Old 29th November 2017, 13:53   #2841  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by lansing View Post
I have a problem applying multiple instances of the virtualdub filter neatvideo in vapoursynth, it was able to load preview but crash on preview close.
Interesting observation. Does it crash on script evaluation, first frame request or later? There's probably some locking/shared resource in the dll that's causing it. I'll try to debug it just to see but these things are hard to figure out without the source.
Old 29th November 2017, 15:25   #2842  |  Link
lansing
It works fine on preview, I was able to navigate and seek without a problem. It crashes only when I close the preview. I tried opening benchmark while still with the preview window open, the benchmark window works fine until I tried closing it.
I tried the same actions on virtualdub filtermod, no problem on navigate and seeking. I tried running "video analysis pass" and abort it and no crash. The program only crash on close. Here's the crash info.
https://pastebin.com/3LY0zMrA
Old 2nd December 2017, 18:43   #2843  |  Link
Selur
Selur's Avatar
Small question: Is there a source filter which can handle movs which only link to the tracks?
On ffmpeg I can play such files by adding '-enable_drefs 1', but I don't know of any option in FFmpegSource2, LSMASHVideoSource or LWLibavVideoSource which supports this.
-> is there some to me unknown option or source filter which could be used for this?
Cu Selur
Ps.: Background: A user asked me (see: https://forum.selur.net/showthread.php?tid=162) whether I could add support for this in Hybrid which is why I'm looking into it.
Old 2nd December 2017, 18:45   #2844  |  Link
Myrsloik
Myrsloik's Avatar
Cu Selur
Maybe, create an issue with this text and maybe I'll look into it later. No idea how that part of the api works.
Old 2nd December 2017, 18:45   #2845  |  Link
Selur
Selur's Avatar
Will do. Thanks!
Old 2nd December 2017, 19:34   #2846  |  Link
Myrsloik
Myrsloik's Avatar
Will do. Thanks!
Do you have some small sample to go with it? I think it's just a simple option to change but need to be able to test it.
Old 2nd December 2017, 19:36   #2847  |  Link
Selur
Selur's Avatar
There's a download link (google drive) to a test folder with the files in the first post over in my board. -> https://forum.selur.net/showthread.php?tid=162
Cu Selur
Old 4th December 2017, 05:25   #2848  |  Link
lansing
Can I output image file name with imwrif base on frame number in the frame property?
Old 4th December 2017, 09:42   #2849  |  Link
Myrsloik
Myrsloik's Avatar
If you call imwri insode frameeval ypu should be able to do it.
Old 5th December 2017, 04:07   #2850  |  Link
lansing
I have problem with the syntax on appending clips reading from text file. I need to reorder a clip like this:
clip[500:600] + clip[400:450] + clip[601:700]
I have looked in remapframes, but it doesn't have such function.
Right now my text read like this:
400 450
601 700
And I use a for loop to create the clips, but I always ended having to create a dummy 1 frame accumulator clip so that I can append the clips onto, and then strips that out after the loop.
clip = core.ffms2.source("abc")
accum_clip = clip[1]
with open(file) as f:
     line = f.readline()
     for line in f:
          start, end = (int(x.strip()) for x in line.split())
          accum_clip += clip[start:end]
clip = core.std.Trim(accum_clip, 1)
How do I avoid doing that dummy clip?
Old 5th December 2017, 05:57   #2851  |  Link
lansing
Ok that looks better than my dummy clip. Didn't know that you can pack those shortcut format into the splice function.
Old 6th December 2017, 04:58   #2852  |  Link
tyee
Just starting to learn VS, but can't find links to any 64 bit plugins to test a script. Trying to find RemoveGrain.dll and Repair.dll to test finesharp script. Anyone got links?
update - ok, I read they are not needed anymore but I would like to know where the 64 bit plugins reside?
tyee is offline   Reply With Quote
Old 6th December 2017, 06:26   #2853  |  Link
lansing
http://www.vapoursynth.com/doc/pluginlist.html
Old 6th December 2017, 07:10   #2854  |  Link
lansing
Updating on my issue with loading multiple instances of a virtualdub filters. I did more testings on a few more vd filters, the problem should be coming from either avisynth or virtualdub. (I highly believe that it's avisynth)
Loading multiple instance of any vd filter in an avs script will result in an "out-of-bound memory access" crash on program close, which is the same behavior I had in vapoursynth earlier.
This will crash in avisynth:
LoadVirtualDubPlugin("Autolevels.vdf", "Autolevels", 0)
src = AVISource("sample.avi").ConvertToRGB32()
a = src.Autolevels(40, 46, 50, 0, 0, 0, 0, 0)
b = src.Autolevels(40, 80, 50, 0, 0, 0, 0, 0)
a+b
This will work:
LoadVirtualDubPlugin("Autolevels_copy.vdf", "Autolevels_copy", 0)
b = src.Autolevels_copy(40, 80, 50, 0, 0, 0, 0, 0)
a+b
Old 6th December 2017, 08:54   #2855  |  Link
pinterf
Yes, already reported, something like a double free at exit, don't spend any more time investigating on the vs side.
pinterf is offline   Reply With Quote
Old 6th December 2017, 19:01   #2856  |  Link
lansing
Ok hope this get fix soon, getting it to work fills in the last missing piece of my project.
Old 9th December 2017, 04:46   #2857  |  Link
lansing
Is there a function that can replace a range of frames with another range of frame of the same clip?
I want to replace frame 200-250 with frame 0-150. It's not remapping, the length of the resulting clip should be different to the original. I looked into remapframes but it doesn't have it.
Old 9th December 2017, 07:28   #2858  |  Link
AzraelNewtype
AzraelNewtype's Avatar
Sure.
http://www.vapoursynth.com/doc/functions/trim.html
http://www.vapoursynth.com/doc/functions/splice.html
AzraelNewtype is offline   Reply With Quote
Old 9th December 2017, 08:20   #2859  |  Link
lansing
I know that we can write it using those native functions. I'm just asking to see if we have something written already.
I have another question about slicing, is there a short form to get a clip of N frame to the end of the clip? "clip[50, -1]" only gets frame 50 to the second to the last frame, is there a flag that represent the last frame of the clip?
Old 9th December 2017, 09:51   #2860  |  Link
AzraelNewtype
clip[50:]
Of course [:-1] is only giving the second to last. That's what negative slice indexes do.
As for wrapping three trims and a splice to do arbitrary replacement of unrelated clips, that kind of really small helper function isn't the sort of thing people share libraries of. A naive implementation is probably about five lines. It's barely even syntactic sugar if you have to define the trim points of the input and replacement separately.
speed, vaporware, vapoursynth
