Old 13th April 2018, 15:33   #21  |  Link
So, chances are good that the makefile will work with the native compiler set of either MinGW32 or MinGW64 ... maybe I try to compile it then. Despite the last change being half a year old.
Old 13th April 2018, 15:40   #22  |  Link
colinhunt
^ I'd be interested in testing the binary if you manage to compile one.
Old 13th April 2018, 16:12   #23  |  Link
Unfortunately I did not. There are some errors (several "enum constant in boolean context" warnings treated as errors in extlib/Eigen/src/Core/Assign.h). I may get further if I knew how to disable this strictness?!
Paste: JVET JEM rev. 595 in MinGW64
Old 13th April 2018, 21:56   #24  |  Link
I commented out the CPPFLAGS option "-Werror" in build/linux/common/makefile.base to get the software built anyway; so expect it to break later...
JVET rev. 595 (HM-16.6-JEM-7.1) — small archive for the minimum software selection, large only for the curious
Old 13th April 2018, 23:16   #25  |  Link
Tommy Carrot
Tommy Carrot's Avatar
Thanks for the build, so far it's working without any crashes. I cant say anything about the quality yet, but the encoding speed is not that bad. I mean it's very slow, but not AV1 slow.
Edit: nevermind, on a higher resolution (720p) test encoding, it's much slower in comparison, the encoding speed is around halfway between AV1 --cpu=used=0 and --cpu-used=1. The quality at low bitrate is VERY impressive though. Easily better than AV1 or XVC.
Tommy Carrot is offline   Reply With Quote
Old 14th April 2018, 12:33   #26  |  Link
iwod
Originally Posted by foxyshadis View Post
It seems like hikvision is the only one who's shown any interest this year, and I actually know a few people there. I should reach out and see what they're working on; aside from that, the project is essentially dead. I guess improving HEVC is still the only priority for all the big research companies.
I thought they have some Demo in NAB?
iwod is offline   Reply With Quote
Old 14th April 2018, 22:23   #27  |  Link
I do not even know what "NAB" means; but yes, it was reported in the thread about AOM.
Old 14th April 2018, 22:42   #28  |  Link
"National Association of Broadcasters", they just had their tradeshow last week where content creators and codec people like to show off.
Old 15th April 2018, 06:26   #29  |  Link
Could a moderator please fix the typos in the thread title, as I reported a few days ago?
Old 15th April 2018, 13:08   #30  |  Link
Tommy Carrot
I've done some more tests with this codec. It's unfortunate that even if they finish the development it's probably doomed because of patents and licensing issues, because from a technical standpoint, it seems to be significantly better than AV1. It has consistently better (and more consistent) quality, in some cases by a pretty big margin.
Old 15th April 2018, 13:37   #31  |  Link
hajj_3
The other big problem is that it will be ratified 2.5yrs after AV1. There will be huge numbers of phones, tablets, laptops, desktops, tvs etc with hardware decoders shipping by the time h.266 is ratified. I reckon within 1yr of h.266 is ratified that AV2 will be ratified, which will likely have 0-15% better compression than h.266.
Old 15th April 2018, 19:33   #32  |  Link
colinhunt
Thanks!
Old 15th April 2018, 20:25   #33  |  Link
iwod
Nearly 1.4 Billion of Smartphone, 150M Tablet, 250M Notebook and Desktop. 200M of TV, Camera, STB, and other consumer electronics combined per year
That is 2 Billion unit every year from Consumer Market. Excluding the professional uses.
If they only take 50 Cents / unit, that is annual $1B revenue stream. If you expect the codec to last 10 - 20 years, that is total $20 Billion return.
With No Cap. The more unit you sell the more you pay.
The software implementation should be free. I mean, the codec would now be so complex it is literally impossible to play without a top range general hardware or dedicated decoder. Along with free image format.
Old 19th April 2018, 18:04   #34  |  Link
augman000
I'm going to start doing some comparative testing of my oen today.
When you say "low bitrate", are you talking 512kbps or less? Also, have you gone below 480p in your low bitrate tests?
augman000 is offline   Reply With Quote
Old 19th April 2018, 19:17   #35  |  Link
Tommy Carrot
On low bitrate, generally i mean around or under the size of x264 crf 30. But i tested it waaaay lower and in normal range as well, on different clips. Generally my finding is that the lower the bitrate, the larger JVET's advantage is (especially on cartoon stuff).
However, be prepared that the encoder is very slow, and cannot read y4m, only raw yuv. I only had the patience to test it on few seconds long 720p and lower res videos. But as the encoder is single-threaded, you can run a couple encodings in parallel.
Old 19th April 2018, 20:24   #36  |  Link
augman000
Sure, I've been playing around with AV1 for quite some time now, so I've learned to be very patient.
Tried to run a quick test on lunch with no luck. Could you give me a sample vommand line syntax? I obviously overlooked or misunderstood something when I looked over the usage info.
Old 19th April 2018, 20:40   #37  |  Link
Tommy Carrot
Here is an example:
TAppEncoderstatic.exe -c config-samples\encoder_randomaccess_jvet10.cfg -q 25 -fr 25 -wdt 720 -hgt 288 -f 50 -i test.yuv -b jvet.bin
I encoded a 720x288 video at 25 fps, and encoded 50 frames in total. You have to set every parameter manually, the encoder is kinda dumb.
In the config file, i set the intra period to 256 frames, i think the default is too low.
Old 19th April 2018, 20:47   #38  |  Link
augman000
Here is an example:
Ah, I think I already see my mistake.
Yhanks for the help.
Old 30th April 2018, 15:45   #39  |  Link
hajj_3
Could a moderator rename this thread please as this codec has an official name now 'Versatile Video Coding' (VVC): http://news.itu.int/versatile-video-...arts-strongly/
Old 30th April 2018, 20:32   #40  |  Link
I wonder if a new source repo will be announced. The Fraunhofer JVEM SVN had a few updates to r599 to prepare a "transition to VTM".
