1st March 2015, 12:08 | #3042 | Link |
MKVToolNix author
Just to make this very clear: »toggle all« enables or disables all tracks at once. It's the same as if you clicked each of the track's checkboxes manually.
It does NOT allow you to select multiple tracks and make any other modification on that selection. This is something that will only come with the new GUI; for the old GUI this would require re-writing roughly half of its code.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
1st March 2015, 12:45 | #3043 | Link |
Life's clearer in 4K UHD
Hi Mosu,
Many thanks for the new Dolby TrueHD audio options
1st March 2015, 15:36 | #3044 | Link |
Wrong duration of video after merging with .ass subtitle?
Thanks Mosu for the wonderful app
Anyway, I've been wondering why every time I merge into mkv, the video duration seems to be appearing wrong. The original video and the merged mkv files have different total duration. After doing some trial and error, I concluded that the mkv output that had wrong duration was because of the .ass subtitle file that had lines that was timed for more than the length of the video file. After retiming the lines of the subtitle file that was over the duration of the video file, then I merge video+audio+subtitle files into mkv, the duration was correct again. As there will be times I won't be able to check always the subtitle files that overpasses the video file, is there a way or an option in mkvmerge (though I'm next to always use mkvmerge gui) where the merged mkv file would produce the same duration as that of the video files and ignores the full duration of the .ass subtitle files? Thanks you in advance |
1st March 2015, 15:45 | #3045 | Link |
MKVToolNix author
No, there's no such option, and there won't be one. The definition of the segment duration is simply the difference between the lowest timecode and the highest sum of packet timecode+duration.
1st March 2015, 16:14 | #3047 | Link |
MKVToolNix author
That is correct.
1st March 2015, 16:34 | #3050 | Link |
does the TrueHD+AC3 recognition & deciding which of these tracks to keep also work for Dolby Atmos tracks?
1st March 2015, 17:02 | #3051 | Link |
Thanks Mosu, but especially Moritz! My Samsung SMART TV has trouble playing DTS-HD MA; the audiotrack is always a little behind and therefore not in sync (for which I hope some future firmware-update could help). Now I can remux in one single step, instead of first having to run eac3to (or ffmpeg) to extract the core and remux afterwards. Works great!
My hobby website |
1st March 2015, 17:10 | #3052 | Link |
MKVToolNix author
@Thunderbolt: so far I haven't done anything in that direction. mkvmerge's TrueHD and AC3 handling code might work with the Atmos extensions, but it isn't explicitly supported (not even tested).
@Corone: mosu == Moritz Bunkus
5th March 2015, 21:02 | #3053 | Link |
x264 data...
Does the newer MKVMerge strip out the encode data?
Perhaps it has done this in earlier builds, but I hadn't noticed it. I found out recently when I took MKV files that DID have the full x264 encode data in the stream and I used the most recent version of MKVMerge to slice it into 10 second snippets (to send to Selur for analysis as to why certain MKV files weren't playing on my OPPO BDP-83 player) And, lo and behold, the resulting 10 second snippets had the x264 encode data stripped out! Has this always been the case or is this something new? Thank you! Oh... and if so, IS there some way to use MKVMerge and still keep the x264 encode data? Last edited by Lathe; 5th March 2015 at 21:03. Reason: More stuff... |
11th March 2015, 04:16 | #3056 | Link | |
@Mosu
mkvmerge v7.7.0 incorrectly fills the biSize field in the BITMAPINFOHEADER structure for RGB8 and RGB565 format ("V_MS/VFW/FOURCC"). http://msdn.microsoft.com/en-us/libr...=vs.85%29.aspx Quote:
11th March 2015, 13:25 | #3057 | Link |
MKVToolNix author
Do you have a sample file? Please upload one to my FTP server (see signature).
The thing is that a LOT of AVIs have biSize include the codec's private initialization bytes and not just the size of BITMAPINFOHEADER. As the MS specs don't say anything about codec private data other than color tables and masks this is very much a grey area.
13th March 2015, 20:39 | #3058 | Link |
twogradients_RGB8_RGB565.7z (AVI files made in VirtualDub).
I also uploaded to FTP server. |
21st March 2015, 15:26 | #3060 | Link |
MKVToolNix author
Not really, no.
