27th July 2020, 05:54 | #3921 | Link | |
I'm Siri
import vapoursynth as vs core = vs.get_core() Code:
from vapoursynth import core |
27th July 2020, 07:12 | #3922 | Link |
You can use this
from vapoursynth import core, YUV, GRAY OR use Code:
core = vs.core Code:
core = vs.get_core() whoops I was too slow
28th July 2020, 06:52 | #3924 | Link | |
Professional Code Monkey
QueryCompletedFrame is also half broken...
28th July 2020, 19:53 | #3925 | Link |
R51-RC2
Found a few more trivially fixable bugs when developing the glorious new branch. So here's another RC. If you have far too much time on your hands you could compare the speed and memory usage with R50. Changes Code:
r51: updated visual studio 2019 runtime version fixed a cache shrinking issue fixed a crash when removing a message handler without a free function fixed an extremely rare threading issue only affecting fmparallelrequests filters and arframeready events fixed compilation when avs+ master is used fixed lut and lut2 triggering a fatal error when invalid planes were specified fixed property append operations on non-empty keys not properly copying the underlying data fixed wave64 headers generated by avfs fixed crash in averageframes with odd number of clips (sekrit-twc) scale averageframes for integer chroma by distance from grey (sekrit-twc) several fixes and improvements regarding handling of the active script environment in python (stuxcrystal) plugin loading now has better error messages (jackoneill) using get_core() in python now generates a deprecation warning since it's been deprecated for years
29th July 2020, 14:03 | #3926 | Link | |
29th July 2020, 14:17 | #3927 | Link | |
You also don't need arFrameReady events unless your filter implementation is a monolithic monstrosity. Have a separate filter to do transfers to the GPU an one after processing to transfer back if needed. That's more or less how I'd handle GPU support if I ever officially added it anyway.
29th July 2020, 20:43 | #3928 | Link | ||
Purely academic as I agree it is not worth pursuing this for now:
29th July 2020, 22:44 | #3929 | Link |
CPUs with more cores have more memory channels and bandwidth too. Unless it's a crippled server cpu being sold to enthusiasts.
The current filter model of operating on whole frames is also very memory bandwidth inefficient. Adding support for filters that work per scanline/tile will allow for huge improvements since then L3 and L2 cache speed would be the limit and not ram. It's it's the curse of having a simple and developer friendly filter model. Writing two versions of filters, even the basic ones, is unsustainable for a project of this size. And I don't only mean in terms of development time but also the number of users that test things. It would most likely constantly end up broken.
29th July 2020, 23:07 | #3930 | Link | |
Cary Knoop
DaVinci Resolve uses this model, you can write a CUDA file with a given interface like so: Code:
__DEVICE__ float3 transform(int p_Width, int p_Height, int p_X, int p_Y, __TEXTURE__ p_TexR, __TEXTURE__ p_TexG, __TEXTURE__ p_TexB) { float3 x = make_float3(_tex2D(p_TexR, p_X, p_Y), _tex2D(p_TexG, p_X, p_Y), _tex2D(p_TexB, p_X, p_Y)); // Do something here with a 3-pixel: x.x += x.x + 0.1f; return x; } A more fancy extension would be to have a prior and next frame pointer as well. Last edited by Cary Knoop; 29th July 2020 at 23:14. |
29th July 2020, 23:13 | #3931 | Link |
Achooo
I'm allergic to proprietary crap
29th July 2020, 23:15 | #3932 | Link |
Cary Knoop
Then use OpenCL.
I think having such an interface would be a great addition to Vapoursynth. And once you have the inferface spec one could write other adapters like for CUDA or other GPU languages. Last edited by Cary Knoop; 29th July 2020 at 23:17. |
31st July 2020, 00:20 | #3933 | Link | |
(Until then maybe vsFilterScript will get there first.) Last edited by HuBandiT; 31st July 2020 at 00:24. |
31st July 2020, 12:46 | #3934 | Link |
VapourSynth is not mentioned in the Wikipedia Frameserver article. I don't have much time and Wikipedia experience.
31st July 2020, 19:45 | #3935 | Link |
I'm Siri
vsFilterScript is now ready for general purpose use, and ready to retire vsxx as the modern vs C++ api wrapper.
it has successfully achieved zero cost abstraction, the test filter runs even faster than the corresponding core filter bundled with vaporsynth. and it comes with much prettier syntax and higher level of abstraction FOR FREE! Last edited by feisty2; 31st July 2020 at 19:52. |
1st August 2020, 22:29 | #3936 | Link |
R51 released!
Not that exciting. Get ready for the considerably more exciting audio and api development builds soon.
1st August 2020, 23:29 | #3937 | Link | |
Will there be source filters for audio available when the core gets audio support?
(i have a tendency to drunk post) |
2nd August 2020, 14:32 | #3938 | Link | |
I encourage the the curious among you to take a look at the audio test builds.
7th August 2020, 00:47 | #3939 | Link |
I have problem setting the color of blankclip referenced from a YUV444P16 clip.
clip_yuv16 = core.resize.Bicubic(clip, format=vs.YUV444P16) color_clip = core.std.BlankClip(clip_yuv16, color=[0, 0, 220]) color_clip.set_output() |
7th August 2020, 01:07 | #3940 | Link | |
