Old 25th March 2019, 23:05   #55501  |  Link
mzso
As far as I can tell, FFmpeg/LAV supports those "T2" ones fine, only "Pro" formats are not supported (10-bit).
Not my experience. FFmpeg/ffplay can't use them ("Invalid data found when processing input") . Also I get a black screen during playback in media players with LAV.
MPC-BE internal filter also gives black screen. MPV gives a spam of "Error while decoding frame!" errors.
Old 25th March 2019, 23:34   #55502  |  Link
el Filou
el Filou's Avatar
Originally Posted by mzso View Post
I kind of borked the comment, but the problem is with the official codecs, not LAV video.
Can you check in MPC's 'pin info' tab in the filter properties, the format (and other info) that the official decoder outputs, and compare it to what LAV outputs?
Old 25th March 2019, 23:42   #55503  |  Link
All I know is that the video in your zip plays fine. Perhaps your earlier videos were somehow corrupt.
Old 26th March 2019, 00:51   #55504  |  Link
mzso
Well, those are the very ones I tried, and the t2 one doesn't work with LAV and the others.
Well, I don't know what specifically are you looking for, here's everything:
Filter : UMRG Decoder DMO - CLSID : {94297043-BD82-4DFD-B0DE-8177739C6D20}
- Connected to:
CLSID: {E1A8B82A-32CE-4B0D-BE0D-AA68C772E423}
Filter: madVR
Pin: Input
- Connection media type:
Video: RGB24 1600x1200 59.999fps
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
subtype: MEDIASUBTYPE_RGB24 {E436EB7D-524F-11CE-9F53-0020AF0BA770}
formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 0
cbFormat: 88
VIDEOINFOHEADER:
rcSource: (0,0)-(1600,1200)
rcTarget: (0,0)-(1600,1200)
dwBitRate: 0
dwBitErrorRate: 0
AvgTimePerFrame: 166670
BITMAPINFOHEADER:
biSize: 40
biWidth: 1600
biHeight: 1200
biPlanes: 1
biBitCount: 24
biCompression: 0
biSizeImage: 5760000
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
pbFormat:
0000: 00 00 00 00 00 00 00 00 40 06 00 00 b0 04 00 00 ........@...°...
0010: 00 00 00 00 00 00 00 00 40 06 00 00 b0 04 00 00 ........@...°...
0020: 00 00 00 00 00 00 00 00 0e 8b 02 00 00 00 00 00 .........‹......
0030: 28 00 00 00 40 06 00 00 b0 04 00 00 01 00 18 00 (...@...°.......
0040: 00 00 00 00 00 e4 57 00 00 00 00 00 00 00 00 00 .....äW.........
0050: 00 00 00 00 00 00 00 00                         ........
- Enumerated media type 0:
Set as the current media type
- Enumerated media type 1:
Video: RGB32 1600x1200 59.999fps
AM_MEDIA_TYPE:
subtype: MEDIASUBTYPE_RGB32 {E436EB7E-524F-11CE-9F53-0020AF0BA770}
lSampleSize: 0
cbFormat: 88
VIDEOINFOHEADER:
dwBitRate: 0
dwBitErrorRate: 0
BITMAPINFOHEADER:
biSize: 40
biWidth: 1600
biHeight: 1200
biPlanes: 1
biBitCount: 32
biCompression: 0
biSizeImage: 7680000
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
pbFormat:
0030: 28 00 00 00 40 06 00 00 b0 04 00 00 01 00 20 00 (...@...°..... .
0040: 00 00 00 00 00 30 75 00 00 00 00 00 00 00 00 00 .....0u.........
Filter : ULH4 Decoder DMO - CLSID : {94297043-BD82-4DFD-B0DE-8177739C6D20}
- Connected to:
Filter: madVR
Pin: Input
Video: YV24 1600x1200 59.999fps
AM_MEDIA_TYPE:
subtype: Unknown GUID Name {34325659-0000-0010-8000-00AA00389B71}
lSampleSize: 0
cbFormat: 88
VIDEOINFOHEADER:
dwBitRate: 0
dwBitErrorRate: 0
BITMAPINFOHEADER:
biSize: 40
biWidth: 1600
biHeight: 1200
biPlanes: 1
biBitCount: 24
biCompression: YV24
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
pbFormat:
0040: 59 56 32 34 00 e4 57 00 00 00 00 00 00 00 00 00 YV24.äW.........
AM_MEDIA_TYPE:
lSampleSize: 0
cbFormat: 88
VIDEOINFOHEADER:
dwBitRate: 0
dwBitErrorRate: 0
BITMAPINFOHEADER:
biSize: 40
biWidth: 1600
biHeight: 1200
biPlanes: 1
biBitCount: 24
biCompression: 0
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
pbFormat:
- Enumerated media type 2:
AM_MEDIA_TYPE:
lSampleSize: 0
cbFormat: 88
VIDEOINFOHEADER:
dwBitRate: 0
dwBitErrorRate: 0
BITMAPINFOHEADER:
biSize: 40
biWidth: 1600
biHeight: 1200
biPlanes: 1
biBitCount: 32
biCompression: 0
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
pbFormat:
Old 26th March 2019, 01:26   #55505  |  Link
so on my system:
ut-teszt-t2 = RGB sample
RGB sample:
on my system the RGB sample can't be send into EVR directly if the native decoder UMRG decoder dmo is used it needs a color space converter or MPC hc will fallback to "video renderer" i didn't even know that there could be a fallback renderer.
lavfilter with either madVR or EVR gave me a black screen if 64 BIT is used it work fine for both on 32 bit.
if lavfilter is blocked the first decoder for this file my system is going to use is AVI Decompressor (UMRG) no colorspace converter nothing works totally fine.
so the odd things here on my system are the native decoder needing a color space converter and lav filter as decoder giving a black screen on 64 bit.
BTW. lav splitter -> prefer UMRG de... -> prefer colorspace converter -> madVR works.
at least to me it looks like UMRG decoder is kind of picky with the need of the color space converter.
Old 26th March 2019, 01:31   #55506  |  Link
amayra
Quality Checker
amayra's Avatar
i read last week about "Vulkan Working To Expose Video Encode/Decode" is this can be any useful to madvr if madshi or nevcairiel add it to lav if they add vulkan support ?
I love Doom9
Old 26th March 2019, 01:57   #55507  |  Link
I can confirm that. Should make it easy to find and fix it.
Old 26th March 2019, 02:52   #55508  |  Link
mzso
I can't follow this line. Where does the "AVI Decompressor (UMRG)" filter come from? I have it but it's not loaded by default. To me it also loads a colorspace converter for EVR.
So you mean that with this unidentified filter it works without a colorspace converter for you?
It works for me too with madVR if I add the colorspace filter as well.
Old 26th March 2019, 03:23   #55509  |  Link
of cause you have it: https://docs.microsoft.com/en-us/win...pressor-filter
this works fine for me and this is what happens on my system with disabled internal filter and lavfilter blocked but no preferred filter.
Filters currently loaded:
- Default DirectSound Device
- madVR
- Audio Switcher
- AVI Decompressor (UMRG)
- LAV Splitter (internal) (low merit)
- File Source (Async.)
i have quite a lot of dshow filter installed for testing but in this case it doesn't use anything special.
that the UMRG decoder dmo needs a colorspace converter is odd to me. of cause you could argue if madVR can't handle the stream the color space converter should be loaded like it is with EVR.
i have no clue who is responsible for loader these "in between filter" but i'm sure we both can both agree it would be great if the UMRG decoder dmo doesn't need this color space filter and that the output of the decoder can be rendered directly.
Old 26th March 2019, 09:09   #55510  |  Link
jmone
Has any one got a stutter free playback on a RTX without using Exclusive Mode?
I just upgraded from a 1070 to 2070 to get some more headroom with the HDR processing being worked on, but I too get stutters every second (queues are fine, no dropped/repeated frames reported) in Windowed Mode but it is fine in Exclusive Mode. I'd much rather not use Exclusive Mode as with the long sync times on my JVC PJ it gets pretty irritating.
Nathan
jmone is offline   Reply With Quote
Old 26th March 2019, 10:22   #55511  |  Link
chros
chros's Avatar
You can give this trick a try, maybe ...
Old 26th March 2019, 10:50   #55512  |  Link
Nicog
I have same issue than you jmone (very painful with JVC Projector in HDR in FSE).
This tip, chros, I tried it also (vertical sync -> Fast + window overlay) : it has effectively killed the stuttering, but at the price of horrible tearings in the picture. Maybe some solutions exists to kills that, but I didn't found it.
JRiver 25 in a Custom PC with i7 7700, Nvidia RTX 2070 (Zotac mini), Windows 10 1809, JVC X7900 in a dedicated black room :-)
Nicog is offline   Reply With Quote
Old 26th March 2019, 11:08   #55513  |  Link
the image is "bad" you are not supposed to use fast you are supposed to use on.
fast sync disables vsync until the frame rate is higher then the display rate this is not going to happen and makes no sense for video playback.
Old 26th March 2019, 11:15   #55514  |  Link
Nicog
Thanks for info.
I tried at first "on" but it was without effect. Maybe I had to restart madvr. I'll try again...
Old 26th March 2019, 12:12   #55515  |  Link
jmone
I'll also test when back in a few days. I also have the Zotac Mini, and MC25 with a beta build of madVR
Old 26th March 2019, 15:56   #55516  |  Link
cremor
Yes, I have no problems in windowed or full screen windowed using a RTX 2070.
When I had problems, it was either because of the already mentioned vsync setting (resetting it to the default value fixed it for me) or because of G-Sync. I solved the G-Sync problem by forcing it off via NVidia Inspector.
cremor is offline   Reply With Quote
Old 26th March 2019, 21:37   #55517  |  Link
Z'Hadum
Hello everybody,
sorry for this stupid question:
Is it possible to pass any of the madvr variables to a batch file through the
"command line to execute when this profile is activated" field?
What would be the syntax?
Some thing like
mySimpleBatch.bat %croppedSrcHeight% %croppedSrcWidth% %fps%
So I can use this variables in the Batch file with %1 %2 %3 ....
Z'Hadum is offline   Reply With Quote
Old 27th March 2019, 02:16   #55518  |  Link
JonnyRedHed
Maybe given the age and performance of your card you're the first one to notice an issue with this setting.. create the log and pass it to madshi over at http://bugs.madshi.net
Thanks, I'll look into that. Although I'm not very good at this sort of thing.
JonnyRedHed is offline   Reply With Quote
Old 27th March 2019, 08:12   #55519  |  Link
Nicog
It seems it works! I tried jsut few minutes, on my favourite test movie, and that looks OK!
Many many thanks to all of you!
Old 27th March 2019, 15:34   #55520  |  Link
chros
chros's Avatar
I just opened a new thread: Which display for MadVR only?
