13th April 2020, 08:33 | #7521 | Link | |
EDIT: Here is a link to version 3.3+15 (multilib exe). This version is the last one without implementation of the abrEncApp. Please test if there are any problems with encoding. Last edited by Patman; 13th April 2020 at 10:39. |
13th April 2020, 15:34 | #7522 | Link | |
Ryzen 7 3700X GTX1660S Ryzen 7 5800X RTX2060S |
14th April 2020, 05:31 | #7524 | Link | |
15th April 2020, 15:17 | #7526 | Link |
Is it possible to customize --total-frames to show total-frames=0 ? I'm asking as I've seen some mediainfo's containing such information and wanted to know if there's some other vodoo than typing --total-frames 0 or simply --total-frames as these gets the encoder to stop altogether.
The documentation says almost nothing on this https://x265.readthedocs.io/en/lates...doption-uhd-bd (and scroll down a notch or two). I'm also asking as I heavily use film.trim() so it looks odd seeing only a certain number of frames in mediainfo when the total frames are much larger after appending the files. Thanks if someone answers it unlike my prior post above where it was completely ignored. |
16th April 2020, 06:58 | #7528 | Link | |
I've asked the mkvmerge creator and said this is a non-issue and won't affect video playback several versions ago. I just wanna know these guys are getting total-frames to read 0. Must be some trick I do not know. Likewise when they somehow cut out encoding settings altogether too but I don't really care about that one. Not sure what you mean by headers. I am also using HEVC through MeGUI's one click (and its command line) if that helps. Last edited by dREV; 16th April 2020 at 07:01. Reason: stuff |
16th April 2020, 19:14 | #7530 | Link | |
EDIT: Here is the link, version x265-3.3+19-..._patched contains with the changes. Pls give me feedback on this version. Last edited by Patman; 16th April 2020 at 19:55. |
16th April 2020, 19:53 | #7531 | Link | |
SuperVirus
https://www.mediafire.com/folder/arv5xmdqyiczc I will test the binary A.S.A.P. |
16th April 2020, 19:56 | #7532 | Link | |
EDIT: I tested this binary and it doesn't work (for me). The encoding process hangs at startup ... Last edited by Patman; 16th April 2020 at 21:17. |
16th April 2020, 23:43 | #7533 | Link | |
SuperVirus
avs2yuv hc500.avs -o -|z265 --input - --y4m --output C:\hp\test.hevc --crf 22 --no-sao --subme 3 --no-open-gop --keyint 150 --min-keyint 1 --ctu 32 hc500.avs: 1280x720, YV12, 8-bits, progressive, 30 fps, 4064 frames y4m [info]: 1280x720 fps 30/1 i420p8 unknown frame count raw [info]: output file: C:\hp\test.hevc x265 [info]: HEVC encoder version 3.3+19-gcaf9d4dbe x265 [info]: build info [Windows][GCC 10.0.1][64 bit] 8bit+10bit+12bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.1 Cache64 x265 [info]: Main profile, Level-3.1 (Main tier) x265 [info]: Thread pool created using 4 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 2 / wpp(23 rows) x265 [info]: Coding QT: max CU size, min CU size : 32 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : hex / 57 / 3 / 3 x265 [info]: Keyframe min / max / scenecut / bias : 1 / 150 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 3 / off / on x265 [info]: AQ: mode / str / qg-size / cu-tree : 2 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-22.0 / 0.60 x265 [info]: tools: rd=3 psy-rd=2.00 early-skip rskip mode=1 signhide tmvp x265 [info]: tools: b-intra strong-intra-smoothing lslices=4 deblock ^C^C |
18th April 2020, 16:11 | #7538 | Link | |
Edited: I got some strange output when the encoding almost done Last edited by tuanden0; 19th April 2020 at 05:26. |
19th April 2020, 09:15 | #7539 | Link |
Can you post your command line? These are my results...
Avisynth Code:
D:\StaxRip\Apps\Support\avs2pipemod\avs2pipemod64.exe -y4mp "G:\Movie\x264\test\Sonic The Hedgehog Trailer_temp\Sonic The Hedgehog Trailer_new.avs" | D:\StaxRip\Apps\Encoders\x265\x265.exe --crf 18 --profile main10 --output-depth 10 --frames 4115 --y4m --output "G:\Movie\x264\test\Sonic The Hedgehog Trailer_temp\Sonic The Hedgehog Trailer_new_out.hevc" - avs2pipemod[info]: writing 4115 frames of 24000/1001 fps, 720x304, sar 0:0, YUV-420-planar-8bit progressive video. y4m [info]: 720x304 fps 24000/1001 i420p8 unknown frame count raw [info]: output file: G:\Movie\x264\test\Sonic The Hedgehog Trailer_temp\Sonic The Hedgehog Trailer_new_out.hevc x265 [info]: HEVC encoder version 3.3+19-gcaf9d4dbe x265 [info]: build info [Windows][GCC 10.0.1][64 bit] 10bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x265 [info]: Main 10 profile, Level-2.1 (Main tier) x265 [info]: Thread pool created using 16 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 4 / wpp(5 rows) x265 [warning]: Source height < 720p; disabling lookahead-slices x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 3 x265 [info]: Keyframe min / max / scenecut / bias : 23 / 250 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 3 / off / on x265 [info]: AQ: mode / str / qg-size / cu-tree : 2 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-18.0 / 0.60 x265 [info]: tools: rd=3 psy-rd=2.00 early-skip rskip mode=1 signhide tmvp x265 [info]: tools: b-intra strong-intra-smoothing deblock sao avs2pipemod[info]: finished, wrote 4115 frames [100%]. avs2pipemod[info]: total elapsed time is 44.602 sec. x265 [info]: frame I: 153, Avg QP:16.30 kb/s: 4090.80 x265 [info]: frame P: 1226, Avg QP:19.30 kb/s: 1643.85 x265 [info]: frame B: 2736, Avg QP:23.93 kb/s: 545.73 x265 [info]: Weighted P-Frames: Y:2.9% UV:2.3% x265 [info]: consecutive B-frames: 29.7% 8.7% 16.5% 23.8% 21.3% encoded 4115 frames in 46.71s (88.09 fps), 1004.71 kb/s, Avg QP:22.27 Code:
"C:\Program Files\VapourSynth\core\vspipe.exe" "G:\Movie\x264\test\Sonic The Hedgehog Trailer_temp\Sonic The Hedgehog Trailer_new.vpy" - --y4m | D:\StaxRip\Apps\Encoders\x265\x265.exe --crf 18 --profile main10 --output-depth 10 --frames 4115 --y4m --output "G:\Movie\x264\test\Sonic The Hedgehog Trailer_temp\Sonic The Hedgehog Trailer_new_out.hevc" - y4m [info]: 720x304 fps 24000/1001 i420p8 unknown frame count raw [info]: output file: G:\Movie\x264\test\Sonic The Hedgehog Trailer_temp\Sonic The Hedgehog Trailer_new_out.hevc x265 [info]: HEVC encoder version 3.3+19-gcaf9d4dbe x265 [info]: build info [Windows][GCC 10.0.1][64 bit] 10bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x265 [info]: Main 10 profile, Level-2.1 (Main tier) x265 [info]: Thread pool created using 16 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 4 / wpp(5 rows) x265 [warning]: Source height < 720p; disabling lookahead-slices x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 3 x265 [info]: Keyframe min / max / scenecut / bias : 23 / 250 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 3 / off / on x265 [info]: AQ: mode / str / qg-size / cu-tree : 2 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-18.0 / 0.60 x265 [info]: tools: rd=3 psy-rd=2.00 early-skip rskip mode=1 signhide tmvp x265 [info]: tools: b-intra strong-intra-smoothing deblock sao Output 4115 frames in 45.41 seconds (90.61 fps) x265 [info]: frame I: 154, Avg QP:16.33 kb/s: 4051.93 x265 [info]: frame P: 1218, Avg QP:19.31 kb/s: 1646.53 x265 [info]: frame B: 2743, Avg QP:23.93 kb/s: 547.57 x265 [info]: Weighted P-Frames: Y:3.3% UV:2.5% x265 [info]: consecutive B-frames: 28.6% 9.4% 16.9% 23.5% 21.6% encoded 4115 frames in 47.49s (86.66 fps), 1004.00 kb/s, Avg QP:22.28 |
