Old 5th September 2018, 22:00   #881  |  Link
sneaker_ger
Originally Posted by MoSal View Post
Is it Chrome? or a Chromium distribution package?
Chrome from Google on Windows 7 x64, not Chromium.
Old 5th September 2018, 22:32   #882  |  Link
marcomsousa
I ask information to Google and they said that the AV1 note in the media update is an error.
They pulled AV1 support in M69 as there were late changes made to the MP4 specification.
The spec has been finalized by AOM, so they have moved launch scheduling to M70.
This pull request in MP4 specification repository suggests that will be finalized soon.
marcomsousa is offline   Reply With Quote
Old 7th September 2018, 21:59   #883  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
AV1 support is to be reenabled in Chrome 70.
Old 8th September 2018, 07:08   #884  |  Link
marcomsousa
The AV1 MP4 specification was finalized yesterday.
Old 10th September 2018, 02:20   #885  |  Link
Mr_Khyron
Member
Mr_Khyron's Avatar
Youtube has started to encode videos to AV1
https://www.youtube.com/watch?v=F1B9Fk_SgI0
You must have youtube-dl (2018-09-10)
Mr_Khyron is offline   Reply With Quote
Old 10th September 2018, 08:06   #886  |  Link
ChaosKing
And you can download it like this
youtube-dl.exe -f 396  https://www.youtube.com/watch?v=F1B9Fk_SgI0
Old 10th September 2018, 08:22   #887  |  Link
marcomsousa
1080p
Interesting to compare this 3 formats
AV1 - 33.37MiB
youtube-dl.exe -f 399  https://www.youtube.com/watch?v=F1B9Fk_SgI0
VP9 - 42.30MiB
youtube-dl.exe -f 248  https://www.youtube.com/watch?v=F1B9Fk_SgI0
AVC1/H.264 - 41.34MiB
youtube-dl.exe -f 137 https://www.youtube.com/watch?v=F1B9Fk_SgI0
Old 10th September 2018, 11:23   #888  |  Link
sneaker_ger
Thx. ffmpeg can decode/play it already. Interesting that it's not webm. (I know it was said mkv/webm binding isn't final yet.)
Old 10th September 2018, 12:02   #889  |  Link
mzso
Originally Posted by Mr_Khyron View Post
Why is the format identifier so messed up? "av01.0.05M.08" and such. On second look AVC is messed up also.
And it only goes up to 480p?
Old 10th September 2018, 13:10   #890  |  Link
MoSal
Higher resolutions are probably still encoding
https://github.com/MoSal
MoSal is offline   Reply With Quote
Old 10th September 2018, 13:23   #891  |  Link
Thats not messed up, thats the codec parameters string as the MP4 specification, its used for immediate profile/level recognition without having to parse the file.
https://aomediacodec.github.io/av1-isobmff/#codecsparam
av1, Main Profile (0), Level 3.1 (05), Main Tier (M), 8 bit (08)
Old 10th September 2018, 13:23   #892  |  Link
marcomsousa
You can also decode/play with Chrome 70 DEV (via chrome://flags/)
Chrome/Firefox don't add any features that can be incompatible in the future.
mp4 codecs param
It's beginning encoding videos with AV1 as a testing or to push the standard.
It's too expensive encoding all videos at this moment, maybe it's better waiting 1 year (with custom capable encoding hardware).
Old 10th September 2018, 20:36   #893  |  Link
mzso
Ah, okay.
So, is LAV holding back support until some sort of wider adoption of AV1 is accomplished?
I didn't suggest that YT should start converting all videos. But converting all resolutions makes sense, for the few that are encoded.
Old 11th September 2018, 05:14   #894  |  Link
benwaggoner
The era of HW encoders is behind us. HEVC was too complex to do with ASIC or even with GPU pixel shaders. Encoding with modern complex codecs like AV1 is going to be CPU, and maybe FPGA.
Ben Waggoner
My Compression Book
Old 11th September 2018, 05:50   #895  |  Link
olduser217
I think there are currently some mobile SOCs or surveillance SOCs that support 4K HEVC encoding with hardware accelerator.
olduser217 is offline   Reply With Quote
Old 11th September 2018, 07:33   #896  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Holy cow, as soon as the extensions get support I'm going to be downloading everything both ways and testing. Hopefully AV1 broad release lives up to its promise.
Old 11th September 2018, 07:56   #897  |  Link
SmilingWolf
I am maddo saientisto!
SmilingWolf's Avatar
Hi y'all!
So, since I keep finding more and more alignment-related bugs that only show up on GCC 8.2, but not on 7.3 (compiler's fault? aomedia's fault? Who knows <rant>they have barely gotten any attention despite the community's effort and the fact they involve common configurations and major compiler releases</rant>) I decided to just go for it and build a GCC 7.3 cross compilation VM
Builds specs:
GCC 7.3, 64bits only, statically linked, secure api enabled, so no Win XP support
lbd binaries have been compiled with -DCONFIG_LOWBITDEPTH=1
hbd binaries have been compiled with -DCONFIG_LOWBITDEPTH=0
Use the former for all your 8bits needs since they are considerably faster, the latter for 10-12bits
av1-1.0.0-541-g7d447f5b0: https://mega.nz/#!0wxmgCqS!vBuViCEA7...v1MubYI0lJnluI
SmilingWolf is offline   Reply With Quote
Old 11th September 2018, 09:58   #898  |  Link
Pushman
It is in HD now:
Pushman is offline   Reply With Quote
Old 11th September 2018, 11:08   #899  |  Link
@SmilingWolf: I'll keep an eye on it, as soon as MABS passes in both branches again. But for now, there is a greater evil breaking the building of ffmpeg. If the API for AV1 was ever "frozen", it seems to melt already.
And yes, I shared one of the issues of GCC 8.2.0 creating unaligned RAM access when vector optimization is enabled, several weeks ago, and apart from adding more CC's, not much happened about it.
Old 11th September 2018, 11:46   #900  |  Link
SmilingWolf
Well TBF they froze the bitstream and released a "stable" version 1.0, such issues are to be expected when using an old and moving codebase that needs some cleaning up after many different iterations.
Shouldn't take much more than removing lines 741-744 from libavcodec/libaomenc.c
This one's on FFMPEG, and will probably be fixed in a day or so
What bothers me much more is the same as the second part of your post, the inertia over months-long periods of time in the AOM tracker
Regarding this, they are evaluating using the patch I suggested in comment 8 as a short term fix. BUT now it can't be tested with GCC 8.2 on master, because there is another couple of access violations of various nature happening at different optimization levels because of (as far as I've been able to test) some unholy interaction between GCC 8.2 and AVX code
Side note: unaligned memory access is fine AS LONG AS the ASM instructions emitted take into account memory could be unaligned. In this instance GCC 8.2 -O3 emits instructions that expect memory to be aligned to a 16-byte boundary (movdqa and movaps), while GCC 8.2 -O3 -fno-tree-slp-vectorize emits instructions fit for unaligned memory access (movdqu and movups)
My advice is to stay on GCC 7.3 for AV1 for the time being. I found the laptop I was using back in june to build A/V stuff with an old toolchain, if you want I can zip it up and upload
