7th October 2011, 00:34 | #441 | Link |
Software Developer
"Peak Level" == "-ne", "RMS Level" == "-nb", "None" == "-n"
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 7th October 2011 at 00:47. |
7th October 2011, 01:23 | #442 | Link |
thanks a lot...
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note... Visit The Land Of Dracula (Romania - EU)! |
10th October 2011, 12:50 | #443 | Link |
HeDoporo
ugly visual bug in latest stable release http://www.youtube.com/watch?v=_aYfZjy0YFs
how i can turn off this useless visual effects? i think previous interface in 3.18 was much better |
10th October 2011, 13:47 | #444 | Link | |
Software Developer
So, if necessary, the window width will be increased step-by-step, until all strings fit in... (And nope, I can't increase the initial window width. This would only mislead the translators to use even longer strings ^^) But feel free to suggest a better/shorter translation. Translation fixes always are welcome! The "old" interface was built with Delphi 7.0 and didn't even support Unicode characters The "new" Qt-based interface is MUCH advanced...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 11th October 2011 at 01:09. |
14th October 2011, 20:45 | #445 | Link | |
Software Developer
LameXP v4.03 Beta-4:
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 16th October 2011 at 19:01. |
16th October 2011, 19:39 | #446 | Link | |
Software Developer
LameXP v4.03 Beta-5:
If you already have Beta-4 installed on your computer, then Auto Update won't work and you have to download/install the new version manually this time! Sorry for any inconvenience...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 18th October 2011 at 19:27. |
17th October 2011, 20:35 | #447 | Link |
Do you happen to know if the aac or mp3 encoder dithers the output when input is for example 32 bit float wav? I didn't see anything related in the neroaacend cli help
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
17th October 2011, 20:42 | #448 | Link | |
Software Developer
There was a lengthy discussion on whether audio decoders should output floating-point here: http://forum.doom9.org/showthread.php?t=156966
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 17th October 2011 at 20:47. |
17th October 2011, 20:46 | #449 | Link |
wav decoder...Im reading here and here and it seems the encoders just don't care and "truncate" the signal. Maybe you could add dithering in the wav decoder?
Reading a bit more it seems they could probably dither, but doing it or not is not a critical issue.... : /
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 17th October 2011 at 20:50. |
17th October 2011, 20:53 | #450 | Link |
Software Developer
I'm not exactly sure what you mean with "wav decoder", because (uncompressed) Wave files don't need any decoder.
And how are the MP3 or AAC encoders related to decoding
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 17th October 2011 at 21:08. |
17th October 2011, 21:16 | #451 | Link |
sorry I didn't think mp3 or aac used already 32bit fp.
18th October 2011, 17:06 | #452 | Link |
Using 4.03 beta 5, am I correct in saying the the debug console not be disabled? It would appear it cannot.
(This is the first time I installed a LameXP beta version). Also, is there a new stable version around the corner? |
18th October 2011, 17:31 | #453 | Link | |
Software Developer
http://lamexp.git.sourceforge.net/gi...=HEAD#900a2a6c Yes, soon. It will contain the LAME 3.99 final release.
18th October 2011, 19:23 | #455 | Link | |
Software Developer
LameXP v4.03 Beta-6:
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 24th October 2011 at 01:40. |
23rd October 2011, 18:36 | #456 | Link | |
Software Developer
LameXP v4.03 RC-1:
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 24th October 2011 at 01:41. |
23rd October 2011, 21:22 | #457 | Link |
it has the same bug that I've previously reported:
if "Prepend relative source file path to output file" in "Output Directory" tab is checked, it still remains active (but greyed) even when "Save output files to the same location where the input file is located" is checked. -feature request to avoid intense (and slow) hd activity, as the size of an intermediate raw files can be easily calculated previously (duration_in_seconds * frequency * bitdepth * channels), it should be possible, if the free RAM size is greater than the above + an offset, use a ram file for the raw intermediate. edit I mean "phisical ram" Last edited by Motenai Yoda; 23rd October 2011 at 21:27. |
23rd October 2011, 21:57 | #458 | Link | ||
Software Developer
Well, that's not the whole truth. It is possible to pass data from one process to another one directly in the memory - by using a pipe. Or more specifically: By having the first process write the data to STDOUT and having the second process read the data from STDIN. But this has other problems: For example, the second process can not determine the size of the input until it has read/processed everything, because seeking is not possible when reading from a pipe. Also not all tools used in LameXP do support reading/writing from/to STDOUT/STDIN. Last but not least, implementing the usage of pipes (at least for the tools that do support it) would require fundamental changes in the architecture of LameXP. For example, decoding and encoding would then happen in parallel, rather than doing it in two separate steps... Anyway, what you can do already: Create a "RAM Disk" and move LameXP's Temp directory to that RAM Disk.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 23rd October 2011 at 22:13. |
23rd October 2011, 23:06 | #459 | Link | ||
if u process a file in "C:\lord_mulder\work" the output file is placed in "C:\lord_mulder\work\lord_mulder\work" I've posted a video at the time. http://forum.doom9.org/showthread.ph...49#post1523849 imho or is grayed/disabled/unapplied or is active/applied. Quote:
23rd October 2011, 23:13 | #460 | Link | |
Software Developer
Sorry, I did not get your point before. But the example made it clear now. Thank you for the report, I will fix this ASAP.
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis |
