2nd January 2022, 18:39 | #31062 | Link | |
3rd January 2022, 05:17 | #31063 | Link |
For some strange reason, I can't get the menu colors to work. Here are the related INI lines:
MENU_ACTIVE_COLOR=0xA6D1D7 MENU_CUSTOM_COLOR= MENU_INACTIVE_COLOR=0x32819A I'm at a loss. |
3rd January 2022, 12:41 | #31064 | Link |
Big Bit Savings Now !
For a quick UHD-BD-R/-RE playability test on standalones https://forum.doom9.org/showthread.php?t=183578
I would kindly ask for known to be working (hidden or open) options which enable building such disc. I will be testing BD-RE-25, BD-RE-50, BD-RE-100 (2 of 3 layers, 3 of 3 layers) (too long that I did not follow development, my bad, and it took longer until hardware became affordable for me)
3rd January 2022, 15:03 | #31065 | Link | |
CUSTOM_TARGET_SIZE=94734 That's twice the default target size BD-RB uses for BD-50. You can use any other value if you think it suits BD-100 better. You can then select "Custom Target Size" from SETTINGS/OUTPUT OPTIONS. Please note that if your source is smaller than your output target, BD-RB may decide to not reencode (because if fits as-is). If you want to force reencoding, add the following line to your INI file: FORCE_ENCODE=1 Even with that set, though, trying to take a smaller source (say BD-25) and stretching to fit a BD-100 will sometimes reach a maximum size for the encoder used. But that is less common. If you are trying to put a standard BD source to UHD format, you can select "Convert BD to UHD-BD (HEVC) Format" from the SETTING/OUTPUT OPTIONS menu. That might occur if you do something like take two or more BDs and combine them into a single UHD disc. You can do that by simply putting the source BD structures under a single folder and selecting that folder within BD Rebuilder. Hope that answers your question. Last edited by jdobbs; 3rd January 2022 at 15:11. |
3rd January 2022, 15:34 | #31066 | Link | |
Life's clearer in 4K UHD
If you are backing up one movie per disc, what do you need a menu for?
3rd January 2022, 17:14 | #31067 | Link | |
Make sure the values are located in the "[Options]" section of the INI. Also make sure there are no other instances of that setting higher up in the INI file (the MS subroutine that handles reading INI files will act of the first setting it encounters). [Edit] I also tried setting MENU_INACTIVE_COLOR=0x0000FF and it came out a bright red. Last edited by jdobbs; 3rd January 2022 at 19:24. |
3rd January 2022, 18:06 | #31068 | Link | |
Many thanks, jdobbs and Happy New Year !
Under Output Options I see only 5 lines to tick: BD-5, BD-9, BD-25, BD-50 and Custom. Encoding Options has no x265 and no UHD entry. Do I have to specify a hidden option to expose that setting ?
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 3rd January 2022 at 18:18. |
3rd January 2022, 18:50 | #31071 | Link |
YES ! This was missing, undocumented in Hiddenopts.txt.
Many thanks, musiclover. There it was: 24th February 2021, 17:13 #30405
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 3rd January 2022 at 19:42. |
3rd January 2022, 19:10 | #31072 | Link |
Whoops. Forgot about that.
There are a lot of options that aren't documented -- mainly to prevent confusion and self-inflicted issues. The majority of BD-RB users aren't necessarily BD savvy. There's also one called UHD_ALL_MODE=1 that allows H.265 encoding of streams that are less than 1080p. While it usually works on many (most?) players -- it violates the UHD-BD spec. Last edited by jdobbs; 3rd January 2022 at 19:19. |
3rd January 2022, 22:25 | #31074 | Link | |||
3rd January 2022, 22:28 | #31075 | Link |
A single file of what? Some kind of movie poster!
4th January 2022, 05:08 | #31078 | Link | |
But, before I continue with my findings, a problem that has been happening pretty consistantly while searching this out is that after I save changes to the configuration I get the "file not found" error. It happens right after creating the pseudo-BD. Right before it goes on to do the menu. Between those two steps a dialog box very briefly shows up. No idea what it says as it is on the screen for too short of a time. If I do nothing and restart BDRB and rerun the job, there is no error. This one has been elusive for ages. Now, on to what I found. Mental error. It came down to my not dealing with the three button states correctly: active, inactive and selected. With only one menu item, it becomes active by default. Thereby it was given the brighter color. For some reason I kept thinking inactive. The inactive color is useless in a single menu. I suspect that you saw the red work because you had at least two menu items. I failed to mention that I only had one. |
4th January 2022, 10:02 | #31079 | Link |
If all you're muxing is a single video file, why do you need a menu (which is another video file)?
