16th January 2020, 23:26 | #581 | Link | |
If you've used potplayer theres a video setting on "levels/offset" and "colorspace" theres a setting there for ycbcr on full or limited and ycbcr/rgb conversation on limited, full as well. Also theres a input output of 0-255 or 16-235. My question is would those matter in the conversions formula or does lav filter override it? I also like the soap opera effect with the smooth motion, will that affect it, I want my playback to be smooth @ 60fps. The scaling on my madvr was that it upscales 720, 1080 all to 4k fyi |
17th January 2020, 00:12 | #582 | Link |
Mine is set to D3D 11. Is that software? Gives the best image so far
17th January 2020, 00:20 | #583 | Link |
@Magik Mark - D3D11 is video card hardware decoding, so that's fine. You'd only be using software aka CPU if it was set to "None".
@Teddy_McFluff - You could try YCbCr as described on the previous page to get rid of pretty much all banding. I don't know much about PotPlayer, so I can't help you there, but you'll probably be fine just by setting madVR to 0-255 and 10-bit. I'm guessing by soap opera effect you do in fact not mean madVR's smooth motion, but rather the TV's motion interpolation. If you prefer that, then you cannot use smooth motion at the same time. You'd be better off sticking with frame rate switching.
18th January 2020, 19:38 | #584 | Link |
I've been reading through the thread and I'm bit a confused. I want an Oled and will probably go with a C9 as the B9 seems to have more banding issues. I prefer Madvr @60 with smooth motion for all content.
Once nvidia releases their firmware update for my rtx2070 to do 4k@120 via hdmi 2.1, will the C9 be able to handle that? Will it even matter for watching madvr content? Would I be able to run at 24/23p via madvr switching with smooth motion off to activate the 120hz on the tv and not have to do turn on any true cinema or other BS and would that be better than using smooth motion at 60 hz? Thanks for the help! |
18th January 2020, 21:05 | #585 | Link |
Yes, the C9 is the TV that firmware update is for, if it really happens (where did you hear that it would?). Smooth motion is better at 120 Hz, so it would be helpful.
No, 24/23p input would not activate the 120Hz on the TV with all the BS off. I don't like my C9 with everything off and 23p input, 60p with smooth motion is better in my opinion. This is for SDR in PC mode (444 chroma) which the highest quality option for SDR with madVR, also sending YCbCr 444 limited from the GPU with full range RGB from madVR. For HDR you need to set the HDMI port to the default or home theater (422 chroma) and then you can send YCbCr 422 10 bit from the GPU, though the quality difference from 8 bit YCbCr 444 is not significant, if it is actually better. Personally I always send YCbCr 444 and only change the HDMI port label on the TV when switching between SDR and HDR.
madVR options explained |
19th January 2020, 01:01 | #586 | Link |
QB the Slayer
On my C8 (not much different from a C9)… I go the other way. I don't switch anything. I leave the TV on the "normal" HDMI setting, GPU is Full RGB 8-bit, and madVR is set to 10 Bit (to make sure HDR is enabled when needed). In this scenario, only the TV is doing something behind madVR's back. And this is un-avoidable at the moment since PC mode for HDMI on LG is seriously borked with horrible banding.
QB
19th January 2020, 01:29 | #587 | Link |
My C9 has very minimal banding in PC mode with YCbCr 444 limited input. It looks as good as the default HDMI mode, not actually perfect but very good. I think this was improved on the C9 because this is not true on my C7. I really hate subsampled chroma so discovering the C9 could do banding free 444 with YCbCr limited was a great discovery. PC mode still fails hard with HDR tone mapping so I have to change modes.
My GPU does not need 10 bit input to use HDR so I leave madVR on 8 bit. If banding is the same it is hard to argue that letting the TV subsample the chroma is ideal.
19th January 2020, 01:50 | #588 | Link |
How do you think we can give the feedback to LG on the issues we see with PC mode and banding. I see Vincent from HDTVTest recently saying LG seem to listen to a lot of reviewers like him and make fixes based on feedback, but I assume that's all in non PC mode. It would be great if someone like Vincent included PC mode in his reviews and gave the feedback there also.
19th January 2020, 03:22 | #589 | Link |
I have another 3 years before I'll even consider a new TV. While my C8 isn't ideal, they've not fixed enough to warrant another 2-3k purchase for nominal gains. The 2020 models look like they're rebranded model names. The Calman guys posted some screen shots of some of the new options they're going to be able to tweak. Essentially they now have full control over calibrating SDR/HDR/DV. Must be nice. LOL Still, it'd be nice to see how these new ones stack up in PC mode.
19th January 2020, 03:53 | #590 | Link |
The 48" CX looks very nice to me. I will be ordering one as soon as available. Turns out the C9 was a bad investment, a great screen but while VRR is nice I will have never run it at 120 Hz before I replace it.
I will report back how it works. I hope that moving the HDR tone mapping, and all their talk about low latency HDR gaming, will also result in the HDR tone mapping being the same in PC and non-PC modes. I also want the better PPI so the update is still worth it if not. HDR gaming on the C9 and earlier is pretty poor though, either high latency and 422 or bad tone mapping so if they fixed that maybe they fixed PC mode? I don't know how we could really get LG attention on PC mode. I think it would take a popular reviewer testing it in a public way. I have been surprised that Vincent does not mention chroma sampling or anything about PC mode, only because of gaming. Traditionally people who cared about calibrations and maximum quality did not play video games and all other content is already subsampled so I suppose professional calibrators don't normally worry about it. madVR, and the idea of quality chroma upscaling, is still a very niche concern.
19th January 2020, 04:12 | #591 | Link |
I'll be choosing my next panel very carefully. Given that I've already gone 4K with the HDR formats I care about, the next one will have to hit ALL checkboxes for me before it becomes worth it. I couldn't care less about 8k as I think that's more than a few years off before it becomes "real" in any sense of the word. But 4K 120Hz, low latency, higher NIT support, etc....that could be fun. Give me a panel that hits 4000 nits with all the bells and whistles and now we're talking.
19th January 2020, 05:01 | #592 | Link |
I hope nothing temps me after the CX until microLED comes out but it seems unlikely given my lack of self control with displays.
I was not thinking my C9 would last until microLED but now it seems possible. OLED is not a great 10 year display tech but reasonably priced 4K microLED displays actually seem possible 3-4 years from now. It could definitely be longer though, especially if OLEDs get cheaper to manufacture and/or there are unexpected difficulties in reducing the cost of manufacturing microLEDs. I think microLED is the only technology that looks promising as a replacement for OLED. OLED is already a nearly ideal SDR display technology as we wait for microLED and nearly ideal HDR.
19th January 2020, 16:02 | #593 | Link |
Here's Vincent's first look of the 48" CX. And indeed the other guy is raving about the improvements made in gaming mode, but he doesn't mention PC mode at all.
19th January 2020, 18:24 | #595 | Link |
Please upload on external site, like Google Drive, we can not watch the picture, see here:
https://drive.google.com/file/d/1pTr...ew?usp=sharing |
19th January 2020, 19:22 | #597 | Link |
As for microLED I can only hope it's ready by the time I'm ready for a new display. Wouldn't that be nice. I love the C8, even with its shortcomings. I can live with it for a few more year if needs be.
24th January 2020, 01:08 | #598 | Link | |
Do you happen to have an image comparing the 2 settings?
24th January 2020, 04:27 | #599 | Link |
Are you talking about PC mode or normal mode? I don't use PC mode for various reasons, so 4:4:4 is not a priority. I tested every available combination, and 4:2:2 10-bit has the least banding of them all. 4:4:4 8-bit is a good option, but then you might as well use PC mode. In normal mode, I'd use RGB over YCbCr 4:4:4.
24th January 2020, 11:49 | #600 | Link | |
What is Normal Mode?
