10th October 2019, 13:58 | #17441 | Link |
Your file has not been correctly encoded. Most likely there is still audio related with advertisements. You need to manually cut out those left overs.
10th October 2019, 14:01 | #17442 | Link | |
10th October 2019, 16:33 | #17443 | Link | |
ByteShare
10th October 2019, 17:26 | #17444 | Link | |
ByteShare
example: Code:
MOVE "%INPUTFILEDIR%\%INPUTFILENAME%.mkv" "C:\done\%INPUTFILENAME%.mkv" Would it be possible for the next job to start but not delete the job folder until after the script runs? Or is there a good way to automatically remove a job via the bat file, and by not just deleting the %Job% folder? |
10th October 2019, 17:42 | #17445 | Link | |
10th October 2019, 19:56 | #17446 | Link |
After yesterdays Windows Update for 7, I get an error
List index out of bounds (130) It's not the app, I unzipped and updated the files in the first post, same thing
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
10th October 2019, 21:56 | #17449 | Link |
Delete job.list file
11th October 2019, 05:20 | #17450 | Link | |
ByteShare
Is your Temp drive for RipBot an SSD? I use a physical drive for storing my sources and an SSD for the Temp drive (jobs) and adding new jobs isn't that slow for me on the latest version. |
11th October 2019, 07:56 | #17451 | Link | |
Grumpy Old Man.
It was John Wick 3, @ approx 65 Gb. And yes, I am yet to complete my "muxing" test, that will be in a few days, will be interesting if SSD's make much difference to large files.
11th October 2019, 08:22 | #17452 | Link |
I do not get IT. Are you encoding 60gib movie to 60gib file? In your earlier post you mentioned that muxing takes long time because your final encoded file was 60-80gib.
11th October 2019, 08:54 | #17453 | Link | |
Grumpy Old Man.
I simply want to strip stuff out, redo audio, as most 4K movies are TrueHD, and my tv doesn't support that. So I have to convert it either with RB, or eac3to. Also some filtering, subtitling, etc, if required. So I am aiming to do the majority of the 4K movies I have @ a 60Mb/s bitrate, that will increase some, and decrease others. So I do things differently to most...so what !!!!
11th October 2019, 12:28 | #17454 | Link | |
So you want to do more than just remultiplexing.
This possibly requires recoding the video (especially if "subtitling" means permanently encoding = "burning" subtitles into the video stream). That will take a lot of time in 4K resolution. |
11th October 2019, 12:57 | #17455 | Link | |
Grumpy Old Man.
Unfortunately, RB can't convert TrueHD to DTS, or subtitles to .srt Once the audio & sub's have been converted, and RB has done it's thing on the video (only), will reconstruct it all back together with MKVToolnix. Admittedly, if I left the original bitrate, then the process would be a little different.. A LOT of work, but that's what I want.
11th October 2019, 14:08 | #17458 | Link | |
11th October 2019, 14:26 | #17460 | Link | |
Grumpy Old Man.
Not trying to compress !!, mind you, I really haven't looked into that, too much.
