Old 27th March 2011, 00:41   #6141  |  Link
pankov
Tom,
I've reported the same problem a few posts up.
pankov is offline   Reply With Quote
Old 27th March 2011, 02:11   #6142  |  Link
Twingo
Just try to help a little bit, I have same problem after using ATI DXVA today. I was using software on my HD5570 card before to decode h264 movies, but today I updated Coreavc to use DXVA for ATI cards, then my MPC-HC is asking me to update my directx after I set it to vmr9-renderless as described on MPC-HC website. It was okay before I updated directX but after I updated my directx to june 2010 release then the same problem (as reported by Barlow) occurred to me, my original directx is from windows xp sp3, never updated before today.
Originally Posted by Barlow View Post
Nice update
Unfortunately I've found a file which causes corruption in DXVA mode, whereas it's fine when decoded by the MPC Videodecoder (with DXVA) or CoreAVC in software mode.
Screenshot
Sample
Edit: forgot to mention, card is a Radeon 4850. OS is Win7 64bit.
Twingo is offline   Reply With Quote
Old 27th March 2011, 02:14   #6143  |  Link
Tom Keller
Tom Keller's Avatar
Originally Posted by pankov View Post
Tom,
Sorry... must have missed it . In the meantime i tested DSGraphEdit - it crashes too. Only the "good" old Microsoft GraphEdit seems to work though...
Tom Keller is offline   Reply With Quote
Old 27th March 2011, 02:43   #6144  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
Can anyone elaborate on an MKV seeking bug in WMP. Seems in certain systems it does not seek. What we are looking for is your settings (DXVA or CUDA) and content type.
Dan "BetaBoy" Marlin
Ubiquitous Multimedia Technologies and Developer Tools
http://corecodec.com
BetaBoy is offline   Reply With Quote
Old 27th March 2011, 04:27   #6145  |  Link
Twingo
I have exactly the same bug with my laptop using intel X3100 integrated video, I tried various settings but it won't work, dxva on/off, deterlacing on/off, low latency on/off or agressive on/off they all won't let me seek by pulling the progress bar. I was playing Mad Love 720p X264 mkv by Dimension.
Old 27th March 2011, 05:02   #6146  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
We have samples now and can reproduce it. Thank you for the follow-up.
Old 27th March 2011, 10:27   #6147  |  Link
cmbe
after upgrade from CoreAVC 2.0 to 2.5 with MediaPortal 1.1.2 i always get "Unable to play video" error on mkv files, besides everything works in Windows Media Player.
Before the upgrade everything works with CoreAVC 2.0 .
If I switch to another h.264 Codec in MediaPortal configuration as: MPCVideoDEc, FFDSHOW, etc. everything works fine.
I have tried to get more info with GraphStudio but it crashes (as reported a few posts back) with CoreAVC 2.5.
Has anyone experienced such problem?
cmbe is offline   Reply With Quote
Old 27th March 2011, 15:24   #6148  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
ok... we found the bug for ImediaPosition and ImediaSeeking (WMP not being able to seeking in some MKV's).... gonna take a look at the issue with MediaPortal and Rad's Graph Studio next.
Old 27th March 2011, 15:56   #6149  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
- ImediaPosition and ImediaSeeking bug, FIXED.
- Graphstudio bug, FIXED.
Going to see about MediaPortal next but I am assuming its fixed as well as it was the same bug as Graphstudio.
Old 27th March 2011, 16:01   #6150  |  Link
Ruklaw
Is an updated download available yet to fix the seek bug?
Ruklaw is offline   Reply With Quote
Old 27th March 2011, 19:00   #6151  |  Link
Chumbo
Chumbo's Avatar
@BetaBoy,
I found a playback corruption issue on a file I edited. Playing it using either ffdshow or MPC decoder has a fairly clean break at the edit point where CoreAVC 2.5 shows much corruption. Small sample here.
Chumbo
Chumbo is offline   Reply With Quote
Old 27th March 2011, 19:12   #6152  |  Link
oddball
Anyone got a direct download link? Your crabby portal does not recognise my email. Why paid up members should have to go through your portal to download the codec (which requires a registration number regardless) baffles me.
oddball is offline   Reply With Quote
Old 27th March 2011, 20:34   #6153  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
We are working on a quick followup release once we are confident the current reports are fixed.
We will send an update notice as soon as it's available. We already have an RC build compiled that we are testing.
Old 27th March 2011, 20:37   #6154  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
Oddball... Do not ask for a direct download link... And you will need a new corenumber as they have changed with 2.5.
PM me with your info and I'll take care of it.
Old 28th March 2011, 03:16   #6155  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
We are sending a test build (v2.5.1) to those who submitted support tickets on the seeking, graphstudio, and mediaportal bugs.
Old 28th March 2011, 13:02   #6156  |  Link
ajp_anton
ajp_anton's Avatar
What advantages does CoreAVC's DXVA have over for example MPC-HC's internal one?
ajp_anton is offline   Reply With Quote
Old 28th March 2011, 14:56   #6157  |  Link
desta
Jerky playback with Cuda
I've just upgraded to 2.5. Before doing so I quickly played some of my own 1080p encodes with 2.0 and all was fine. After upgrading to 2.5 I now get jerky, stuttered playback with 1080p mkv's. If I disable cuda then playback becomes smooth. 720p and below is fine with and without cuda.
I've opened a ticket through the portal.
desta is offline   Reply With Quote
Old 28th March 2011, 16:01   #6158  |  Link
robpdotcom
I updated to 2.5 yesterday, and when using DXVA I'm getting a corrupted image (not sure how to describe it, I can get some screen shots if necessary).
I haven't seen anyone else describe anything similar. Should I open a ticket, and, how do I open a ticket?
Windows 7 x64
i7 870
16GB RAM
AMD 6870
robpdotcom is offline   Reply With Quote
Old 28th March 2011, 16:50   #6159  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
What NVIDIA drivers do you have installed? Have up upgraded to the newest ones?
Old 28th March 2011, 16:51   #6160  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
We have received other similar reports... if you have a sample that shows this it would help trying to see whats going on.
codec, coreavc, corecodec, coremvc, cuda, decoder, dxva, h.264, mvc, scam
