Old 29th August 2019, 10:20   #861  |  Link
Do you guys know why decoding VC-1 using vc1_cuvid is also broken? Unlike software decoder frames are not corrupted but they are decoded in incorrect order.
sample -> https://www.mediafire.com/file/dldzx...ample.mkv/file
script
LoadPlugin("LSMASHSource.dll")
video=LWLibavVideoSource("vc1_sample.mkv",cachefile="vc1_sample.mkv.lwi",decoder="vc1_cuvid")
Decoding works fine in MPC-HC with these settings
PS. yes I have latest driver installed.
Old 29th August 2019, 11:26   #862  |  Link
DJATOM
DJATOM's Avatar
@Atak_Snajpera
HW decoder is actually inactive on your screenshot.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 29th August 2019, 12:40   #863  |  Link
Originally Posted by DJATOM View Post
@Atak_Snajpera
But CPU usage is 3 times lower so it works.
Also there is H/W indicator
Old 30th August 2019, 00:47   #864  |  Link
MeteorRain
結城有紀
https://down.7086.in/AviSynthPlus%20...-r935%2B34.zip
Stop indexing progress spamming
-- Now only refresh at every 1%.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 31st August 2019, 00:22   #865  |  Link
stax76
stax76's Avatar
@HolyWu
With my 49 PGS subtitle 50 GB file using your last build I'm getting 60 seconds load time, with MeteorRain's build it's only 10 seconds.
edit:
both was tested with 20 PGS subtitles, with 49 PGS subtitles MeteorRain's build took 30 seconds and yours 7 minutes.
Old 31st August 2019, 04:01   #866  |  Link
MeteorRain
結城有紀
Yea that was what I immediately noticed when I was encoding some stuff.
Projects
Old 31st August 2019, 11:22   #867  |  Link
Natty
Noob
Natty is offline   Reply With Quote
Old 1st September 2019, 18:20   #868  |  Link
@MeteorRain
Quick question: Why LSMASHSource.dll is 2 times smaller than HolyWu's version?
Old 1st September 2019, 18:25   #869  |  Link
DJATOM
DJATOM's Avatar
Different compilers or some features disabled at configuring time?
Me on GitHub
Old 1st September 2019, 20:06   #870  |  Link
MeteorRain
結城有紀
@MeteorRain
Size of ffmpeg makes huge differences. I disabled lots of features, and that's probably why.
Last build was on VS 2017 n4.1.3. I'll probably do a refresh VS 2019 n4.2.0 soon for the next build.
"C:\Programs (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvars32.bat"
chcp 65001
./configure --toolchain=msvc --prefix=/ffmpeg-msvc32 --cpu=i686 --arch=i386 --target-os=win32 --disable-pthreads --disable-bzlib --disable-iconv --disable-lzma --disable-xlib --disable-zlib --disable-muxers --disable-encoders --disable-network --enable-gpl --enable-version3 --disable-programs --disable-doc
"C:\Programs (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvars64.bat"
chcp 65001
./configure --toolchain=msvc --prefix=/ffmpeg-msvc64 --arch=x86_64 --target-os=win64 --disable-pthreads --disable-bzlib --disable-iconv --disable-lzma --disable-xlib --disable-zlib --disable-muxers --disable-encoders --disable-network --enable-gpl --enable-version3 --disable-programs --disable-doc
Projects
Old 1st September 2019, 21:21   #871  |  Link
ChaosKing
@MeteorRain It would be nice if you could also add vapoursynth support in your next LSmash release on github
Old 1st September 2019, 23:43   #872  |  Link
MeteorRain
結城有紀
@ChaosKing, support of what? Current release had no problem running under VapourSynth. Any particular thing I should be aware of?
Projects
Old 2nd September 2019, 09:28   #873  |  Link
ChaosKing
The current r935+2 release on github only supports avisynth and it would be nice if the next release (r935+X) in your github repo could also include vapoursynth support
I ask because I would like to add it to vsrepo.
Currently it is included in avsrepo https://github.com/theChaosCoder/avs...al/lsmash.json
Old 2nd September 2019, 19:29   #874  |  Link
MeteorRain
結城有紀
Oh you meant github release. Yea definitely.
Also please be aware it's not the original / official release, but rather a fork.
Projects
Old 3rd September 2019, 17:20   #875  |  Link
L-SMASH-Works_20190903.7z
  • Fix abnormal loading time.
  • Improve progress printing.
  • Use both file size and partial checksum (xxhash) for file signature comparison in index file.
  • LWLibav: Fix inaccurate framerate in some files.
  • VapourSynth: Replace configure with Meson build system.
  • VapourSynth: Fix missing setError invocation when there is an error.
  • Fix frame corruption in some VC-1 files by a workaround. Tested Atak_Snajpera's sample by seek-test.py and confirmed to be frame accurate.
Can you reduce size of .dll like MeteorRain did here https://forum.doom9.org/showthread.p...99#post1883899
Old 4th September 2019, 04:22   #876  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Thank you!
Old 4th September 2019, 18:58   #877  |  Link
I don't understand. Does a size difference of 10 MB really matter on current HDD or internet bandwidth?
Anyway, the culprit is not in FFmpeg as I already knew of disabling unused features when I began providing my builds ages ago.
The main reasons are that different compiler being used and two additional libraries being linked in, one is libaom and the other is libmfx.
For libaom it's used for AV1 decoding. I think I will just ditch it since it's way slower than libdav1d. Just use FFMS2 for AV1 and VP9 decoding as it passed random seek test after some proper patching. Unfortunately for AVC and HEVC decoding it still has random seek issue with some samples even using StvG's latest build, while LWLibav passed.
For libmfx it's used for Intel Quick Sync Video decoding. I need someone with capable Intel GPU to test whether the _qsv decoders also have random seek issue like the _cuvid decoders do, so as to decide whether I should keep it or ditch it.
Yes it matters if you use distributed encoding in ripbot264 where all tools and plugins are being downloaded from host PC. I just want to reduce starting time as much as possible on ~80Mbps (10MiB/s) LAN/Wi-FI. I'm already using compressed (by upx) ffmpeg.exe (20MiB),x264(8MiB) and x265(7MiB) in order to reduce encoding delay. I also decided to compress index file with 7zip in order to reduce index file from ~30MiB to ~1MiB.
example script
#VideoSource
LoadPlugin("\\HOST-PC\RipBot264temp\Tools\AviSynth plugins\lsmash\LSMASHSource.dll")
video=LWLibavVideoSource("\\HOST-PC\RipBot264temp\job1\video.mkv",threads=0,cachefile="\\HOST-PC\RipBot264temp\job1\video.mkv.lwi")
cmd.
"\\HOST-PC\Ripbot264temp\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "\\HOST-PC\RipBot264temp\job1\Chunks\1.avs" -strict -1 -f yuv4mpegpipe - | "\\HOST-PC\Ripbot264temp\tools\x264\x264_x64.exe" --stdin y4m --output "\\HOST-PC\RipBot264temp\job1\Chunks\1.264" -
Old 4th September 2019, 19:59   #878  |  Link
StvG
Disabling aom AV1 encoder and aom tests will save space if you didn't do it already.
Can you share those AVC and HEVC samples that have seeking issues with ffms2?
StvG is offline   Reply With Quote
Old 4th September 2019, 20:25   #879  |  Link
videoh
Useful n00b
I second that request. I would like to test them with DG tools.
Old 6th September 2019, 14:47   #880  |  Link
videoh
Useful n00b
Thank you, HolyWu.
