18th May 2015, 11:06 | #3261 | Link | |
Is this new or should I assume all my VC-1 files have these extra 30 bytes? |
18th May 2015, 12:02 | #3262 | Link |
MKVToolNix author
As the VC-1 handling code hasn't changed in ages this has probably been present for a long time.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
18th May 2015, 20:44 | #3263 | Link | |
18th May 2015, 20:50 | #3264 | Link |
MKVToolNix author
Uhm… I doubt that. 30 bytes sounds more like CodecPrivate being duplicated (think of SPS/PPS info in h.264 tracks being duplicated by extraction).
19th May 2015, 00:18 | #3265 | Link |
I was thinking that but Codec Private was 74 bytes and MakeMKV is refusing to remux them. They play fine though but that could be error correction or not.
Mike should be looking at a sample by now and hopefully the next version of MakeMKV will be able to read through whatever it is. It might be nothing, but Batman is VC-1 and I know I've remuxed that movie several times already, and I'm trying to get a final version of The Matrix done at the moment, the audio is being a pain... I would like to know exactly what it is though. |
22nd May 2015, 10:27 | #3266 | Link |
Pig on the wing
Is there a possibility that mkvalidator is not playing nicely or is it possible that a Matroska file corrupts in a few minutes?
First I got: Code:
R:\>mkvalidator --no-warn "The X-Files - S07E01 - The Sixth Extinction.mkv" ................................................................................ mkvalidator 0.5.0: the file appears to be valid file created with libebml v1.3.1 + libmatroska v1.4.2 / mkvmerge v7.9.0 ('Birds') 64bit Code:
R:\>mkvalidator --no-warn "The X-Files - S07E01 - The Sixth Extinction.mkv" ERR066: The SeekPoint at 87 references an unknown Cues at 401390961 file created with libebml v1.3.1 + libmatroska v1.4.2 / mkvmerge v7.9.0 ('Birds') 64bit I used "for %f in (*.mkv) do mkvalidator --no-warn "%f"" to check the files.
22nd May 2015, 10:52 | #3267 | Link |
MKVToolNix author
Hmm such things could happen due to uninitialized variables (= a bug). You should file a report at https://github.com/Matroska-Org/foun...-source/issues
22nd May 2015, 11:22 | #3268 | Link |
Pig on the wing
Is it possible to compare Matroska files? I'd like to make sure that my computer is not to blame, but using an MD5 checksum doesn't work.
22nd May 2015, 11:31 | #3269 | Link |
MKVToolNix author
I don't know of an easy-to-use tool for that. One possibility is to run mkvinfo -v on both files, direct the output to text files, use a diff tool and to ignore those elements known to be unique to each file (e.g. muxing date, all the UIDs).
22nd May 2015, 12:17 | #3270 | Link |
Pig on the wing
It seems that I can pinpoint the problem to occur on two hard drives that are in an external USB dock (connected to USB 3.0 via a PCIe card). Copying the same (working) muxed files from a different drive to one with problems doesn't seem to break them. Also other drives attached to the same PCIe card don't have the problem. I also tested a few FLAC files I have there but they are fine.
My question is: does mkvmerge use some special method to write the files? I have had write caching disabled so the drives are in quick removal mode.
22nd May 2015, 12:26 | #3271 | Link |
MKVToolNix author
mkvmerge uses the default functions offered by the operating systems; WriteFile() on Windows and fwrite() everywhere else.
22nd May 2015, 14:48 | #3272 | Link |
Pig on the wing
I was able to make all USB drives corrupt data, no matter if they were directly connected to the motherboard or via the PCIe card. Then I enabled write caching (the "Better performance" option) in Device Manager for all my USB drives and the issue is now gone. I have absolutely no clue why the setting would have anything to do with it, in fact I would expect the exact opposite, but no more corruption when muxing I do recall reading that uTorrent and KTorrent had similar issues related to Windows caching some time in the past.
23rd May 2015, 05:26 | #3273 | Link |
Boulder,
I think that problem has been mentioned in the VideoHelp computer sub-forum a few times and from memory it only applies to the 64 bit version of Windows 7. Is that what you're using? Have a look there but I'm not sure if anyone found another solution, aside from not using Windows Explorer to copy and paste but using a third party copying utility instead, although of course that probably doesn't help when using a USB drive as the destination drive when muxing it. Anyway, I just thought I'd mention it in case you wanted to look at those threads. Maybe it's related, or maybe not. |
25th May 2015, 18:45 | #3274 | Link |
Here's what I do is:
I analyse my input with mkvinfo Code:
mkvinfo.exe --ui-language en -s "H:\193.mkv" Code:
... Track 1: video, codec ID: V_MPEG4/ISO/AVC (h.264 profile: High 10 @L3.0), mkvmerge/mkvextract track ID: 0, default duration: 41.708ms (23.976 frames/fields per second for a video track), language: jpn, pixel width: 698, pixel height: 478, display width: 698, display height: 537 Track 2: audio, codec ID: A_AC3, mkvmerge/mkvextract track ID: 1, default duration: 32.000ms (31.250 frames/fields per second for a video track), language: jpn, sampling freq: 48000, channels: 2 ... Code:
"G:\MkvCutter\MediaInfo.exe" --Full "H:\193.mkv" Code:
... Video Count : 311 Count of stream of this kind : 1 Kind of stream : Video Kind of stream : Video Stream identifier : 0 StreamOrder : 0 ID : 1 ID : 1 Unique ID : 1 Format : AVC Format/Info : Advanced Video Codec Format/Url : http://developers.videolan.org/x264.h tml Commercial name : AVC Format profile : High 10@L3 Format settings : CABAC / 6 Ref Frames Format settings, CABAC : Yes Format settings, CABAC : Yes Format settings, ReFrames : 6 Format settings, ReFrames : 6 frames Internet media type : video/H264 Codec ID : V_MPEG4/ISO/AVC Codec ID/Url : http://ffdshow-tryout.sourceforge.net / Codec : V_MPEG4/ISO/AVC Codec : AVC Codec/Family : AVC Codec/Info : Advanced Video Codec Codec/Url : http://ffdshow-tryout.sourceforge.net / Codec profile : High 10@L3 Codec settings : CABAC / 6 Ref Frames Codec settings, CABAC : Yes Codec_Settings_RefFrames : 6 Duration : 1461712 Duration : 24mn 21s Duration : 24mn 21s 712ms Duration : 24mn 21s Duration : 00:24:21.712 Duration : 00:24:22;02 Duration : 00:24:21.712 (00:24:22;02) Bit rate : 1044138 Bit rate : 1 044 Kbps Width : 698 Width : 698 pixels Height : 478 Height : 478 pixels Pixel aspect ratio : 0.890 Original pixel aspect ratio : 0.889 Display aspect ratio : 1.300 Display aspect ratio : 4:3 Original display aspect ratio : 1.298 Original display aspect ratio : 1.298 Frame rate mode : CFR Frame rate mode : Constant Frame rate : 23.976 Frame rate : 23.976 fps Frame count : 35046 Resolution : 10 Resolution : 10 bits Colorimetry : 4:2:0 Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 Bit depth : 10 bits Scan type : Progressive Scan type : Progressive Interlacement : PPF Interlacement : Progressive Bits/(Pixel*Frame) : 0.131 Delay : 0 Delay : 00:00:00.000 Delay, origin : Container Delay, origin : Container Stream size : 190778595 Stream size : 182 MiB (72%) Stream size : 182 MiB Stream size : 182 MiB Stream size : 182 MiB Stream size : 181.9 MiB Stream size : 182 MiB (72%) Proportion of this stream : 0.71656 Writing library : x264 - core 142 r2453 ea0ca51 Writing library : x264 core 142 r2453 ea0ca51 Encoded_Library_Name : x264 Encoded_Library_Version : core 142 r2453 ea0ca51 Encoding settings : cabac=1 / ref=6 / deblock=1:1:1 / ana lyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me _range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_p skip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads= 0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / b frames=9 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop= 0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_ lookahead=60 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.70 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=1:0.60 Language : ja Language : Japanese Language : Japanese Language : ja Language : jpn Language : ja Default : Yes Default : Yes Forced : No Forced : No ... Code:
-o H:\\Temp\\test.mkv --split parts-frames:32545-34102,34102-34352 --no-audio --no-subtitles --no-buttons --no-track-tags --no-chapters --no-attachments --no-global-tags H:\\193.mkv with: Code:
"G:\MkvCutter\mkvmerge.exe" @"H:\Temp\TEST_M~1.TXT"
then I cut the file using Code:
LoadPlugin("G:\MkvCutter\LSMASHSource.dll") LWLibavVideoSource("H:\Temp\test-002.mkv", format="YUV420P10", cache=false) Trim(0,length=195) and rencode the file using: Code:
"G:\MkvCutter\avs2yuv.exe" -raw "H:\Temp\test-002.avs" -o - | "G:\MkvCutter\x264-10bit.exe" --profile high10 --level 30 --sps-id 0 --cabac --ref 6 --deblock 1:1 --partitions all --me umh --subme 10 --psy-rd 0.40:0.00 --merange 24 --trellis 2 --8x8dct --deadzone-inter 21 --deadzone-intra 11 --qblur -2 --bframes 9 --b-pyramid normal --b-adapt 2 --b-bias 0 --direct auto --weightp 2 --keyint 250 --min-keyint 23 --scenecut 40 --rc-lookahead 60 --qcomp 0.70 --qpmin 0 --qpmax 81 --qpstep 4 --ipratio 1.40 --aq-mode 1 --aq-strength 0.60 --chroma-qp-offset -2 --stitchable --non-deterministic --thread-input --crf 19 --demuxer raw --input-depth 10 --input-res 698x478 --fps 24000/1001 --sar 1000:890 -o "H:\Temp\test-002_reencode.264" - Code:
raw [info]: 698x478p 100:89 @ 24000/1001 fps (cfr) x264 [info]: using SAR=100/89 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2 x264 [info]: profile High 10, level 3.0, 4:2:0 10-bit 1 frames: 1.36 fps, 745.56 kb/s 23 frames: 22.16 fps, 147.96 kb/s 46 frames: 34.10 fps, 127.19 kb/s 64 frames: 39.98 fps, 119.78 kb/s 85 frames: 45.14 fps, 116.71 kb/s 107 frames: 49.22 fps, 114.23 kb/s 137 frames: 56.03 fps, 114.47 kb/s 170 frames: 63.08 fps, 117.26 kb/s x264 [info]: frame I:1 Avg QP:27.84 size: 3887 x264 [info]: frame P:38 Avg QP:30.81 size: 1305 x264 [info]: frame B:156 Avg QP:34.43 size: 409 x264 [info]: consecutive B-frames: 1.0% 0.0% 3.1% 12.3% 33.3% 43.1% 7.2% 0.0% 0.0% 0.0% x264 [info]: mb I I16..4: 62.2% 36.2% 1.6% x264 [info]: mb P I16..4: 2.8% 1.5% 0.0% P16..4: 41.0% 2.2% 1.9% 0.0% 0.0% skip:50.5% x264 [info]: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 24.9% 0.9% 0.1% direct: 0.2% skip:73.9% L0:50.1% L1:48.7% BI: 1.2% x264 [info]: 8x8 transform intra:36.6% inter:88.6% x264 [info]: direct mvs spatial:95.5% temporal:4.5% x264 [info]: coded y,uvDC,uvAC intra: 10.7% 0.0% 0.0% inter: 0.8% 0.0% 0.0% x264 [info]: i16 v,h,dc,p: 20% 25% 11% 44% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 5% 6% 50% 5% 8% 5% 9% 4% 10% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 6% 20% 13% 4% 10% 3% 33% 2% 9% x264 [info]: i8c dc,h,v,p: 100% 0% 0% 0% x264 [info]: Weighted P-Frames: Y:44.7% UV:0.0% x264 [info]: ref P L0: 37.4% 20.1% 18.0% 9.9% 9.9% 4.7% 0.1% x264 [info]: ref B L0: 73.9% 11.9% 8.4% 4.1% 1.7% x264 [info]: ref B L1: 93.0% 7.0% x264 [info]: kb/s:115.36 encoded 195 frames, 68.06 fps, 115.36 kb/s Now I cut the audio using: Code:
-o H:\\Temp\\test_AudioCut.mkv --split parts:00:22:37.398-00:23:50.471 --no-video --no-subtitles H:\\193.mkv which creates:
Then I join the audio&video files again, using H:\Temp\test-001_mkvOptions.txt: Code:
-o H:\\Output\\test.mkv --clusters-in-meta-seek --engage no_simpleblocks --disable-lacing --engage no_cue_duration --engage no_cue_relative_position --no-global-tags --no-chapters --no-subtitles --no-track-tags --no-buttons --no-audio --no-attachments --forced-track 0:no --default-duration 0:24000/1001p --fix-bitstream-timing-information 0:1 H:\\Temp\\test-001.264 --no-global-tags --no-chapters --no-subtitles --no-track-tags --no-buttons --no-audio --no-attachments --forced-track 0:no --default-duration 0:24000/1001p --fix-bitstream-timing-information 0:1 + ( H:\\Temp\\test-002_reencode.264 ) --no-video --no-global-tags --no-chapters --no-subtitles --no-track-tags --no-buttons H:\\Temp\\test_AudioCut.mkv --append-to 1:0:0:0 Code:
"G:\MkvCutter\mkvmerge.exe" @"H:\Temp\test-001_mkvOptions.txt" Code:
... Video Count : 311 Count of stream of this kind : 1 Kind of stream : Video Kind of stream : Video Stream identifier : 0 StreamOrder : 0 ID : 1 ID : 1 Unique ID : 12902876771495624352 Format : AVC Format/Info : Advanced Video Codec Format/Url : http://developers.videolan.org/x264.h tml Commercial name : AVC Format profile : High 10@L3 Format settings : CABAC / 6 Ref Frames Format settings, CABAC : Yes Format settings, CABAC : Yes Format settings, ReFrames : 6 Format settings, ReFrames : 6 frames Internet media type : video/H264 Codec ID : V_MPEG4/ISO/AVC Codec ID/Url : http://ffdshow-tryout.sourceforge.net / Codec : V_MPEG4/ISO/AVC Codec : AVC Codec/Family : AVC Codec/Info : Advanced Video Codec Codec/Url : http://ffdshow-tryout.sourceforge.net / Codec profile : High 10@L3 Codec settings : CABAC / 6 Ref Frames Codec settings, CABAC : Yes Codec_Settings_RefFrames : 6 Duration : 73073 Duration : 1mn 13s Duration : 1mn 13s 73ms Duration : 1mn 13s Duration : 00:01:13.073 Duration : 00:01:13;02 Duration : 00:01:13.073 (00:01:13;02) Bit rate : 914620 Bit rate : 915 Kbps Width : 698 Width : 698 pixels Height : 478 Height : 478 pixels Pixel aspect ratio : 1.123 Original pixel aspect ratio : 0.889 Display aspect ratio : 1.640 Display aspect ratio : 16:10 Original display aspect ratio : 1.298 Original display aspect ratio : 1.298 Frame rate mode : CFR Frame rate mode : Constant Frame rate : 23.976 Frame rate : 23.976 fps Frame count : 1752 Resolution : 10 Resolution : 10 bits Colorimetry : 4:2:0 Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 Bit depth : 10 bits Scan type : Progressive Scan type : Progressive Interlacement : PPF Interlacement : Progressive Bits/(Pixel*Frame) : 0.114 Delay : 0 Delay : 00:00:00.000 Delay, origin : Container Delay, origin : Container Stream size : 8354260 Stream size : 7.97 MiB (69%) Stream size : 8 MiB Stream size : 8.0 MiB Stream size : 7.97 MiB Stream size : 7.967 MiB Stream size : 7.97 MiB (69%) Proportion of this stream : 0.69014 Default : Yes Default : Yes Forced : No Forced : No ... -> Any idea why the Pixel Aspect ratio isn't 0.89? Cu Selur |
26th May 2015, 19:59 | #3276 | Link |
MKVToolNix author
RDF: The Matroska file format uses ISO 639-2. Therefore mkvmerge cannot simply use 639-3 codes. So the first step would have to be to extend the Matroska file format with new language elements that use the 639-3 codes, then to have support implemented in muxers like mkvmerge (and the associated GUIs), ffmpeg or gstreamer, and then in the players. A shitload of work, all in all, especially as all tools would have to be able to deal with two language attributes at once suddenly.
In short: it's highly unlikely that this will ever happen unless someone who cares about such a feature does the work. I don't care about that enough, so it won't be me.
26th May 2015, 20:02 | #3277 | Link |
MKVToolNix author
Selur: I really don't understand your question. You're actively telling x264 to use a pixel/sample aspect ratio of 1000/890 which is 1.1235… and then you wonder why MediaInfo outputs exactly that very same pixel/sample aspect ratio? Anyway, I have no clue whatsoever which value(s) MediaInfo choses to output as the various aspect ratios (sample/display/original sample/original display/pixel/whatever…); so may this question would be better off in a MediaInfo thread.
26th May 2015, 20:28 | #3279 | Link |
MKVToolNix author
You even pointed it out in your post
