30th June 2019, 23:59 | #8862 | Link |
Use Megui 2908 X64 please help me to reduce NOISE old movie bluray
Source: Old full bluray H264 Resize filter: LancZos (sharp) [default] Please how to apply denoise correctly? Avisinth profile: scratchpad > ADD DENOISE Add this tag without any value Code:
<denoise> example my source with a lot of noise, which values to apply ??? Thanks a lot Last edited by Xor; 1st July 2019 at 00:14. |
1st July 2019, 09:18 | #8863 | Link |
@Xor
To use MeGUI <denoise> filters go to Filters tab like the image. There are many other denoiser filters in AviSynth but you need load the necesary plugins and add the functions manually in Script tab.
14th July 2019, 19:27 | #8865 | Link |
Hello. I finally upgraded to MeGUI-AviSynth+ 64 bit but have a final (ha ha) MeGUI question. Every time I open the 64 bit (latest, developmental server) version, MeGUI downloads almost 100MB of .dll's: api-ms-win-core..., mfc..., etc. because every time I close MeGUI 64 bit all of the .dll's are deleted. Any ideas how to get MeGUI 64 bit to simply keep all these .dll's upon closing? Thanks for any help .
3rd August 2019, 20:50 | #8868 | Link |
Happy Saturday! and another question . When using QAAC with the latest developmental build of x64 MeGUI to downmix audio in .mkv's, the output file has no language tag (it's "undetermined") even if the audio language is properly tagged in the .mkv itself. Is there any way--the Extra/Custom Command Line, maybe?--to get the output file to keep the language tag? Thanks for any help.
P.S.--Any answer for my recent question about the x64 version of MeGUI downloading ~100MB of .dll's every time it's opened? |
6th August 2019, 16:45 | #8874 | Link | |
giving a very continous and dedicated support to Megui for some years, so I prefer to think that if he'd decided to leave Megui he himself would say so. Besides, Megui and it's dependencias are quite stable even if there's no update recently. |
10th August 2019, 01:08 | #8876 | Link |
I don't know in detail how Windows behaves and how MeGUI works. The codepage which Czech is using Windows-1250 has these characters covered however so theoretically a GUI such as MeGUI which uses ANSI only tools such as AviSynth can work with such characters. One thing that a GUI should absolutely avoid is using batch files, that's gonna be trouble even on Win 10. For Unicode only VapourSynth will work, AviSynth don't support it.
https://de.wikipedia.org/wiki/Windows-1250
20th August 2019, 15:39 | #8877 | Link | |
Is this something new in MeGUI? I've been using MeGUI for 7 or 8 years now, and there was only 2 jobs for 2 pass encoding option. Why this job 3? Is it to mux de first and the second pass? Can someone help me with this question? Thanks in advance. Last edited by RipFan; 20th August 2019 at 15:45. Reason: add information |
27th August 2019, 16:20 | #8879 | Link |
Is HD streams extractor a eac3to frontend? eac3to prints:
Supported source formats: (1) RAW, (L)PCM (2) WAV (PCM, DTS and AC3), W64, RF64 (3) AC3, E-AC3 (4) DTS, DTS-ES, DTS-96/24, DTS-HD Hi-Res, DTS-HD Master Audio (5) MP1, MP2, MP3 audio (6) AAC audio (7) MLP, TrueHD, TrueHD/AC3 (8) FLAC (9) EVO/VOB/(M2)TS and MKV
27th August 2019, 16:24 | #8880 | Link | |
Can you recommend a program to extract opus from mkv? |
megui |
