24th February 2018, 14:16 | #5102 | Link |
# Version 14.0.0 "Flow" 2017-07-23 ## New features and enhancements * mkvmerge, mkvpropedit, MKVToolNix GUI (chapter editor): added support for chapters in WebM files that is spec-compliant by removing all tag elements not supported by the WebM spec. Implements #2002. |
24th February 2018, 14:27 | #5103 | Link |
MKVToolNix author
Chapters in WebM are spec-compliant. The valid elements are a subset of all the chapter elements Matroska supports.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
24th February 2018, 14:28 | #5104 | Link | |
MKVToolNix author
In the case of Annex B bitstreams inside MP4: the bitstream information.
24th February 2018, 18:49 | #5105 | Link | |
Matroska find' ich toll
24th February 2018, 23:19 | #5106 | Link |
This is how I proposed it in #2047. But now that I think about it again I think my proposal was based on a misconception: That parsing framed input would be slow. In fact, for an eternity you have already looked at the first byte of every NAL unit in order to discard filler bytes and now AUDs as well. What do you think?
25th February 2018, 12:10 | #5107 | Link |
MKVToolNix author
Not interested. Due to how Matroska works, mkvmerge has to calculate all reference timestamps properly, which basically means treating any h.264 stream the way an Annex B stream is treated (safe for finding the unit boundaries, of course): calculating the frame order etc. The flags in the "simple block" structure such as "key" and "discardable" are only derived from those reference timestamps. And for situations such as simple blocks being disabled the reference timestamps will actually have to be written to the output file (in the block groups).
So no, it's not just looking at the slice type.
4th March 2018, 11:17 | #5108 | Link |
MKVToolnix and TSDoctor do not like each other
Just stumbled upon a weird interaction between TSDoctor and MKVMerge.
The source is a downloaded TS file from the ARTE Mediathek. I used the SD version, but the HD version has the same problem. The downloaded TS file has a frame rate of 25 fps, it plays without issues. After running it through TSDoctor it still shows 25 fps and plays nicely. But after repacking this TSDoctor fixed TS using MKVMerge GUI the properties change to VFR, and playback shows heavy artifacts. If I feed MKVMerge with the original downloaded TS without using TSDoctor then the resulting MKV has 25 fps CFR and plays without problems. I uploaded my results here: http://www83.zippyshare.com/v/cndrA2sS/file.html Any idea what is happening here? I tend to believe that MKVMerge is to blame, because when I use FFmpeg to repack the TSDoctor fixed TS file then the resulting MKV does not show any issues. Cheers manolito |
4th March 2018, 11:21 | #5109 | Link |
Looks to me like TSDoctor is not properly adjusting the headers, mkvmerge keeps the messed up headers and delivers vfr, ffmpeg ignores the headers partially and returns cfr. So I would blame TSDoctor and not mkvtoolnix.
4th March 2018, 17:06 | #5111 | Link |
Beginning with mkvmerge 20.0 mkvmerge nows uses the information from the continuity counter that the transport stream provides to decide whether a PES packet in the input is corrupted; corrupted PES packets are dropped. ProjectX says that there are some discontinuities in the continuity counter, so this is what's happening here. It also complains a lot about bit errors in packets.
Why do you use tsdoctor at all? What can it do that mkvmerge can't (apart from outputting a transport stream what mkvmerge obviously won't)? [Edit]: It's actually slightly different to what I said above: There are some packets in your file that look like this: Code:
47 01 00 39 B7 00 FF FF ... FF FF According to the TS header this packet has an adaption field followed by a payload. The B7 (=183) says that the whole rest of the ts packet belongs to said adaption field, i.e. contrary to what has been signalled the packet doesn't even contain a payload. Now the thing is that the continuity counter is only supposed to increase for packets with payload. If one ignores this restriction, then there is no discontinuity in the continuity counter; but if one expects the continuity counter not to increase with such packets, then one has a discontinuity in the continuity counter which leads to the rejection of the entire PES packet. Now I have to admit that I don't know whether the continuity counter should increment if the header signals the presence of a payload despite there being none (or does a 0 B payload count?) or if it should only increment when there is an actual payload. Anyway, this faulty header information leads to ProjectY's reports of bit errors in the packet; therefore it drops said packets and reports a discontinuity in the continuity counter afterwards. mkvmerge is likely to do something similar. PS: I'd really liked to know what TSDoctor is supposed to achieve. Last edited by mkver; 4th March 2018 at 17:37. |
4th March 2018, 20:02 | #5112 | Link |
I have been using TSDoctor for a long time for video broadcasts in TS containers mainly to repair broadcast glitches and remove padding data. You are probably correct to question its usefulness for non-broadcast streams like downloaded files or ripped files from a BD.
You cannot really compare TSDoctor to ProjectX. ProjectX converts MPEG2 transport streams to program streams, it repairs broadcast glitches and takes care of keeping A/V sync. TSDoctor keeps the transport stream format when repairing the source, and when there was a glitch in the transmission TSDoctor will issue a warning, but it will not repair the stream. The resulting "fixed" stream will still exhibit A/V sync problems (which ProjectX would have repaired). Still my question remains valid. Why does the TSDoctor fixed TS file work perfectly, but after repacking it to MKV with mkvmerge the resulting MKV is broken? And doing the repacking of the same file to MKV with FFmpeg does not introduce any problems? Cheers manolito Last edited by manolito; 4th March 2018 at 20:05. |
4th March 2018, 20:12 | #5113 | Link |
1. mkvmerge does also remove padding data by default. And has done this for a very long time. So I don't see a point in using TSDoctor for broadcast streams, too. You yourself said that mkvmerge when fed with the original ts file produces a flawless file.
2. I did not compare ProjectX to TSDoctor; I just said that I used ProjectX to analyze your sample. 3. I don't see that TSDoctor fixed your TS file; the file it created is corrupted as I have explained. And since when does a mediathek use filler data at all? That would be news to me. So why do they exist in the version produced by TSDoctor? Really strange. 4. ffmpeg ignores the continuity counter, therefore it doesn't care about discontinuities in the continuity counter. |
4th March 2018, 20:23 | #5114 | Link | ||||
MKVToolNix author
That 0xb7 = 0b10110111 indicates: 0b10 = transport_scrambling_control; 11 = adaptation_field_control ( = adaption field present, payload present), 01111 = current continuity_counter. The "payload present" flag is set, therefore the condition mentioned above is not met, meaning the continuity_counter must be increased. If TSDoctor is writing such header fields but isn't increasing the continuity_counter, then it produces broken files and should not be used until that issue's been fixed. Quote:
4th March 2018, 20:33 | #5115 | Link |
FFmpeg reads the continuity counter, and it warns if it mis-matches, but it doesn't automatically drop data.
PS: Your analyzes is one byte off Mosu, the important header starts at 39, but the conclusion remains the same.
4th March 2018, 20:58 | #5116 | Link | ||
@Nevcairiel: I have seen ffmpeg outputting error messages that PES packet are incomplete, but I never got an error message (or a warning) informing me of discontinuities in the continuity counter. Last edited by mkver; 4th March 2018 at 21:05. |
4th March 2018, 21:07 | #5117 | Link | |
MKVToolNix author
Yes, I was off one byte (oops!), but as Nev said, it doesn't actually change the analysis: the adaptation_field is still 0b11, and therefore the continuity_counter must be incremented.
4th March 2018, 21:34 | #5118 | Link |
MKVToolNix author
Well, I did look into my source code. And yes, this is a bug in mkvmerge. From what I can tell, mkvmerge doesn't update its expectation about what the next continuity_counter is supposed to be if a TS packet doesn't contain payload bytes. The line I've linked to above handles that case correctly, it simply isn't called in that case (and that's likely the issue here). I'll see if I can get it fixed.
4th March 2018, 22:21 | #5119 | Link |
MKVToolNix author
Should be fixed in the latest pre-builds.
