Old 30th October 2009, 22:18   #5781  |  Link
Capsbackup
@jdobbs;
Perhaps I misinterpreted a previous post, but is full movie backups to BD5/9, including PiP and secondary audio, supported by standalone players as well as software players?
Old 30th October 2009, 23:31   #5782  |  Link
cwh060
@jdobbs,
That's because the extras are insignificantly small and are left alone (copied intact). Combined they add up to only about 350MB on that disc. It's supposed to do that. The disc will still be a full backup. It can't do intact file copying on BD-5/9 because the bitrate could be too high for those types of discs.
Great, thanks for the answer.
cwh
cwh060 is offline   Reply With Quote
Old 30th October 2009, 23:32   #5783  |  Link
Originally Posted by Capsbackup View Post
@jdobbs;
They work on my Sony...
Old 31st October 2009, 14:11   #5784  |  Link
Lynxs
@jdobbs,
@jdobbs;
Do you think the latest BD-R version will address the audio issue I'm having. I'm re-encoding a BD-9 full backup with v0.31.01 right now.
And is there any special settings you can suggest that may solve my audio issue?
I'm trying to use BD-R as "turnkey" with standard settings to fully backup onto a DVD-DL which I know is stating the obvious since that why we are reporting potential bugs here.
For the last backups I've done, BD-R has been fantastic. Just completed the kids "ICE AGE 3" and it was a perfect dupe so I'm pretty confident with my settings -> just want to make sure I haven't missed any small tweaks that can address some of these particular BDs with higher audio and video track complexity in the main movie and extras (PiP,additional tracks, commentary, etc.).
Lynxs is offline   Reply With Quote
Old 31st October 2009, 14:25   #5785  |  Link
Originally Posted by Julian124
Originally Posted by pakkman View Post
I have had sync problems with the main movie on "Drag Me to Hell". If I copy movie only it's in sync and if I do 1:1 (48GB) in sync, but if backup whole disc to 25 GB the movie is out of sync from the beging to the end. Any ideas?
I seem to be having the same problem, and I tried moving around the settings in the audio, but still nothing. Does anyone know how we may be able to fix this issue?
Ok, guys. I need some help here. I did a full backup of "Drag Me to Hell" to BD-25 last night and it (both versions) is in perfect sync. You need to give me more details or I can't help you. What O/S are you using? What settings? What region are you in? How about the log and the INF file?
Old 31st October 2009, 14:27   #5786  |  Link
Originally Posted by Lynxs View Post
@jdobbs,
I can only tell you that v0.31.01 addresses audio problems related to MPEG-2 sources with pulldown. I haven't been able to replicate any other reported audio problems, and no one so far is giving me any useful details that might help find what is causing their problems. If I get a disc reported with issues and when I run it everything is fine (especially when I get no details) -- I always have to assume it is caused by "tinkering" and go on to the next problem.
I'm going to pick up a copy of "Monsters vs Aliens" this afternoon and see what it does for me.
Old 31st October 2009, 15:17   #5787  |  Link
Lynxs
@jdobbs,
I get your point and that's fair. When I complete the BD-9 on M vs. A's (estimate tomorrow morning), I'll let you know if I have better luck producing a BD-9 (fb) using TMT using v0.31. And I'll also post my O/S, Region, settings, INI, inf, and log file.
And thanks for trying to reproduce my problem.
Old 31st October 2009, 16:41   #5788  |  Link
@jdobbs,
Were you keeping the original audio or reencoding to AC3?
Old 31st October 2009, 17:29   #5789  |  Link
Lynxs
@jdobbs,
Tried turning both on and off at the same time. If I understood you to mean "do not include DTS convert to AC3" and "Do not reencode AC3" for BD-9. And also turning on and off "Keep HD Audio for BD25 encoding" when I tried to re-encode for BD-25 ... for me I couldn't find a setting that made any difference to the output..
Old 31st October 2009, 17:37   #5790  |  Link
drmih
I've done M v A to bd-9 full disc and it works fine on a pc with TMT 3. However, it's one of those discs where the audio is unselectable when played on a sony sap.
Old 31st October 2009, 17:59   #5791  |  Link
Lynxs
@drmih,
That's great. Did you enode the seconday video as well ie. does the PiP audio work with the "Animator's Corner" extra and if so, could you please let me know your settings.. thks
Old 31st October 2009, 19:03   #5792  |  Link
LowDead
Elit Amans
BD Rebuilder v0.31.01 Audio encode error
When I did Royal Space Force last night I got an audio encode error.
ReencodeAudio() 00075 1801
My setup was not to convert DTS, not reencode AC3 and not keep HD audio. I'm not sure what has happened here so here comes the logs:
LOG:
[22:04:01] BD Rebuilder v0.31.01 (beta)
  - Source:  ROYAL_SPACE_FORCE
  - Input BD size: 32,72 GB
  - Approximate total content: [02:08:12.351]
  - Target BD size: 23,73 GB
  - Windows Version: 6.1 [7600]
[22:04:01] PHASE ONE, Encoding
 - [22:04:01] Extracting A/V streams [VID_00000]
 - [22:19:54] Reencoding: VID_00000 (1 of 8)
 - [09:30:23] Extracting A/V streams [VID_00001]
 - [09:30:26] Reencoding: VID_00001 (2 of 8)
 - [09:31:37] ReencodeAudio() 00075  1801
[18:18:15] - Failed to reencode audio, aborted
INF:
[Status]
LABEL=ROYAL_SPACE_FORCE
VERSION=v0.31.01 (beta)
SOURCE_SIZE=35128576000
SOURCE_VIDEO_SIZE=35044798464
TARGET_SIZE=25480396800
REDUCTION=.724690121704904
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;swe;
BACKUP_MODE=0
QUICK=0
ENCODE_STEP=3
COMPLETED=1
[00000]
AUDIO=111
PGS=11
M2TS_TARGET=24179667480
RATE=23129
NSIZE=23431065600
FLINK=0
MLINK=0
[00001]
AUDIO=111
PGS=11
M2TS_TARGET=41759961
RATE=6038
INI:
[Options]
MODE=0
ENCODE_QUALITY=3
TARGET_SIZE=23450
AUDIO_TO_KEEP=eng;
SD_CONVERT=0
COLOR_BOOST=0
RESIZE_1080=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
KEEP_HD_AUDIO=0
AVCHD=0
REMOVE_WORKFILES=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=24300
QUICK_EXTRAS=0
[Paths]
SOURCE_PATH=J:\TEMP\ROYAL SPACE FORCE\
WORKING_PATH=G:\TEMP\ROYAL SPACE FORCE\
LASTCMD:
"C:\DVD-Rip\BD_Rebuilder\tools\x264.exe" "G:\TEMP\ROYAL SPACE FORCE\WORKFILES\VID_00001.AVS" --preset slow --ref 4 --b-adapt 1 --qpmin=0 --bitrate 6038 --level 4.1 --sar 1:1 --aud --vbv-bufsize 30000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 35000 --threads auto --slices 4 --thread-input --stats "G:\TEMP\ROYAL SPACE FORCE\WORKFILES\VID_00001.AVS.MKV.stats" --pass 2 --output "G:\TEMP\ROYAL SPACE FORCE\WORKFILES\VID_00001.AVS.MKV"
Hope this helps if it is a bug.
Edit: One thing I came to think of was that I manually choosed which audio tracks to keep in the "stream" window as my default options didn't apply on this disc. My OS is a freshly installed Win7. I never had any problems before, but yet again it is freshly installed so I could have missed something.
//LD
Old 31st October 2009, 20:00   #5793  |  Link
Sharc
@jdobbs
Thanks for providing the Tweaks as hidden options. I tried it and it works well. .
Now my question: If I do 1-pass crf encode, will the tweaks be applied for crf prediction pass as well?
I am asking because I set
TWEAK_PASS_ONE=--me umh --tune film
TWEAK_PASS_TWO=--me umh --tune film
and got an oversize (BD5 movie only) which I never have experienced before. Therefore my question whether the tweaks are applied for the crf prediction pass (actually they should), or if not, if this could be the cause of the oversize?
Old 31st October 2009, 20:13   #5794  |  Link
turbojet
I see the same oversize issue with TWEAK_PASS_TWO= --me umh --psy-rd 1:0 --direct-auto.
custom size 4555 MB = 4449 MB (4,455,xxx KB) without tweak with tweak 4489 MB (4,596,xxx KB).
I'll try to find another calculation that works consistently with tweak.
Old 31st October 2009, 20:37   #5795  |  Link
@jdobbs
If you use CRF, it will use the tweak from TWEAK_PASS_TWO. I might add a TWEAK_CRF=n for the next release.
I made a change to the CRF routine that rounds to the nearest .1 while looping (trying to reduce the number of passes). That's probably what caused the oversize. I'll go change it back.
Old 31st October 2009, 20:59   #5796  |  Link
psycoxl
Maybe im missing it or maybe it's feature request but is there any possibility to make a working bluray with menu. I want to rip all audio streams except one and i want to add one audio stream (cause i want to convert a PCM to DTS).
tia
michiel
psycoxl is offline   Reply With Quote
Old 31st October 2009, 21:18   #5797  |  Link
Race Guy
BD-RB (v0.31.01)
- Corrected an error that can result in out-of-sync
audio and playback problems on some MPEG-2 sources
that use pulldown flags.
Hi jdobbs! This was the fix for those Casablanca OOS extras, correct?
If so, I just tried to run it again & two of the problem vids were good on sync (0032 & 0051), but the other two vids (0033 & 0037) were just as OOS as before.
See ya!
Race Guy is offline   Reply With Quote
Old 31st October 2009, 22:40   #5798  |  Link
pakkman
I've Done this in Vista and Win7. I just tried it again in win7 with 31.01 and got the same result. I did this as a single pass
here is the ini
[Options]
MODE=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
COLOR_BOOST=0
RESIZE_1080=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
KEEP_HD_AUDIO=1
AVCHD=0
REMOVE_WORKFILES=1
AUDIO_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=23450
TARGET_SIZE=23000
ENCODE_QUALITY=5
[Paths]
WORKING_PATH=D:\ISO\
SOURCE_PATH=C:\BD BACKUP\DRAG_ME_TO_HELL\
pakkman is offline   Reply With Quote
Old 31st October 2009, 23:52   #5799  |  Link
Sharc
Hmmm... , not sure if any rounding to .1 is the cause for the oversize. Here my sequence:
- [18:17:48] Performing CRF Prediction...
- Analyzing 11.00 30.50 25.20 21.60 19.50 18.40 18.00 18.10 18.05 18.08 18.09 [18.09]
The steps are .01 rather than 0.1.
Old 1st November 2009, 00:07   #5800  |  Link
happycase
[17:44:52] BD Rebuilder v0.31.01 (beta)
- Source: BATMAN_AND_ROBIN_WW
- Input BD size: 30.25 GB
- Approximate total content: [02:04:53.861]
- Target BD size: 4.35 GB
- MOVIE-ONLY mode enabled
[17:44:52] PHASE ONE, Encoding
- [17:44:52] Extracting A/V streams [VID_00000]
- [18:00:10] Reencoding: VID_00000 (1 of 1)
- Switching to FFMS2.DLL for decoding.
- Encode failed. Retrying.
- Reached retry limit. Aborting.
[18:01:15] - Failed video encode, aborted
Could someone please tell me what this error means? I just set Windows 7 (yes, authentic student upgrade official release) up on a new machine and didn't encounter this under Vista.
This is also a VC-1 disk and a legitimate rip.
happycase is offline   Reply With Quote
