Old 26th August 2009, 17:05   #5581  |  Link
Does this happen with all files? (avi,mp4 and so on)
Old 26th August 2009, 23:17   #5582  |  Link
stryker412
@stryker412
Import original blu-ray structure in ripbot264 without using tsmuxer. Just select any .m2ts.
Thanks got it, one last question. I had to use another program to embed forced subtitles into the video. I have a 1080p mkv of that movie, can I use ripbot to resize that file down to 720p without losing chapters?
stryker412 is offline   Reply With Quote
Old 26th August 2009, 23:20   #5583  |  Link
yes. if original mkv has chapters. chapters are automatically extracted and imported into new mkv.
Old 27th August 2009, 01:26   #5584  |  Link
stryker412
I loaded up the BD so I could encode it down to 720p. However, when I hit encode there is no info at the bottom of the ripbot screen saying what % it's at. It's completely blank. I don't remember it doing this on other encodes. I checked my CPU usage and it's 50% so it appears ripbot is going, and the temp folder has all the files in it. I just have no display to see how it's going.
Edit: Looks like I have the same issue as Ken does. x264_x86.exe is only using 620k of memory but 50% CPU.
Originally Posted by kenwheeler77 View Post
ripbot264 v1.14.3 hangs on x264_x86.exe
Earlier post I had submitted I was running Win7 RC. Now running Win7 RTM
I have a fresh install of Windows 7 RTM, Core 2 Quad, 2 GB Ram and plenty of drive. I am trying to convert .m2ts files to stream to my ps3. I was having no problems on my Vista box (but haven't tried v1.14.3 from Vista) with these video sources (blu-ray .m2ts files). The issue I'm now having is this:
It gets through the "Encoding Audio" but seems to get stuck on the "Please Wait - Initializing". I can leave it for over 24 hours and it stays stuck on this.
I show a process by the name of x264_x86.exe using 25% CPU and 700k RAM. Nothing shows up in the Ripbot Logs folder.
Any ideas to get me going in the right direction would be greatly appreciated. I've had no problems in the past using Ripbot and I love the program. Great job with the coding!
I've installed ffdshow_rev3052
Thank you,
Ken
Old 27th August 2009, 10:24   #5585  |  Link
replace old x264_x86.exe with new one http://jeeb.fiveforty.jp/x264/1235/x264.exe
Old 27th August 2009, 12:32   #5586  |  Link
iSeries
Have a bit of an issue, trying to re-encode 'Cloverfield' blu ray to 480x272 with the PSP profile. It whizzes through the encode at something silly like 500fps and then gives me an MP4 which is only something like 8 minutes long. If I don't resize and use the Blu Ray profile it correctly re-encodes.
Anyone got any idea what is causing this?
Old 27th August 2009, 12:45   #5587  |  Link
Uninstall AviSynth , Haali Media Spliter , FFdshow. Update manually x264_x86.exe and x264_x64.exe
I hope this helps.
Old 27th August 2009, 22:05   #5588  |  Link
hoju3508
BDSup2Sub
@Atak,
I was curious of the command that you use when running BDSup2Sub. I have a BD that's 24fps instead of 23.976fps and the subtitle is out of sync.
I manually ran the following from the cmd shell:
% java -jar BDSup2Sub.jar 4_Subtitles_English.sup 4_Subtitles_English_1080.sup /res:1080 /fps:keep
Now, the sup file is 24fps instead of 23.976fps. I was curious if you passed other options.
-Hoju
Old 28th August 2009, 01:00   #5589  |  Link
BDFreak
RipBot264 Setting?
Hey, i would like to know what setting is more good? Im ripping right now at 1080p (HD full) and with QC - 20. It gives me about 10-15gig each movies. Its big but i dont really want to loose quality. Can i go 22? Or you could see the diference? I have a 48inch Plasma TV. And is QC better than 2 pass method? I know with QC i cant make the output size. So im gessing thats better right?
PS: and all the other programmes, like ffdshow, haali media splitter, do i need to change some of these settings? Or its all good if i keep it like it is?
Hope you guys can help Cya!
ohh yeah.. I use MKV for file format, and also 640kbps (the better one).
BDFreak is offline   Reply With Quote
Old 28th August 2009, 03:44   #5590  |  Link
gr1mmj0w
Hello gents, Have anyone had any issues with subtitles not working with BD rips? I would rip the whole movie, when I use ripbot to specify what subtitle I want it accepts it.
But when I actually finish the movie, there is no subs? any ideas?
gr1mmj0w is offline   Reply With Quote
Old 28th August 2009, 15:30   #5591  |  Link
hoju3508
In your job[n] folder do you see the .sup files?
Old 28th August 2009, 18:16   #5592  |  Link
prettyboy85712
Be more specific. Where are you selecting the subtitle. Hint: selecting the subtitle for the demuxing process doesn't automatically add it to the encode.
prettyboy85712 is offline   Reply With Quote
Old 28th August 2009, 21:38   #5593  |  Link
gr1mmj0w
I'll check when I get home.
for the demuxing process I would pick the subtitle but on the main encoding screen (ie. where you pick bitrate, name, audio,video) there is a small area to add subtitles.
I add it there also and still nothing.
Old 28th August 2009, 22:50   #5594  |  Link
stryker412
I'm having issues with downrezzing a 1080p mkv to 720p. The video is fine but no matter what setting I use for audio delay it always goes off. Any suggestions?
Old 28th August 2009, 23:30   #5595  |  Link
delay is constant?
Old 28th August 2009, 23:32   #5596  |  Link
kenwheeler77
x264_x86 not working in Windows 7
You are da man! It is now working great! Ripbot no longer stalls on Windows 7
I was wondering that was the issue but when I tried to follow a previous post to the "latest x264" thread, I was lost in a sea of patch definitions and updates.
Thank you very much for providing a link to this file.
Ken
kenwheeler77 is offline   Reply With Quote
Old 29th August 2009, 00:08   #5597  |  Link
cconnell
Two questions. First thanks for Ripbot. When creating a mkv I do not have the Copy Stream option for a HD-DVD. Is this possible? Does Ripbot support TrueHD in a mkv? My next question is why does Ripbot only have a 4.0 profile not a 4.1 profile? Thanks in advance.
cconnell is offline   Reply With Quote
Old 29th August 2009, 00:47   #5598  |  Link
JimmyFace
I had the same issue. Wouldn't show up and no players could display it even though it appeared to be added when viewing the encoded video file with mediainfo. When trying to add the sub with build in picture, ripbot would just hang after the encoding was finished, freezing on "muxing".
JimmyFace is offline   Reply With Quote
Old 29th August 2009, 01:03   #5599  |  Link
prettyboy85712
You can edit the profiles and make your own.
Old 29th August 2009, 01:28   #5600  |  Link
cconnell
Okay I did some more research. The only difference between 4.0 and 4.1 is bitrate. The author of RipBot feels strongly that there is no reason to go to 4.1. What does the bitrate mean in terms of quality? If there is no difference why does the standard exist? Thanks.
