28th May 2018, 04:41 | #15841 | Link |
Is there anyway to get BD Rebuilder and RipBot to exist together? Once I run RipBot it installs some sort of modified version of AviSynth and the only way to get BD Rebuilder to work is uninstall all my AviSynth's and reinstall normal AviSynth.
28th May 2018, 09:59 | #15843 | Link |
Maybe it is time to convince BD Rebuilder author to finally switch to AviSynth+ MT x64.
28th May 2018, 16:36 | #15844 | Link | |
ByteShare
30th May 2018, 12:42 | #15846 | Link |
Normalize ON = 100%
30th May 2018, 17:27 | #15848 | Link |
ByteShare
HEVC Stable was bumb'd to 2.8+9
http://msystem.waw.pl/x265/ |
31st May 2018, 01:50 | #15849 | Link |
DVD Rip displaying in 3:2 vs 4:3
Atak,
Got a quick question. I have been converting some DVDs that are 720x480. The original source is 4:3, but for some reason after conversion, they are coming out 3:2 -- and on playback, are slightly stretched. I've tried 2 different options -- one without resize, and one resizing to NTSC SD -- and both give the same 3:2 result. Is there any way to keep the 720x480 but have it display as 4:3? I've tried to force it using MVKToolNix, but it doesn't seem to take. |
31st May 2018, 07:41 | #15850 | Link | |
31st May 2018, 16:38 | #15851 | Link | |
ByteShare
You can even use a batch file to edit the MKV info without remuxing the whole file. |
1st June 2018, 13:35 | #15852 | Link | |
ByteShare
2nd June 2018, 18:37 | #15853 | Link | |
Found this actually using v1.20 that was writing that to script. thanks all! |
7th June 2018, 16:20 | #15858 | Link | |
ByteShare
Having an issue with color space on a 10bit x264:
https://imgur.com/a/V1GswgQ Link to the file: https://mega.nz/#F!I0QjVRBQ!sXl7gbM-ZfspEdwvrezNlA Meida Info: Quote:
9th June 2018, 09:59 | #15859 | Link | |
Renaming Install.cmd to Install.cmd.bak will prevent RipBot to auto update, if you at some point want to update RipBot just remove .bak |
