4th March 2017, 13:48 | #25741 | Link | |
just tested on another machine. Same there. X264L-64.exe is called. I even started with a new ini file. Using a playlist containing a 30 min extra (because demuxing is quicker) everything is normal. x264.exe is called and feeded with the AVS script. Seems it only happens with the main movie playlist... Movie is Sherlock Holmes 2 by the way. The one with Robert Downey Jr. Looking into some INF files I still had and they are all saying "USE_LAVF=0". Is that correct? (only a guess) ggtop Last edited by ggtop; 4th March 2017 at 13:55. |
4th March 2017, 17:11 | #25742 | Link | |
4th March 2017, 18:20 | #25743 | Link | |
December 5th, 2016 - v0.50.20 - Updated code so that X264/LAVF can also be used for ALTERNATE encoding. In previous releases ALTERNATE encoding forced the use of DirectshowSource (for resizing). Now X264's internal resizing filters are used when X264/LAVF is selected. This reduces BD-RB's dependence on LAVF or FFDSHOW. ggtop |
6th March 2017, 17:51 | #25744 | Link |
Choosing Menu Background Video for Quickplay...
Quickplay has option for "finding" the original BD menu background video and using that instead of a static image. My question is: Why not let user select the correct *.m2ts file to use from the BDMV\Stream folder?
I frequently run into this issue when trying to re-author BD's, especially problem ones like Mockingjay 2(Hunger Games). This BD uses playlist obfuscation, which leads to multiple issues using BD Rebuilder. Using TSMuxer I create a new BD structure by selecting the correct playlist and de-selecting unwanted audio and subtitle streams. It is good to go at this point: under 25GB so will fit on a single disc. However, it would be really nice to add an opening "Quickplay" menu using the background video from the original disc. Read earlier posts: there is a problem where BD Rebuilder will always re-encode. This is such a case. Would be great if BD Rebuilder had option to really _FORCE No Encode_ for testing purposes. I tried multiple tricks attempting to get BD Rebuilder to "find" that background video. I know the correct *.m2ts and the *.mpls; can make a guess on the matching *.clpi... but my knowledge on BD structure is minimal. Is there a way to copy the necessary files to the structure(BDMV folder) to help BD Rebuilder "find" the menu background video... if implementing a direct choice under Quickplay options is too troublesome? I have found numerous work-arounds to create nice Quickplay menus, and would like to add a "tutorial" post to this thread to share tips. The _FORCE No Encode_ option (for testing) and (somehow?) choose original background video for Quickplay menu, would be a big help. Thanks JD for your continued efforts!!! Walker (in Virginia's Northern Neck) |
6th March 2017, 20:24 | #25745 | Link |
Hi LoneSwan,
from Hiddenopts.txt: Code:
This file contains descriptions of settings that can be added to the BDREBUILDER.INI file (via the Config/INI editor) that may change the handling of files during conversion, reencode, and rebuild. [Options] FORCE_NOENCODE=n n = 0/1 - if set to 1, BD-RB will always use original video (sizing will not be checked) BTW I had no problems with MockingJay 2. Prerequisite is of course it is decrypted properly. ggtop Last edited by ggtop; 6th March 2017 at 20:27. |
7th March 2017, 08:56 | #25746 | Link |
v0.50.20
Bug selecting BLANK.AC3 from BDRB install directory. When I go down the path: C:\Program Files (x86)\BD.... to select the BLANK.AC3 file, all that shows up is: C:\Program Files The rest of the path is missing. To get around the issue, I just copied the AC3 file into the same directory as the background menu. Unrelated issue: What is the darkest black that can be used for the active color? I discovered that selecting 0x000000, results in default green being used. I'm down to 0x202020. Thinking about it, you need some margin to be able to subdue it when the menu item isn't active, hence the not liking 0x000000. Last edited by MrVideo; 7th March 2017 at 10:20. |
7th March 2017, 14:34 | #25747 | Link | |
The MENU_ACTIVE_COLOR value can be anything greater than zero. So 0x010101 would be the darkest evenly distributed color. Of course you could use 0x000001 -- but that's not even. The reason is because 0 (which is the same as no setting) indicates the default color. Last edited by jdobbs; 7th March 2017 at 15:38. |
7th March 2017, 19:38 | #25748 | Link | ||
The long path to the BLANK.AC3 file has "(x86)" as part of it. I'm guessing that your program doesn't like the part of the path containing the ( ) characters, therefore truncating the rest of the path from those characters onward. Just a WAG. Try installing to C:\jdobbs (x86)\BDRebuilder\... and then see if you can get the program to point to the BLANK.AC3 file that is in that path. Quote:
To me, MENU_ACTIVE_COLOR="" or MENU_ACTIVE_COLOR= is equal to no setting. Blame it on my Linux scripting programming where a variable such as this is not binary True/False (1/0), so anything would be a value. IIRC, I did try 0x010101 and the text was white. |
7th March 2017, 20:01 | #25749 | Link | |
The solution is for me to change my code to use the registry instead of an INI -- but I just don't feel like putting that much effort into it. |
7th March 2017, 20:39 | #25750 | Link |
OK, so I do not have virtualization. Even if I did, it has nothing to do with this problem. I think you may be misunderstanding the issue.
Install BDRB into the normal M$ location on a 64-bit system, where BDRB will end up in C:\Program Files (x86). Start BDRB. Then do Settings->Import/Quick-Play Settings. Now browse (audio) to the location of the installed BLANK.AC3 audio file. Select the BLANK.AC3 file and then click on Open. The path shown will now only be C:\Program Files. All of this before anything is ever attempted to be written to any INI file. Again, I believe that BDRB doesn't like any path with ( ) characters. I agree with not putting this stuff in the registry. Makes it very difficult to look thru the parameters. |
7th March 2017, 21:53 | #25751 | Link |
Well... actually it does have something to do with the problem. If you'd followed the instructions you wouldn't be in that folder and you wouldn't be having that problem.
Also, I just tried browsing from within that folder while choosing the .AC3 file for the menu, and had no issues. Are you sure you have privileges? Last edited by jdobbs; 7th March 2017 at 22:04. |
8th March 2017, 01:41 | #25752 | Link | ||
So, I did some more testing. I copied the blankclip directory, and its contents to the same path you searched. No problem with that path. So, I copied BLANK.AC3 to the BD_Rebuilder and Tools directories. There was no problem when searching those two locations. The path it does not like is: C:\Program Files (x86)\BD_Rebuilder\Tools\blankclip\BLANK.AC3. So, I copied BLANK.AC3 into the dvdauthor directory and that path is not liked either. Lastly I created a C:\jdobbs\jdobbs path and copied the BD_Rebuilder directory, and its contents into it. Searching that longer path worked. I have no clue as to why BDRB doesn't like any directory under Tools when the path is C:\Program Files (x86)\BD_Rebuilder\Tools. |
8th March 2017, 03:07 | #25754 | Link | |
8th March 2017, 03:52 | #25755 | Link |
I was thinking that length had something to do with it, but not the length of characters. Why? Because in the menu background result box, the numbers of characters is larger than the available space and the characters to the right are just truncated. No wrapping. Then again, there are no spaces in that line in which the line can be cut to wrap.
I just did a test with the menu background in that I was able to change a "-" to a space and sure enough, it wrapped. The bug might be with M$ if it has a no-wrap attribute and you have it enabled, but it wraps anyway. If it is still bad with Win10, it has been around for a very long time. Can you make that dialog box user resizable so that a user can make it wider, allowing for the text to fit and not wrap? |
8th March 2017, 06:31 | #25756 | Link |
I might have mentioned this a while back, I don't remember, but is it possible to be able to use more characters in the titles of the Quick Play menu? Many times I use it to put the Xtras, and usually the titles of each of the xtras is cut off (looks like about maybe 36 characters total including spaces) Any chance of being able to have longer titles in the Quick Play menu. They currently only take up about 1/2 the length of the screen.
Thanks! |
8th March 2017, 15:02 | #25757 | Link | |
What is possible is that I could add a hidden option that reduces the font size by some specified amount. For example, if you set a value of .75, the size of the font would be reduced to 3/4 of the default. It would give you more horizontal space. It may not be exact, since most fonts don't use fixed spacing. But it would make it more controllable. The downside is that when you reduce the font size, both the vertical and horizontal size is affected. Last edited by jdobbs; 8th March 2017 at 15:08. |
9th March 2017, 07:51 | #25758 | Link | |
Now, to expand upon this... Last edited by Lathe; 9th March 2017 at 07:54. Reason: Hit the wrong key like a Jack@ss... |
9th March 2017, 08:15 | #25759 | Link |
I have some MKV H.264 videos that I want to put on a couple of discs. First, I wasn't sure if the H.264 video would play in the Blu-ray player, untouched, so I created a test disc with a single video. When I put the disc into the player, the video was fine, but there wasn't any audio. Going back to the computer, I looked at the M2TS file, and sure enough, no audio. Then I noticed that when the BDRB job finished, it only showed the video file. No explanation as to why BDRB rejected the audio stream.
The audio is E-AC3 5.1. MediaInfo and txMuxer both claim it is 640 kbps, while VideoReDo says it is 1280 kbps. E-AC3 is a legit Blu-ray audio format, so why would BDRB reject it? I can supply a 30 sec segment of the video for downloading from my server. |
9th March 2017, 08:20 | #25760 | Link | |
