3rd April 2015, 11:44 | #3121 | Link |
MKVToolNix author
I know, but a lot of people know that directory, therefore I haven't renamed it (yet).
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
3rd April 2015, 11:56 | #3122 | Link |
MKVToolNix author
Meh. I decided to rename it to »windows« and promptly made an error during syncing the directory to my server resulting in the whole directory being lost. Good thing I have backups
4th April 2015, 15:08 | #3124 | Link |
AV heretic
Just got 1073741819 error code (2-3 attempts). I tried to mux:
- m2v (50i) video from PAL DVD (demuxed by PgcDemux 1205 without any error); - FLAC from that DVD (LPCM demuxed by PgcDemux and packed to FLAC by eac3to without any error). MkvMerge is 7.8.0 x64 version. Any tips on whats wrong and how to fix? |
4th April 2015, 15:18 | #3125 | Link |
MKVToolNix author
That error code usually means that mkvmerge ran out of memory which is almost always due to either bogus file data or a bug in mkvmerge. I would need the two files in question if you want me to take a look.
4th April 2015, 15:20 | #3126 | Link | |
(try it with just the m2v and see if it still happens, then try... 7.3.0 I think it was...) |
4th April 2015, 15:48 | #3127 | Link | ||
AV heretic
EDIT: Mosu, no need to check it. It seems something went wrong with DVD ripping though and data is incomplete. My bad. Last edited by Qaq; 4th April 2015 at 17:19. |
4th April 2015, 18:01 | #3128 | Link |
MKVToolNix author
Yeah… I cannot find a problem with the two files here either. I've muxed both three times: on Linux (64bit) and on Windows (both 32 and 64bit builds). Everything's fine, memory usage stays pretty much constant.
5th April 2015, 05:40 | #3129 | Link |
Mosu, I've tried to append some files that have identical tracks but mmg doens't see it this way. I've uploaded a small zip to your FTP with Mediainfos output. Maybe that is sufficient.
MultiMakeMKV: MakeMKV batch processing (Win) MultiShrink: DVD Shrink batch processing Offizieller Übersetzer von DVD Shrink deutsch |
5th April 2015, 09:01 | #3130 | Link |
MKVToolNix author
Do you mean the file append.error-the.formats.do.not.match.rar from April 1st? If so: I've already deleted that file as I couldn't associate it with any request.
What would the actual error message be, BTW? MediaInfo output is most likely not helpful on its own.
5th April 2015, 10:34 | #3131 | Link |
When remuxing m4vs...
MMG doesn't seem to take into account a tracks "enabled" flag, which behaves much like a "default" flag in an MKV, is this deliberate? When extracting chapter images, shouldn't MKVMerge save them as attachments rather than as a video stream, after all: it doesn't extract apple text chapters as a subtitle track. |
5th April 2015, 10:38 | #3132 | Link |
MKVToolNix author
mkvmerge doesn't evaluate that flag.
Chapters in MP4 files are a steady stream of funny tales… meaning the different ways suck. It's not really unusual that mkvmerge doesn't behave the way you expect it to.
5th April 2015, 11:07 | #3133 | Link |
It's itunes, and apparently they've been doing it the one way for quite a while:
http://code.google.com/p/subler/issues/detail?id=27 I don't really care, it just took me a while to figure out what the hell that second video track was. (mkvextract cues, mkvmerge "split at chapters", mkvextract -raw) |
5th April 2015, 14:34 | #3134 | Link |
Just so I'm sure we're on the same page:
Video #2 ID : 8 Format : JPEG Codec ID : jpeg Duration : 1h 49mn Bit rate mode : Variable Bit rate : 3 891 bps Width : 640 pixels Height : 360 pixels Display aspect ratio : 1.85:1 Frame rate mode : Variable Frame rate : 0.002 fps Minimum frame rate : 0.001 fps Maximum frame rate : 0.004 fps Color space : YUV Chroma subsampling : 4:4:4 Bit depth : 8 bits Compression mode : Lossy Bits/(Pixel*Frame) : 8.444 Stream size : 2.78 MiB (0%) Language : English Encoded date : UTC 2014-02-14 22:47:03 Tagged date : UTC 2014-02-14 23:02:54 Menu ID : 7 Codec ID : tx3g Duration : 1h 49mn Language : English Encoded date : UTC 2014-02-14 22:47:03 Tagged date : UTC 2014-02-14 23:02:54 Source duration : 6589756 Source frame count : 12 Source stream size : 215 Frame count : 12 Stream size : 215 00:00:00.000 : Opening Credits/A Shooting Star 00:09:21.000 : Electrical Marvel 00:19:16.000 : "Run, Dorothy, Run!" 00:28:40.000 : The Yellow Brick Road 00:40:41.000 : Princess Mombi 00:46:23.000 : Jack Pumpkinhead 00:54:19.000 : Powder Of Life 01:04:42.000 : Crash Landing 01:12:37.000 : Three Chances 01:26:26.000 : Scarecrow 01:34:16.000 : Emerald City 01:45:08.000 : End Credits Bit rate mode : VBR Code:
Encoded date : UTC 2014-02-14 22:47:11 Tagged date : UTC 2014-02-14 23:02:54 |
5th April 2015, 14:37 | #3135 | Link |
MKVToolNix author
I currently have no plans of looking into that.
5th April 2015, 15:09 | #3136 | Link |
I though it was interesting.
And here's the disabled flag: Code:
Track # 3 Info - TrackID 3 - TimeScale 48000 - Media Duration 01:49:49.760 Track has 1 edit lists: track duration is 01:49:49.759 Track is disabled Media Info: Language "English (en-US)" - Type "soun:ac-3" - 205930 samples AC-3 stream - Sample Rate 48000 - 5.1 channel(s) - bitrate 192000 RFC6381 Codec Parameters: ac-3 Alternate Group ID 1 All samples are sync |
6th April 2015, 18:44 | #3137 | Link |
Pig on the wing
I've got a large amount of ERR312's in the mkvalidator log with Opus audio, for example:
ERR312: CueEntry Track #3 and timecode 8544636 ms not found ERR312: CueEntry Track #1 and timecode 8545454 ms not found When muxing the same video and subtitle track with FLAC audio, there are no such errors. I've not seen these errors with other files, but this one (the first Hobbit movie) is over 3 hrs long which makes it a bit different from the others.
6th April 2015, 19:03 | #3138 | Link |
MKVToolNix author
I cannot reproduce such errors with mkvalidator 0.5.0 and a random file with Opus inside. So you'll have to provide me with a sample file if you want me to take a look…
6th April 2015, 19:47 | #3139 | Link |
Pig on the wing
While trying to remux the file (because I couldn't reproduce it by demuxing to elements and muxing them), I found out that the Matroska file contains errors. This is really weird because I just muxed the original file and moved it over the network from my desktop PC to the external HD without any CRC differences (used Teracopy to move the file). It seems that the external HD is going bad
6th April 2015, 19:50 | #3140 | Link |
MKVToolNix author
Bad hardware will get you all the time, yeah I just had to replace two hard drives in my RAID 6 array. Luckily I'm a big fan of RAID 6 and not just of RAID 5…
