27th January 2013, 14:01 | #16543 | Link | |
If TSMUXER says there is an invalid SRT... then the problem is likely an invalid SRT. You can't expect TSMUXER to fix a corrupt source. If you try to run MKVs through TSMUXER you will find a lot of them that will fail because TSMUXER does not support compression (e.g. zlib), as is true with some players. When it is there you have to remove it. Lots of MKV creation software has that set as a default. If you let BD-RB do the conversion for you it will handle that removal automatically. To find out more about removing compression see the compression option in this link. As you will see, the compresion might very well be the issue you are seeing with the SRT. Last edited by jdobbs; 27th January 2013 at 14:13. |
27th January 2013, 14:38 | #16544 | Link |
Just finished another project... lots of time on the road so I apologize for the limited feedback this last month. I'm out of that grind (or at least will be early this week) so I can start spending more time on BD-RB again.
27th January 2013, 18:20 | #16545 | Link |
By removing the SRT tracks, I have no more problem with TSMUXER, so clearly the issues are linked to these SRT. Despite that they work fine with VLC, they are something wrong preventing to use BD rebuilder and TSMUXER tools.
I found on a forum that it could be linked to blank line when a subtitle is displayed on 2 lines. I tried to extract the SRT with Mkvextract to check. No way. The SRT file is empty ! |
27th January 2013, 20:10 | #16546 | Link | |
28th January 2013, 23:38 | #16548 | Link |
@jdobbs, I didn't really catch what you mean regarding the compression. I need to read more seriously the link you sent to understand I guess !
@hoju3508, I tried Mediainfo on a failing mkv. I got the following data on the SRT : Text #1 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : complets Language : French Default : No Forced : No Text #2 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : forcés Language : French Default : Yes Forced : No |
1st February 2013, 23:35 | #16550 | Link |
Bitter Old Geek
Any issues with resuming a job?
I have really never done this before, but I needed to take my laptop somewhere while it was in the middle of a BDRB job. The resumed video has a couple of unplayable areas in it with bad breakups. I reran the job from scratch and they are gone. Is that an issue with resuming jobs, or a bug with that function?
1st February 2013, 23:37 | #16551 | Link | |
2nd February 2013, 00:13 | #16552 | Link |
I had an odd one the other day; not a rebuild failure, but truly an oddity. I was Backing up a BluRay of "W". The source folder was called "W" but the resulting rebuild ended up in a newly-created folder called "WD-2TB". The source folder ("W") was on a HDD with a volume label "WD-2TB" (Western Digital 2 Terra Bytes), so, it would seem pretty obvious that the new folder name was just copied from the volume label instead of the folder name.
Not sure if this is a BD-RB issue or a Win7-64 issue, or what. It's a pretty far-out edge case (not likely to happen very often), but I thought I'd report it just to get it in the record. |
2nd February 2013, 00:43 | #16553 | Link |
@RobertM
This seems to occur with input names that are short. Maybe 3 or 4 characters or less. I usually get INPUT, which happens to be the name of my source drive. Just tested and it seems the number of characters is 2 or less for this to happen. Last edited by gonca; 2nd February 2013 at 00:47. Reason: more info |
2nd February 2013, 00:57 | #16554 | Link | |
4th February 2013, 09:49 | #16557 | Link |
bug
not play the movie, or the theatrical version and extended version, the extras on hand, if. Code:
[Status] LABEL=THE.MAN.WITH.THE.IRON.FISTS.2012.1080P.BLURAY.AVC.DTS-HD.MA.5.1-PUBLICHD VERSION=v0.42.08 (beta) SOURCE_SIZE=44452706845 SOURCE_VIDEO_SIZE=43688785920 TARGET_SIZE=25583157248 REDUCTION=.568091692189555 RESIZE_1080=0 AUDIO_TO_KEEP=all KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=-1 INSTANCES=5 DGDECNV=0 QUICK=0 ENCODE_STEP=0 COMPLETED=92 REBUILD_COMPLETE=1 [00031] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=268757 RATE=500 SPLITS=1 NSTART=27000000 NEND=27001877 NSIZE=12288 FLINK=0 MLINK=0 [00032] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=268757 RATE=500 SPLITS=1 NSTART=27000000 NEND=27001877 NSIZE=12288 FLINK=0 MLINK=0 [00033] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=268757 RATE=500 SPLITS=1 NSTART=27000000 NEND=27001877 NSIZE=12288 FLINK=0 MLINK=0 [00105] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=46540398 RATE=8553 SPLITS=1 NSTART=27000000 NEND=28704960 NSIZE=45053952 FLINK=0 MLINK=0 [00107] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=289699 RATE=500 SPLITS=1 NSTART=27000000 NEND=27001877 NSIZE=12288 FLINK=0 MLINK=0 [00108] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=286209 RATE=500 SPLITS=1 NSTART=27000000 NEND=27001877 NSIZE=12288 FLINK=0 MLINK=0 [00109] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=300171 RATE=500 SPLITS=1 NSTART=27000000 NEND=27001877 NSIZE=12288 FLINK=0 MLINK=0 [00112] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=132634 RATE=500 SPLITS=1 NSTART=27000000 NEND=27001877 NSIZE=12288 FLINK=0 MLINK=0 [00119] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=2753890 RATE=6530 SPLITS=1 NSTART=27000000 NEND=27133920 NSIZE=2752512 FLINK=0 MLINK=0 [00120] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=2760871 RATE=6461 SPLITS=1 NSTART=27000000 NEND=27133920 NSIZE=546816 FLINK=0 MLINK=0 [00121] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=4090696 RATE=9815 SPLITS=1 NSTART=27000000 NEND=27133920 NSIZE=3883008 FLINK=0 MLINK=0 [00122] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=2757381 RATE=6524 SPLITS=1 NSTART=27000000 NEND=27133920 NSIZE=2752512 FLINK=0 MLINK=0 [00123] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=2760871 RATE=6542 SPLITS=1 NSTART=27000000 NEND=27133920 NSIZE=2807808 FLINK=0 MLINK=0 [00124] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1137779059 RATE=9852 SPLITS=1 NSTART=27000000 NEND=64679040 NSIZE=1111990272 FLINK=0 MLINK=0 [00125] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=250268950 RATE=9869 SPLITS=1 NSTART=27000000 NEND=35298720 NSIZE=244224000 FLINK=0 MLINK=0 [00126] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=117108403 RATE=9868 SPLITS=1 NSTART=27000000 NEND=30882240 NSIZE=111550464 FLINK=0 MLINK=0 [00127] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=290753582 RATE=9847 SPLITS=1 NSTART=27000000 NEND=36617760 NSIZE=284461056 FLINK=0 MLINK=0 [00128] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=144008572 RATE=9863 SPLITS=1 NSTART=27000000 NEND=31772160 NSIZE=141072384 FLINK=0 MLINK=0 [00130] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=5451935 RATE=9803 SPLITS=1 NSTART=27000000 NEND=27180000 NSIZE=6586368 FLINK=0 MLINK=0 [00131] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=198789699 RATE=9607 SPLITS=1 NSTART=27000000 NEND=33622560 NSIZE=193800192 FLINK=0 MLINK=0 [00132] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=4069754 RATE=9869 SPLITS=1 NSTART=27000000 NEND=27133920 NSIZE=4399104 FLINK=0 MLINK=0 [00133] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=4066264 RATE=9860 SPLITS=1 NSTART=27000000 NEND=27133920 NSIZE=4331520 FLINK=0 MLINK=0 [00134] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=4069754 RATE=9869 SPLITS=1 NSTART=27000000 NEND=27133920 NSIZE=4411392 FLINK=0 MLINK=0 [00135] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=4066264 RATE=9860 SPLITS=1 NSTART=27000000 NEND=27133920 NSIZE=4362240 FLINK=0 MLINK=0 [00136] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=4076735 RATE=9886 SPLITS=1 NSTART=27000000 NEND=27133920 NSIZE=4478976 FLINK=0 MLINK=0 [00137] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=83936066 RATE=9759 SPLITS=1 NSTART=27000000 NEND=29748960 NSIZE=82176000 FLINK=0 MLINK=0 [00138] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=83503262 RATE=9756 SPLITS=1 NSTART=27000000 NEND=29734560 NSIZE=81211392 FLINK=0 MLINK=0 [00139] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=91750971 RATE=9765 SPLITS=1 NSTART=27000000 NEND=30006720 NSIZE=90513408 FLINK=0 MLINK=0 [00140] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=79869802 RATE=9754 SPLITS=1 NSTART=27000000 NEND=29613600 NSIZE=78127104 FLINK=0 MLINK=0 [00141] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=79901215 RATE=9747 SPLITS=1 NSTART=27000000 NEND=29613600 NSIZE=78759936 FLINK=0 MLINK=0 [00143] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=549622768 RATE=15026 SPLITS=1 NSTART=27000000 NEND=35393280 NSIZE=530122752 FLINK=-1 MLINK=0 [00144] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=432744728 RATE=14348 SPLITS=1 NSTART=27000000 NEND=33739680 NSIZE=417122304 FLINK=-1 MLINK=0 [00145] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=256886664 RATE=15010 SPLITS=1 NSTART=27000000 NEND=31127040 NSIZE=248592384 FLINK=-1 MLINK=0 [00146] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=48948744 RATE=14420 SPLITS=1 NSTART=27000000 NEND=27763680 NSIZE=47468544 FLINK=-1 MLINK=0 [00147] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=113953122 RATE=14974 SPLITS=1 NSTART=27000000 NEND=28825920 NSIZE=109971456 FLINK=-1 MLINK=0 [00148] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=59817710 RATE=14705 SPLITS=1 NSTART=27000000 NEND=27947520 NSIZE=58472448 FLINK=-1 MLINK=0 [00149] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=195260950 RATE=14635 SPLITS=1 NSTART=27000000 NEND=30085440 NSIZE=188319744 FLINK=-1 MLINK=0 [00150] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=340306157 RATE=14855 SPLITS=1 NSTART=27000000 NEND=32339520 NSIZE=329091072 FLINK=-1 MLINK=0 [00151] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=281783369 RATE=14674 SPLITS=1 NSTART=27000000 NEND=31468800 NSIZE=272007168 FLINK=-1 MLINK=0 [00152] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=165460296 RATE=14302 SPLITS=1 NSTART=27000000 NEND=29567520 NSIZE=159141888 FLINK=-1 MLINK=0 [00153] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1075476215 RATE=14702 SPLITS=1 NSTART=27000000 NEND=44043840 NSIZE=1039337472 FLINK=-1 MLINK=0 [00154] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=18572181 RATE=16043 SPLITS=1 NSTART=27000000 NEND=27314880 NSIZE=17952768 FLINK=0 MLINK=0 [00155] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=2349902686 RATE=14771 SPLITS=1 NSTART=27000000 NEND=64321440 NSIZE=2271006720 FLINK=-1 MLINK=0 [00156] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=222192532 RATE=14820 SPLITS=1 NSTART=27000000 NEND=30533760 NSIZE=214904832 FLINK=-1 MLINK=0 [00157] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=330226011 RATE=15021 SPLITS=1 NSTART=27000000 NEND=32106720 NSIZE=318547968 FLINK=-1 MLINK=0 [00158] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=618208250 RATE=14779 SPLITS=1 NSTART=27000000 NEND=36819360 NSIZE=597331968 FLINK=-1 MLINK=0 [00159] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=788404958 RATE=14590 SPLITS=1 NSTART=27000000 NEND=39406080 NSIZE=760823808 FLINK=-1 MLINK=0 [00160] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1599755513 RATE=14669 SPLITS=1 NSTART=27000000 NEND=52262400 NSIZE=1544669184 FLINK=-1 MLINK=0 [00161] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1822719413 RATE=14719 SPLITS=1 NSTART=27000000 NEND=55901760 NSIZE=1764311040 FLINK=-1 MLINK=0 [00162] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=213494566 RATE=14810 SPLITS=1 NSTART=27000000 NEND=30366720 NSIZE=205799424 FLINK=-1 MLINK=0 [00163] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1624969840 RATE=14806 SPLITS=1 NSTART=27000000 NEND=52812480 NSIZE=1570787328 FLINK=-1 MLINK=0 [00164] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1303532544 RATE=14598 SPLITS=1 NSTART=27000000 NEND=47329920 NSIZE=1257756672 FLINK=-1 MLINK=0 [00165] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1898484557 RATE=14485 SPLITS=1 NSTART=27000000 NEND=56740800 NSIZE=1830365184 FLINK=-1 MLINK=0 [00166] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=768862459 RATE=14399 SPLITS=1 NSTART=27000000 NEND=39015360 NSIZE=740474880 FLINK=-1 MLINK=0 [00167] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=588023657 RATE=14329 SPLITS=1 NSTART=27000000 NEND=36132480 NSIZE=567060480 FLINK=-1 MLINK=0 [00168] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=420661118 RATE=14940 SPLITS=1 NSTART=27000000 NEND=33735840 NSIZE=407832576 FLINK=-1 MLINK=0 [00169] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=263881336 RATE=14705 SPLITS=1 NSTART=27000000 NEND=31177920 NSIZE=255123456 FLINK=-1 MLINK=0 [00170] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=255563819 RATE=14956 SPLITS=1 NSTART=27000000 NEND=31098720 NSIZE=246982656 FLINK=-1 MLINK=0 [00171] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=124856992 RATE=14839 SPLITS=1 NSTART=27000000 NEND=28992960 NSIZE=121387008 FLINK=-1 MLINK=0 [00172] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=344218845 RATE=14678 SPLITS=1 NSTART=27000000 NEND=32446560 NSIZE=332974080 FLINK=-1 MLINK=0 [00173] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=806293030 RATE=14974 SPLITS=1 NSTART=27000000 NEND=39644160 NSIZE=779808768 FLINK=-1 MLINK=0 [00174] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=516007155 RATE=14750 SPLITS=1 NSTART=27000000 NEND=35188800 NSIZE=498708480 FLINK=-1 MLINK=0 [00175] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=444988895 RATE=14301 SPLITS=1 NSTART=27000000 NEND=33908640 NSIZE=428685312 FLINK=-1 MLINK=0 [00176] AUDIO=1111 PGS=111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1089350378 RATE=14580 SPLITS=1 NSTART=27000000 NEND=44143200 NSIZE=1052037120 FLINK=0 MLINK=0 [00177] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=158465624 RATE=9783 SPLITS=1 NSTART=27000000 NEND=32204160 NSIZE=154970112 FLINK=0 MLINK=0 [00178] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=8122057 RATE=9848 SPLITS=1 NSTART=27000000 NEND=27269280 NSIZE=10917888 FLINK=0 MLINK=0 [00179] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=4998189 RATE=6541 SPLITS=1 NSTART=27000000 NEND=27247680 NSIZE=1124352 FLINK=0 MLINK=0 [00180] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=5225062 RATE=6542 SPLITS=1 NSTART=27000000 NEND=27257760 NSIZE=1136640 FLINK=0 MLINK=0 [00181] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=5263456 RATE=6542 SPLITS=1 NSTART=27000000 NEND=27260640 NSIZE=1136640 FLINK=0 MLINK=0 [00182] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=5867287 RATE=6539 SPLITS=1 NSTART=27000000 NEND=27290880 NSIZE=1161216 FLINK=0 MLINK=0 [00183] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=6355937 RATE=6537 SPLITS=1 NSTART=27000000 NEND=27313920 NSIZE=1185792 FLINK=0 MLINK=0 [00184] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=8076682 RATE=9861 SPLITS=1 NSTART=27000000 NEND=27267840 NSIZE=10973184 FLINK=0 MLINK=0 [00185] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=8533919 RATE=9868 SPLITS=1 NSTART=27000000 NEND=27282240 NSIZE=11298816 FLINK=0 MLINK=0 [00186] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=8467602 RATE=9856 SPLITS=1 NSTART=27000000 NEND=27280800 NSIZE=11249664 FLINK=0 MLINK=0 [00187] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=8076682 RATE=9861 SPLITS=1 NSTART=27000000 NEND=27267840 NSIZE=10973184 FLINK=0 MLINK=0 [00188] AUDIO=1 PGS=111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=11402991 RATE=11894 SPLITS=1 NSTART=27000000 NEND=27313920 NSIZE=13977600 FLINK=0 MLINK=0 Code:
[Options] VERSION=0.42.0.8 MODE=0 MIN_M2TS_SIZE=1 MIN_PLAYLIST_MINS=1 WEIGHTP =1 DTSX_ENABLE=1 AUTO_BIAS=4 BLANK_THRESHOLD=1 ENABLE_TEST=1 ENCODE_QUALITY=3 ONEPASS_ENCODING=0 MULTIPROCESS=5 AUTO_QUALITY=0 AUDIO_TO_KEEP=all SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=1 RESIZE_1080=0 DEINTERLACE=1 DEINTERLACER_TYPE=3 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=1 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=24398 ENABLE_BLANKING=1 TARGET_SIZE=24398 [Paths] SOURCE_PATH=D:\THE.MAN.WITH.THE.IRON.FISTS.2012.1080P.BLURAY.AVC.DTS-HD.MA.5.1-PUBLICHD\ WORKING_PATH=I:\REBUILDERDISCONUEVO\ |
4th February 2013, 12:15 | #16558 | Link |
[QUOTE=lauguru;1614309]bug
not play the movie, or the theatrical version and extended version, the extras on hand, if. [CODE][Status] LABEL=THE.MAN.WITH.THE.IRON.FISTS.2012.1080P.BLURAY.AVC.DTS-HD.MA.5.1-PUBLICHD/QUOTE] Come back when u decide to use the original retail store disc (pirate). No retail disc uses a name like that. Verstuurd van mijn HTC Sensation XE with Beats Audio Z715e met Tapatalk |
