3rd March 2019, 09:44 | #55121 | Link | |
ZOTAC MAGNUS EN1060K: Win 10 x64 + Kodi DSPlayer x64 LG OLED65C8 / Denon AVR-X3200W / KEF E305+ONKYO SKH-410 / Synology DS2415+ / Logitech Harmony 950 Last edited by sat4all; 3rd March 2019 at 10:26. |
3rd March 2019, 10:26 | #55122 | Link | ||
I have a JVC projector and a HTPC, my screen is 2.39:1 format (135"). I only ever really watch 2.39 or 2.4 content on my setup and don't really care about 16:9 movies for the projector as I watch them on my 4K TV. I use madVR with my HTPC along with my GPU Sapphire Nitro+ RX 580 4GB. I use madVR for tone mapping HDR also. I overshoot my projector so that the top and bottom is overshooting the screen which leaves me a perfect fit for a 2.39 movie. In doing so, my Windows 10 HTPC desktop which was previously set to 3840 x 2160p 60hz (8bit) was overshooting my screen and I wanted to be able to view my entire desktop within my 2.39:1 screen. In order to do this I have searched the internet and asked on the forums how I can do this. I came across a YouTube video where I was guided to edit a registry file within "regedit" and put a custom resolution of 3840 x 1620p at 60hz which I have done and the result can be seen below: https://i.imgur.com/COnp0gX.jpg After doing this regedit, I restarted my HTPC , went into the AMD software and selected 3840 x 1620p at 60hz for my desktop resolution. This was absolutely fine and I was happy with this. Here is what it looks like with this resolution on my 2.39 screen: https://i.imgur.com/sGexqfi.jpg After I did this I opened up Kodi DSPlayer. My Kodi DSPlayer GUI has always been in 16:9 format within my 2.39 screen and my screen resolution has always been 3840 x 2160p and I have had no issues. Since changing my desktop resolution to a scope format I then wanted to change the way my Kodi DSPlayer looked on my screen . I wanted the GUI to fill the whole screen instead of just 16:9 format.. In order to do this I learned by experimenting that I had to set Kodi DSPlayer's resolution to the same as my desktop (3840 x 1620p) and when I do this the screen stretches out to fill 2.39 but still doesn't look quite right, however when I enable "use fullscreen window" then the GUI sits perfectly within inside my 2.39 screen.. Please see images below: https://i.imgur.com/o8xuscc.jpg https://i.imgur.com/lGYPrtP.jpg https://i.imgur.com/qfcu8PX.jpg https://i.imgur.com/VTsA7ZB.jpg https://i.imgur.com/tihDvP1.jpg So now the issue I was having is that my movies when played with madVR seemed to be downscaling to 3840 x 1620p and didn't play right.. it was stuttering. In order to avoid this I added screen resolutions (2160p23, 2160p24, 2160p30, 2160p50 and 2160p59) into madVR in the hope that it would force the videos to play in this format and not downscale it to 3840 x 1620p which was my desktop resolution and the resolution I had to set within madVR to get the GUI to display correctly. In doing the above, the video plays correctly now (I think, please check the the images as the movies is 3840 x 2160 but it is showing 3840 x 1607, 2.39) please can you confirm this is OK? I think this is happening as I am using madVR black bar detection .. Please see pics below: https://i.imgur.com/TWpllJY.jpg https://i.imgur.com/KS66lWJ.jpg Please note that in the above picture is says "D3D11 fullscreen windowed (8bit)" . as my movies are 4K HDR shouldn't it say 10bitHuh Please can you advise me of this. I know this is because I have enabled "use fullscreen window" but I must do this if I want the Kodi GUI to be correct format within my screen aspect ratio. Please see pictures below, this is what it looks like if I disable the "use fullscreen window" in Kodi .. It shows as D3D11 fullscreen (10bit) which is the correct format of the movie: https://i.imgur.com/W6LWZ81.jpg As I need Kodi GUI to be perfectly fit in my screen ratio, I select resolution as same as my desktop which is now 3840 x 1620p and enable "use fullscreen window" in Kodi for it to display correctly without any stretching happening. My question really is, is there a way to get madVR to play this as a 10bit file or is it no problem if it is displays as (8bit) on the madVR OSD? It's worth mentioning that I use the JVC masking in order to crop the top and bottom of the screen. the reason I do this is when watching movies with IMAX scenes (ie Interstellar, First Man, MI Fallout etc) I don't want the image to overshoot my screen. https://i.imgur.com/Ypy6DCQ.jpg https://i.imgur.com/wYebVVP.jpg https://i.imgur.com/SZDXQR0.jpg https://i.imgur.com/Mqoibkh.jpg Here are some of my Kodi Settings for reference to get the GUI to fill the screen: https://i.imgur.com/RXLfjTI.jpg https://i.imgur.com/7v5JUD0.jpg https://i.imgur.com/NhaDCMA.jpg Here is some pics of my desktop and GPU settings: https://i.imgur.com/RbXjQG4.jpg https://i.imgur.com/PkImZoD.jpg Just to re cap.. Here is what I need to know : 1 - The fact that is is showing (8bit) in the madVR OSD is this ok? If not then how can I please resolve this? 2 - Is my screen resolutions for desktop and Kodi correct and should I be enabling "use fullscreen window"? If I don't then my Kodi GUI doesn't sit in my 2.39 correctly it looks stretched. 3 - When I view a movie with the settings above it seems to be working ok resolution wise but shows as 3840 x 2160 -> 3840 x 1607 is this ok? 4 - Once I exit the Kodi and return to my Windows Desktop, for some reason my windows desktop selects itself to 3840 x 1620p but instead of 60 hz 8 bit it changes to 24hz 12 bit? Whats the reason for this please? Sorry for so many questions and the very long post but I really would appreciate if I can get this sorted please and guided if I am doing anything wrong.. Thank you so much and look forward to your help and advice Smile Forgot to post these for reference: https://i.imgur.com/nm4Dr5C.jpg https://i.imgur.com/cjTuCfs.jpg |
3rd March 2019, 11:11 | #55123 | Link | ||
I never said that the banding was generated by madVR, it clearly has to be generated by the GPU. Here it's a better option to set bit depth to 8bits in madVR if the GPU is set to 8bits, that way madVR dithers directly to 8bits and the GPU can't me$$ things up. It definitely does otherwise. Now of course if that causes issues with HDR switching, or if using 12bits in the GPU causes banding on the display, that's another question. I use pixel shader tonemapping so I have no issue with HDR switching in 8bits. And with bit depth set to 8bits in madVR, I get no banding on the JVC, the way I do if bit depth is set to 10bits or auto. Not sure what I would do if I couldn't use 12bits due to banding and if I needed HDR switching. But I have enough issues and bugs to work around, this is currently the best compromise in my setup, at least until JVC fixes the forced YCC422 in RGB 12bits on the new models. Quote:
More important would be for madVR to detect the bit depth set in the GPU so that auto would adjust automatically to that. At the moment auto is based on the display EDID, so if the display reports 10bits or more, that's what madVR sends, even if the driver is set to 8bits, which is neither correct nor optimal and can/does result in banding, at least here.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 3rd March 2019 at 11:19. |
3rd March 2019, 11:56 | #55124 | Link |
You cannot do that, since Direct3D has no 12-bit surface format, meaning that you cannot pass 12-bit data to the GPU. Its either 10-bit, or some weird unusual 16-bit format, so madVR always uses 10-bit if possible, or 8-bit if needed.
3rd March 2019, 13:27 | #55126 | Link | |
I just don't understand why nvidia is not offering 10bit output, at least they should listen to edid data
ZOTAC MAGNUS EN1060K: Win 10 x64 + Kodi DSPlayer x64 LG OLED65C8 / Denon AVR-X3200W / KEF E305+ONKYO SKH-410 / Synology DS2415+ / Logitech Harmony 950 |
3rd March 2019, 14:15 | #55127 | Link | ||
why do i get even back to this? if you get banding on a new device it should never be the GPU if it didn't do it before and everyone should get the same banding if this would be broken. first of all i know that nvidia was ignoring the 8 bit setting before and just used what ever they seems fit before. if this is again or still the case we may found the issue already. there is a simple way to test this to make this more clear (sadly still not 100%) you absolutely force nvidia to do 8 bit by using 60 hz UHD. if you want something to be fixed you should make as sure as possible what the reason is for that. to your report you get banding with 12 bit GPU output on the new JVC and banding when the GPU is supposed to dither to 8 bit but you get no banding if you output 8 bit directly. the dithering to 8 bit is an odd one here that shouldn't be there. Quote:
feel free to give me the exact settings you are using and i will check it yet again. |
3rd March 2019, 14:31 | #55128 | Link | |
Soul Seeker
Monitor is 2560x1080p. Any recommendations for image doubling or image upscaling will be appreciated. Last edited by Siso; 3rd March 2019 at 16:21. |
3rd March 2019, 17:14 | #55129 | Link | |
I couldn't use 8bits on my older JVC because of the magenta bug. It's a JVC/nVidia bug that was only at 4K60p initially, and with later drivers became an issue at all 4K refresh rates. So it's not as if there was no banding before in 8bits and there is now. You could get rid of the bug by not sending HDR metadata. I've never tested 8bits before, simply because I couldn't and I always used 12bits because of this magenta bug. Second I know that nVidia isn't ignoring the 8bits because there is a bug in the rs2000 that forces YCC422 in RGB 12bits. That's why I use 8bits. I don't get any banding in 12bits, I have no idea where you're getting that from. What I'm saying is that if you set the bit depth in the GPU to 8bits and set the bit depth in madVR to auto you get banding, because auto is based on the EDID of the display, not on the bit depth selected in the GPU. This banding is because the GPU is dithering to 8bits behind madVR's back. If I set the bit depth in madVR to 8bits, the banding goes away, because madVR dithers directly to the correct bit depth. I have no idea if you're seeing something different, and honestly I don't care. I have more than enough of these drivers issues and I'm seriously considering throwing my HTPC away, now that we're going to be about to get madVR's goodness on any source. I've just found out that what I thought was a bug in JVC's DI implementation is an issue that doesn't happen with a standalone player, but only with a HTPC. I'm still exploring this new issue instead of watching films. Frankly this is taking way too much of my time. I can't wait to leave all this behind. I really have had enough.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 3rd March 2019 at 17:38. |
3rd March 2019, 18:09 | #55130 | Link | |||||
the major difference in madVR dithering to other dithering algorithms isn't the banding it's the noise level. Quote:
you have a magenta problem on the old ones and the new ones have problems with 12 bit forcing "stuff". |
3rd March 2019, 18:23 | #55131 | Link | ||||
FYI I have an HD Fury Maestro, there is zero doubt about what's coming out of the GPU HDMI out and into the JVC. As in I know exactly the colourspace, bit depth and refresh rate of the content being sent, even when the JVC reports otherwise. For example, when the GPU sends YCC422 12bits instead of RGB 12bits, the JVC reports RGB 12bits. But if you select the colorspace manually in the JVC, you can see that it's YCC422, not RGB being sent. Quote:
Yes, I have a magenta problem in 8bits on the old one and an YCC422 forced in 12bits RGB on the new one. Please tell me something I don't know if you really have to say something It's taking me long enough to troubleshoot this without having to answer all your questions on top.
3rd March 2019, 18:38 | #55132 | Link |
419.17
FSE 10 bit GPU 8 bit= no banding FSE 10 bit GPU 12 bit= no banding WFS 10 bit GPU 8= heavy banding WFS 10 bit GPU 12 bit= banding and that's why i ask for the exact settings. this is a sample size of 1 i have one more PC i will test later. looks like windows or nvidia broke yet again WFS 10 bit. |
3rd March 2019, 20:09 | #55133 | Link |
It's weird how everyone's setup is different. That makes it even harder to troubleshoot. For me, there is no difference between WFS and FSE. I don't get banding either way with the GPU set to 8-bit output and madVR to either 8-bit or 10-bit/auto. The only time i get major banding is when I set the GPU to output 12-bit. By the way, "auto" in madVR seems to pick 8-bit or 10-bit randomly (for SDR content), according to the OSD. There is no consistency in my case, but the one thing that hasn't worked in quite a while is what I talked about yesterday: The switching into HDR mode when madVR is set to 8-bit. That's why I wanted to know if anyone had ever gotten the HDR flag to work in profiles. It would solve my one remaining issue
3rd March 2019, 20:25 | #55134 | Link | |
You're not giving enough information. I don't have banding in 8bits or in 12bits in WFS, provided the correct bit depth is selected in madVR. This is what I get here (419.17, but I'm reverting to 385.28): WFS 8bits GPU 8bits madVR 8bits= no banding WFS 10 bit GPU 12 bit madvr 10bits or more (or auto)= no banding WFS 10 bit GPU 8 bits madvr 10bits or more (or auto)= banding Anyway, I think everyone gets different results depending on the combination of GPU, driver, display and settings. That's why I concentrate on my issues, and told you you were correct that I shouldn't make blanket statements. The only thing I can do is report the issues I experience, and when I find a fix or workaround, share it.
3rd March 2019, 20:45 | #55135 | Link |
VBB,
In devices/your display/, create a profile group for PROPERTIES using this rule: If (deintFps <= 30) "10-bit" else "8-bit" Add a profile for PROPERTIES named 10-bit. Add another named 8-bit. For the 10-bit profile under 'the native display bitdepth is: - select 10 bit (or higher). For the 8-bit profile, select 8bit. I use older nVidia drivers. Never a problem going into HDR mode and both are set to 8 bit here. Follow this link and you'll see the screenshots I've listed - https://imgur.com/a/4h7U0#MruR8Lw
HOW TO-Kodi 2D-3D-UHD (4k) HDR Guide Internal & External Players W11 Pro 24H2 GTX960-4GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit KODI 22 MPC-HC/BE 82" Q90R Denon S720W Last edited by brazen1; 3rd March 2019 at 20:50. |
3rd March 2019, 21:04 | #55136 | Link |
this wouldn't the first time everyone with nvidia card got banding with WFS 10 bit. the banding with sending 10 bit is hard to see i don't expect many other user to see it the only reason i even think it has anything todo with the GPU/WDM is the fact is gone in FSE. i still have a problem understanding how a GPU could produce it at input 10 bit 12 bit output.
BTW. there is no need to act elitist here no one forces you to answer anything and no one can read your mind. not using FSE is not a small unimportant thing with the history by nvidia. known all 4 states(GPU driver, madVR OSD, HDfury and end device) for the signal is helping a lot. yes you know this stuff because you are sitting next to it i don't. i found a potential fix for your banding issue if you don't like it/can't use it well to bad but this should help other users at least. even the 8 bit banding is pretty hard to see on the 6 bit TN i'm testing right now. so if someone wants to test: http://www.bealecorner.org/red/test-...ient-16bit.png |
3rd March 2019, 21:09 | #55137 | Link | |
Maybe I didn't explain this right Ideally, I'd like to have the entire chain set to 8-bit. That's best case scenario with the OLEDs, but it's not doable at the moment, because madVR won't switch into HDR mode when it's set to 8-bit. As a workaround, I want to split DISPLAY -> PROPERTIES into two separate profiles, one for SDR using 8-bit, and one for HDR using 10-bit/auto. The only boolean I can see useful for this is "HDR", as in if (HDR) "HDR" else "SDR" but that does not work. madVR will always use the SDR profile.
3rd March 2019, 21:47 | #55138 | Link |
Sorry. I was thinking that you only want HDR to engage using 10 bit since they are all 10 bit.
SDR only for 8 bit but it appears not all SDR are only 8 bit - They are 10 bit also otherwise we could have differentiated. Disregard.
3rd March 2019, 21:53 | #55139 | Link |
Well, yes, that is essentially what I want, but I don't think your code would do that. It doesn't contain a trigger for bit rate detected, only for frame rate.
3rd March 2019, 22:00 | #55140 | Link |
Try "hdr" or "bitDepth."
