25th January 2007, 08:27 | #321 | Link | |
Xvid Tribalistic Fan
I've compared colors of the mpeg2source and avisource with converttorgb and definetly the encodes with colormatrix had better color matching. Maybe it could be a mistake of my eyes. All the best, Sharro |
1st February 2007, 23:36 | #322 | Link |
If the source is not bt709 you will get wrong colors with colormatrix of course.
I actually noticed the wrong colors myself a few years back and happiliy found colormatrix what got the solution to this problem. That was before autogk or megui were using them as standard. |
13th August 2008, 17:38 | #325 | Link | |
Well just as there is no 'best' there is not really a cqm that will work right with everything, for everybody, because what I think looks good others will not. But so far I have found that, again, this is for me (I like a sharper picture and always used mpeg over H.263) I have been very impressed with the "EQM - AutoGK sharp.xcm" cqm and so far (over 100 encodes) its working right every time and has yet to have a problem with any SAP (nothing below 16 in the inter-matrix). But I would also do as Ranguvar says and at least try "EQM V3LR, MPEG, and possibly EQM V3HR" as well because they are top quality cqm's.
EncodingBox DFI-LP RDX200 CF-DR AMD4200x2 @2.5GHz 2GB G.Skill HZ's x1650XT Corsair HX620 Eclipse62 LG GSA-H42N Lite0n SHM-165P6S Asus CRW-5232A Optiarc AD-5170A Sony e500's & Ducky 1087 via KVM |
14th August 2008, 13:59 | #329 | Link | |
14th August 2008, 14:09 | #330 | Link |
Mr. Sandman
consider VAQ as a sort of "adaprive CQM" that even works on standalones.
If i have to choose between encoding with a CQM or encoding with VAQ, ill go for VAQ first. If and only if im not satisfied then i would use a CQM.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! |
17th August 2008, 12:30 | #331 | Link | |
Also i am using Xvid 1.1.2 [xvidcore.dll] Koepis Vanilla CVS Build , Nov 1 2006 specifically.
Knowledge is the Greatest Power. Share It. Let others also feel it. - ViDeO MaStEr |
17th August 2008, 13:35 | #332 | Link |
Mr. Sandman
xvid 1.1.2 AQ is not VAQ... and it sux...
30th July 2010, 17:54 | #335 | Link |
Ex-ter-mi-nate!
EQM v3 HR preserves detail pretty well (and works OK with VAQ). Qpel can help a lot as well (if our target player supports it). It's the resizing from 1920x1080 to 720xXXX that will cause a significant loss of detail (of course we have no other choice if we want to play our encodes on “DivX Home Theater” certified players).
30th July 2010, 22:43 | #336 | Link |
Read the sticky
Here you have a thread with compressibility tests using different CQMs and Jawor made a useful comment on compatibility here. The higher bitrate matrices keep more details, but they also need more bitrate. edit: lol, the post with the question I was commenting to disappeared. Last edited by elguaxo; 31st July 2010 at 11:44. |
30th July 2010, 23:10 | #337 | Link |
Ex-ter-mi-nate!
About the min=16 requirement for the INTER part... If you change the 15s to 16s in “EQM v3 HR”, the quality difference won't be really noticeable (I tried this ). MediaTek-based players may require such a change. My Philips DVP3142/12 (Zoran Vaddis 966 chipset) plays every custom matrix I can throw at it. Very old players (e.g. based on the ESS Vibratto chipset) probably won't play any of the “MPEG-Custom” matrices.
21st September 2010, 15:37 | #338 | Link | |
It's ok to use a custom matrix and VAQ at the same time? And how do i use VAQ in xvid_encraw? |
22nd September 2010, 01:13 | #339 | Link |
Mr. Sandman
not all quant matrices are VAQ friendly.
test them on a short clip and see if they're behaving correctly.
