Go Back   Doom9's Forum > General > DVD2AVI / DGIndex
Old 24th June 2014, 19:18   #3021  |  Link
Morku
Thats all I get ô.o I am sure, I am doing wrong
00000000	0.00000000	[4260] Morku: ref 1
Morku is offline   Reply With Quote
Old 24th June 2014, 19:21   #3022  |  Link
No, that's OK, I expected that. Please re-download DGIndexNV_Morku and do it again. Each time I add new traces to get closer to the problem.
Thank you for your patience and assistance.
Old 24th June 2014, 19:29   #3023  |  Link
Morku
00000000	0.00000000	[4904] Morku: ref 5
00000001	5.89221283	[4904] Morku: ref 1
00000002	5.89222980	[4904] Morku: ref 5
00000003	5.89227603	[4904] Morku: ref 6
00000004	5.89228597	[4904] Morku: ref 7
And again a video, just in case, I am doing wrong: https://www.dropbox.com/s/s4q1b7jvfactc68/dbgview.mkv
Old 24th June 2014, 19:35   #3024  |  Link
Please close and re-open Dbgview each time, or do Edit/Clear display.
Please double check it. Your video didn't match the trace.
Wait for another version please...
Old 24th June 2014, 19:40   #3025  |  Link
Morku
I did.
Proof: woops wrong video, wait.
Okay, here the right proof video: https://www.dropbox.com/s/s8ugb9bjgm4bwni/dbgview3.mkv
EDIT: And again... I don't like Dropbox.
EDIT2: Yep, It's finally the right video ^^
Old 24th June 2014, 19:51   #3026  |  Link
Looks like GetSaveFileName() is failing (sporadically, on Windows 8/8.1). Please re-download and try again.
Old 24th June 2014, 19:57   #3027  |  Link
Morku
00000000	0.00000000	[4288] Morku: ref 5
00000001	5.26865458	[4288] Morku: ref 1
00000002	5.26872158	[4288] Morku: ref 5
00000003	5.26877219	[4288] Morku: ref 6
00000004	5.26878418	[4288] Morku: ref 7
Old 24th June 2014, 20:02   #3028  |  Link
Morku
I could make a video again, but it will look like dbgview3.mkv...
CRC32 of my DGIndexNV_Morku.exe: F2919DDA
Old 24th June 2014, 20:08   #3029  |  Link
Ouch, hard crash in Microsoft code!
Please re-download and try again. I am testing something I found on the net.
Old 24th June 2014, 20:10   #3030  |  Link
Morku
Um...
00000000	0.00000000	[3040] Morku: ref 5
00000001	6.03631456	[3040] Morku: ref 1
00000002	6.03634675	[3040] Morku: ref 5
00000003	6.03637747	[3040] Morku: ref 6
00000004	6.03640263	[3040] Morku: ref 7
Old 24th June 2014, 20:26   #3031  |  Link
Thinking...
Old 24th June 2014, 20:39   #3032  |  Link
OK, no need to hang around. I have to do some research on this. Thanks, Microsoft, for screwing things up.
Old 24th June 2014, 20:42   #3033  |  Link
Morku
Okay, no problem. I will randomly visit this thread, if I have to test again.
Old 24th June 2014, 20:50   #3034  |  Link
One more thing to try... Please re-download and try again.
If only it would fail for me...
Old 24th June 2014, 20:59   #3035  |  Link
Morku
00000000	0.00000000	[5260] Morku: ref 5
00000001	6.11000601	[5260] Morku: ref 1
00000002	6.11003468	[5260] Morku: ref 5
00000003	6.11005575	[5260] Morku: ref 6
00000004	6.11007623	[5260] Morku: ref 7
EDIT: btw. the same problem occurs on 64bit version of DGIndexNV.
Old 25th June 2014, 04:59   #3036  |  Link
It's a Microsoft problem. I am looking for a workaround.
Old 25th June 2014, 14:33   #3037  |  Link
I have another attempt. Please re-download DGIndexNV_Morku.exe and test it. The traces were removed so don't bother with Dbgview, just tell me if it still crashes.
Old 25th June 2014, 15:11   #3038  |  Link
Morku
No, it doesn't crash anymore. It's working now
Old 25th June 2014, 15:14   #3039  |  Link
Morku
Oh, wait, no. It crashs when I click on "Desktop".
Here you can see again: https://www.dropbox.com/s/xelk4njihn5tbtk/desktop.mkv
I also realised, that the program detects the fps of the mov file wrong. The preview window says in title 25fps. But it's wrong. It's 29,97fps.
Old 25th June 2014, 15:24   #3040  |  Link
Please re-download again. Does it crash now only when you click on Desktop? If so, I may know what is happening (permissions problem).
DGIndexNV does not support MOV! Don't test with MOV files.
