19th September 2020, 16:33 | #361 | Link | |
INI file settings AVSMeter checks if a settings file ("AVSMeter.ini" / "AVSMeter64.ini") exists in the directory from where it is started. If not, it will be created with the default settings. Note: If applicable, command line switches override INI settings. Supported settings for the INI file (default values in red): ... "PauseBeforeExit" (0 or 1): If set to "1", pauses the program at the end and returns to the console prompt only after pressing "ESC". ...
Groucho's Avisynth Stuff Last edited by Groucho2004; 19th September 2020 at 16:51. |
14th October 2020, 10:00 | #366 | Link |
32 bit AvsPmod needs a 32 bit avisynth.dll
64 bit AvsPmod needs a 64 bit avisynth.dll Are you sure you have the correct combination available? Also make sure you don't have any stray copy of the avisynth.dll in any other directory when you have AviSynth+ installed in your system. And you may also need to have the proper Visual C++ runtimes installed. |
14th October 2020, 10:01 | #367 | Link |
since bookmarks now kinda base on tabs (Except synced one) I think it's better to add new (Clear all bookmarks) for selected tab(s) only, and/or maybe rename the current one to "Clear all bookmarks Globally"
also don't know if it bug or is it fixed or not but in avspmod 2.6.3.9 sometimes when I save some bookmark by ctrl + b and then close avspmod I note it wasn't saved (or removed) @szabi it work fine here
See My Avisynth Stuff |
14th October 2020, 23:26 | #368 | Link | ||
When you change tab, the current bookmarks are saved as a backup in the script variable so that they can be restored when you select the tab again. That means if I delete the tab bookmarks they are deleted but not deleted because they also exist globally. And when you switch tabs, they are saved again because they still exist global. And even worse, until the tab is not changed, the tab bookmarks don't even exist. Except, bookmarks were read from the script or read from the session file. Quote:
I assume that this could also possibly be the problem of not saving in the session file, as I said if the tab is not changed there are no tab bookmarks. But if I remember correctly, I was paying attention to this problem. I will look at both.
Live and let live |
15th October 2020, 21:30 | #369 | Link |
If someone feels like it, they can test the new version before I release it tomorrow or the day after tomorrow.
'Clear tab bookmarks' and saving the bookmarks in the session file should now work. 64bit version only. Exchange the library.zip in the lib folder https://www.sendspace.com/file/h6nu28 Code:
* New item in Bookmarks menu 'Clear tab bookmarks' clears only the current tab bookmarks (idea by real.finder) -- is disabled if tab context menu option 'Tab change loads bookmarks' is disabled * 'Clear all bookmarks' renamed to 'Clear all bookmarks Globally' * Fixed zoom option 'fill window' * Fixed current tab bookmarks not always saved in session file
Live and let live Last edited by gispos; 15th October 2020 at 21:34. |
16th October 2020, 06:59 | #370 | Link | |
18th October 2020, 10:11 | #372 | Link | |
I installed on a different PC and working now. I have to figure out the reason for the other PC which has the issue. I will check on steps you guide me. Thanks. Regards Szabi |
26th October 2020, 05:29 | #373 | Link |
Hi gispos
I asked about this before, but it will be nice if tabs in avsp used separate process (Multi-processing like chrome and firefox or even similar to how MP_Pipeline work) since it's annoying when if one tab crash the whole avsp crash and all work lost! aside from the possibility of making one avsp for both avs x86 and x64 and switch between them anytime from tab setting
26th October 2020, 09:49 | #375 | Link | |
ffms2 (64) some filter in 32 another one in 64 and the other in 32 and fun fact, I used to use AvsPmod 32 with avs 64 using MP_Pipeline before AvsPmod get 64 build
26th October 2020, 19:00 | #376 | Link | ||
Use the paranoia mode. 'Options > Save\Load > ' Backup session when previewing' then the session will be saved before the preview (if the script was changed). For me it is switched on. A real multithreading application is one of the most demanding things you can write and that has to be planned from the start. With the already considerable amount of code and functions of AvsPmod, the subsequent implementation is a mammoth task or even impossible. With Delphi I have already written a few applications that use multiple threads, with Python I have zero experience with it ... so it doesn't work. Quote:
MP_Pipeline is not a single application, two processes are started 64bit and 32bit that comonicate with each other and finally a memory address is passed to avisynth, the clip. I don't see any possibility to do this with python for one application. Even just accessing the 64bit avisynth.dll requires some effort in code preparation under python and differs enormously from the 32bit version. I would be happy if Ferenc would write something about it. I'll play around with a few things that occurred to me about the program crash. I can't promise more. Sorry.
Live and let live |
26th October 2020, 20:05 | #377 | Link |
This test program uses a separate thread for each tab when loading.
The title bar shows how many loading threads are currently active. I started the project a year ago and then gave up! Avisynth Plus has problems with 'Eval' and AnsiStrings. As soon as MCTemporalDenoise is present in the script, I get error messages. I can only load scripts internally with AviSource. I wanted to put Ferenc on it , but he has enough other things to do. real.finder You like to test. Is it the same for you with MCTemporalDenoise() ? Open a few scripts at once and switch through the tabs and click into the video window with each tab change so that the script is loaded. Ignore the 'Test' menu I am interested in the errors with MCTemporalDenoise() Thanks. https://www.sendspace.com/file/190u6y
Live and let live |
26th October 2020, 20:26 | #378 | Link | |
colorbars converttoyv12 MCTemporalDenoise
27th October 2020, 01:08 | #379 | Link | |
aside from that, I feel that your test program is faster (whether in response, operation or starting) than avsp, is it because python that slow or is it because it's kinda not complicated with features/options yet? and if it approved, will it has all features/options of avspmod? and what about avsp py macros support or replacement in it?
