |
D-Plane 2 in TSMuxer or something like that?? |
22nd September 2016, 18:34 | #24917 | Link |
For your information, if I use tsMuxeR GUI directly to create a Blu-ray ISO with only the audio and subtitle languages that I desire, i.e. german and english, the 3d-planes stay the same as in the original.
If I understand it correctly, those 3d-planes are some sort of table with information where on the Z-axis the different subtitle texts are positioned over time. And as the subs may have slightly different timings or sentence lenghts, the 3d-plane for i.e. the english subtitle texts might place the german subtitle texts at positions where they interfere with 3D objects from the movie. So I think it would be desirable to keep the 3d-planes together with their corresponding subs if somehow possbible. |
23rd September 2016, 02:26 | #24919 | Link | |
I'm just simply running the last version of BDRB. JD, do you think that I should do that, or should I replace the .exe from the last version in this one and use the current new one? I DO in fact always use LAVF, so it really does make a difference. For some odd reason, when I use FRIM (which is my only choice since I ALWAYS get that weird AnyDVD error on EVERY source when I use DirectShow) I notice that the BD-25 size always comes out a little short. No big deal, but with LAVF it almost always comes out to 22.9, whereas with FRIM it seems to come out to 21.xx most times. No biggie I guess... Is there really any other difference using FRIM instead of LAVF...? Thanks! |
23rd September 2016, 02:37 | #24920 | Link | |
