13th May 2013, 13:39 | #17181 | Link |
Here's a new one. To me, at least.
v0.44.05 disc: Wolf Children (animation) job: movie-only backup log: [05.13.13] BD Rebuilder v0.44.05 (beta) [14:29:07] Source: WOLF_CHILDREN_00001 - Input BD size: 34,29 GB - Approximate total content: [01:57:03.516] - Target BD size: 23,78 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Better (Faster), Two Pass - Output folder: U:\_ENCODES\ - X264 Tweak(s) enabled - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Subtitle [2] is defaulted ON. [14:29:10] PHASE ONE, Encoding - [14:29:10] Processing: VID_00001 (1 of 1) - [14:29:10] Extracting A/V streams [VID_00001] - Extracting video streams [VID_00001] - Extracting audio streams [VID_00001] - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: S:\VIDEO\BD\WOLF_CHILDREN\BDMV\STREAM\00001.M2TS - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: S:\VIDEO\BD\WOLF_CHILDREN\BDMV\STREAM\00001.M2TS [15:00:12] - Failed to retrieve audio, aborted |
13th May 2013, 16:46 | #17183 | Link |
BD Rebuilder v0.44.06 (beta)
I have updated the first post of this thread with a link to the latest release of BD-RB (v0.44.06). Changes for this release:
- Corrected an new error in which ALTERNATE encodes using vFormat=8 (intact) was not working on multipart sources. - Corrected an error in which ALTERNATE output to an MKV file with MKV_MUXSUPS selected and a resize specified would cause a failure with an MKVMERGE error.(v0.44.5) - Corrected an issue in which zero length files could be created during ALTERNATE encoding. - Fixed an error in which some movie-only jobs that should use original audio may reencode. - Fixed an issue in which 3D ALTERNATE output to DVD-5/9 was not working (encode error). (v0.44.5) - Added the capability to perform 3D backups at full resolution (Full Side-By-Side and Full Over/Under)(default is HALF, as that is what most players expect). Note: This option will ONLY work on ALTERNATE MKV & MP4 output that has vFormat set to NO-RESIZE. FULL-3D is meant mainly for full HD 3D archiving.(v0.44.5) - Corrected an issue related to international decimal conversion of framerates during the IMPORT function.(v0.44.5) - Added a workaround so that 64 bit LAVF can be used on systems that don't support OpenCL. (v0.44.5) - Other minor corrections and cosmetic fixes. Last edited by jdobbs; 13th May 2013 at 16:51. |
13th May 2013, 17:11 | #17185 | Link |
Before I got my LG drives(Apparently NEC chipped, which I love), I found I got more bad rips with BD's, than DVDs. The discs didn't look that bad, but my Lite-on is really finicky. So, I only use it as a real time player now. Which it seems to excel at
13th May 2013, 17:37 | #17187 | Link |
Hi all, been reading over the forum for about an hour now trying to find a way to enable CUDA processing in BDRB and I can see it works but I have been messing with my settings and cannot get it to change from DirectShow to DGDecNV, I just got a GTX650 Ti Boost and want to see how it goes speed wise, its running paired with a Core i7 3770, any help much appreciated, cheers.
13th May 2013, 17:40 | #17188 | Link | |
13th May 2013, 21:14 | #17190 | Link |
Mr. Dobbs,
Thank you for issueing version 44.5 of BD Rebuilder, with the changes that you've made within the program, I've been able to finish encoding 3 blu rays, with the internal LAVF enabled.. these encodes have turned out perfectly well. Thank you again for all of your wonderous work on a marvelous software, BD REBUILDER.. Thanks again for your kind attention, and patience with me. |
13th May 2013, 21:34 | #17192 | Link | |
Edit: Fixed the problem, was using a beta nVIDIA driver, once I went back to the official version all worked. Last edited by sojourner353; 14th May 2013 at 04:55. |
14th May 2013, 05:02 | #17193 | Link |
MKV with Intact Video and Audio, Intact Video and AAC, doing well. Not so with Intact Video and AC3.
[05/13/13] BD Rebuilder v0.44.06 (beta) [20:55:54] Source: PAUL_00800 - Input BD size: 21.59 GB - Approximate total content: [01:43:48.263] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV, Intact Video & AC3 - Decoding/Frame serving: DirectShow [4-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [20:55:55] PHASE ONE, Encoding - [20:55:55] Processing: VID_00831 (1 of 30) - [20:55:55] Extracting A/V streams [VID_00831] - [20:58:21] Reencoding video [VID_00831] - [20:58:21] Keeping original video (no reencode) - [20:58:21] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [20:58:21] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [20:58:21] ReencodeAudio() 00070 1801 [20:59:36] - Failed to reencode audio, aborted All video/subtitles look to be playing correctly and in the correct order. It's great to see correct MKV sizes. I'm seeking through them for now. I haven't created the opportunity to watch completely. I noticed in the previous release the ghosting effect in the Alternative settings when using a custom setting. I think it wasn't new but...I like it a lot anyway.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 14th May 2013 at 05:07. |
14th May 2013, 05:31 | #17195 | Link |
For fun, since I know you support bug reports from BD-RB processed backups...I figured I'd process by backup of "The Hunger Games".
I made a Movie & Menus blanking extras a bit ago with AC3. I copied the contexts to the HDD, and proceeded to have BD-RB process it. This is the log.. [05/13/13] BD Rebuilder v0.44.06 (beta) [19:40:16] Source: THE_HUNGER_GAMES_00017 - Input BD size: 20.77 GB - Approximate total content: [02:22:33.216] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV, Intact Video & AC3 - Decoding/Frame serving: DirectShow [4-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [19:40:18] PHASE ONE, Encoding - [19:40:18] Processing: VID_00511 (1 of 12) - [19:40:18] Extracting A/V streams [VID_00511] - [19:42:42] Reencoding video [VID_00511] - [19:42:42] Keeping original video (no reencode) - [19:42:42] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [19:42:42] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - ERROR in attempt to reencode audio (AFTEN) [AUD_00511_4352.AVS] [19:42:43] - Failed to reencode audio, aborted Perhaps there's a way to make BD-RB identify that an AC3 is already exists and prompt the user to select "Alternative Video & Audio" when they click the button?
14th May 2013, 06:01 | #17196 | Link | |
---------------------- [05/13/13] BD Rebuilder v0.44.06 (beta) [21:43:07] Source: PAUL_00800 - Input BD size: 21.59 GB - Approximate total content: [01:43:48.263] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV, Intact Video & AC3 - Decoding/Frame serving: DirectShow [4-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [21:43:10] PHASE ONE, Encoding - [21:43:10] Processing: VID_00831 (1 of 30) - [21:43:10] Extracting A/V streams [VID_00831] - [21:45:37] Reencoding video [VID_00831] - [21:45:37] Keeping original video (no reencode) - [21:45:37] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [21:45:38] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - ERROR in attempt to reencode audio (AFTEN) [AUD_00831_4352.AVS] [21:45:38] - Failed to reencode audio, aborted Using my MacBook Pro (Windows 7 partition) which no one else is allowed to use and I only use for video editing... Same report. Edit 1: Code:
[05/13/13] BD Rebuilder v0.44.06 (beta) [22:08:31] Source: PAUL_00800 - Input BD size: 21.59 GB - Approximate total content: [01:43:48.263] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV, Intact Video & AAC - Decoding/Frame serving: DirectShow [4-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [22:08:32] PHASE ONE, Encoding - [22:08:32] Processing: VID_00831 (1 of 30) - [22:08:32] Extracting A/V streams [VID_00831] - [22:10:58] Reencoding video [VID_00831] - [22:10:58] Keeping original video (no reencode) - [22:10:58] Processing audio tracks - Track 4352 (eng): Reencoding audio to AAC... - Track 4355 (eng): Reencoding audio to AAC... - Track 4356 (eng): Reencoding audio to AAC... - [22:19:21] Processing: VID_00802 (2 of 30) - [22:19:21] Extracting A/V streams [VID_00802] - [22:19:38] Reencoding video [VID_00802] - [22:19:38] Keeping original video (no reencode) - [22:19:38] Processing: VID_00832 (3 of 30) I didn't overwrite the Alternative.txt. I'll compare them next.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 14th May 2013 at 06:39. |
14th May 2013, 06:14 | #17197 | Link |
Hi jdobbs, so I seem to have DGDenCV setup currently and get no errors now when I start BDRB with it enabled but BDRB now hangs after Extracting A/V streams is complete and I just have to abort it, since its not throwing an error I don't know what might be causing the problem, any ideas? thanks.
14th May 2013, 06:56 | #17198 | Link | |
"This software requires a license! If you attempt to run the software without a valid license in place you will receive no explicit notification of that fact. Instead, various functions of the program will simply fail to operate correctly"
14th May 2013, 07:59 | #17199 | Link | |
14th May 2013, 13:57 | #17200 | Link | |
[Edit] Can you show me the preset you created for "Intact Video and AC3"? I just tested it with the one below and it is working fine???? Code:
[00031] caption=MKV, Intact Video and AC3 Audio aType=0 aBitrate=* vFormat=8 cType=1 Last edited by jdobbs; 14th May 2013 at 14:27. |
