18th January 2017, 17:01 | #1721 | Link | |||
Hey folks, I'm fairly new here but I already have a problem, haha.
So I was trying to encode a video that I created using Vegas Pro 13.0 with staxrip. But when I try to load my source file (in this case, the video file is about 350 GB) and choose AviSynth+ as source filter I get an error: Quote:
19th January 2017, 00:52 | #1723 | Link |
I dont know if that is the best place to talk about this but since the noticed issue started with Youtube i would say here. A guy noticed than when uploading Nvenc source to Youtube the reencoding results were worse than feeding with x264 source. So i tried samething and find same problem. Then i decided to reencode at low bitrate with my own x264 software from both NVENC and x264 high bitrate sources which you will not notice quality difference and i see than samething happens, when reencoding at low bitrate like youtube (1080p@5mbit) NVENC source give worse result. With Quicksync happened samething. Is that something was already known?
26th January 2017, 01:34 | #1724 | Link |
Hi everyone. JohnLai posted some recommended QSVEncC HW encoding settings for me a few months back that have been helpful. http://i.imgur.com/OaGdzPs.jpg
I just updated to the latest Staxrip and Rigaya QSVEncC and was wondering if any of the recommendations have changed. Thanks for any advice! |
26th January 2017, 15:54 | #1725 | Link | |
His recommendation is flawed. B-frames over 4 results in playback issues when converting with a low bitrate, TU4 and even more TU1 is dead slow under H265 because Intels GPU is too slow, it's a bad tradeoff. You may try TU4 which is slow, but forget about TU1. Ref frames 5 - never saw improvements in real world over 3. MBBR is enabled by default, no matter if you disable or enable it, it won't change anything. It runs enabled even if you try to disable it. ICQ Bitrate mode has lower quality than VBR, yes it has some benefits over VBR in some cases but it can be really poor in static scenes for example. Better go with VBR as a starting point. The non QSV decoder is much slower with more CPU use, only use it if you need scenechange (doesn't work with QSV decoding) |
26th January 2017, 18:05 | #1726 | Link |
-.- Spon wants the best possible out of Intel HEVC encoding. Those options are the best possible options.
B-frame over 4 only problematic for smartphone or low end devices. Beside, Intel is using GPB, which mean, IBBBBBBBBBBBBBBBB, might as well as max it and leave it to 'scenechange' to insert new I-frame when it is necessary...... TU1 --> Remember 32x32 CU? Efficiency? REF --> Real world, not really, in synthetic PSNR, there is an impact. Oh, I think you are the one who provide me the HEVC sample last time for Intel. Technically, the reference top out* at 2 frames. The third reference frame only account for around 1-5%. Example from your Intel HEVC sample last time with 3 reference frame. (Note, Frame number 40 is being analysed) Reference pictures % Pixels 29 1.26 26240 33 39.80 831488 37 77.37 1616320 But, for animated content, high count of reference frames are very useful. ICQ ---> which is why 'scenechange' enabled to minimize static scene artifact. Note, VBR is worse than ICQ in my test. Decoder ---> That why I wrote only use QSVENC as decoder if one is certain the source file can be QSV-decoded. Last edited by JohnLai; 26th January 2017 at 18:21. |
26th January 2017, 18:39 | #1727 | Link |
Yups & JohnLai -
Thank you both for your responses. It's interesting to see the differing opinions. I'm going to try them both and see which one looks better to my eyes. One question - I can't seem to find the TU1/TU4 that you reference. Which menu is is located in - Basic, Slice, Rate Control, Motion Search, Porfile, Performance, Bitstream, VPP, VUI, Deinterlace or Other? Also, can the latest version of QSVEnnC encode 10bit? I saw a reference to it on Rigaya's site, but don't see anything in Staxrip. Thanks again |
26th January 2017, 19:07 | #1729 | Link | |
I have a skylake CPU, so probably no-go on 10but. Thanks again |
28th January 2017, 07:13 | #1730 | Link |
@Stax76
Hello Frank. A brand new VCEEncC v3.01 HW encoder for AMD is here: http://rigaya34589.blog135.fc2.com/b...ry-891.html?sp It has a few new options for H.264 and it's the first one with H.265 HW encoding support for Polaris cards and newer. Rigaya has also added some other useful features like HW decoding, --check-features etc
28th January 2017, 14:41 | #1731 | Link |
I'm running a i7-7700k, would you call it a low end device? B-frames over 4 requires some amount of minimum bitrate, a 1080p video with 3 Mbps isn't going to work. It's clear you didn't test anything in real world. And ICQ is below VBR in image quality, confirmed by Intel (and me).
28th January 2017, 15:10 | #1732 | Link | |
Beside, I can only test lotta B-frames with Haswell H264 (IPBBBBBBBBBBBBBBB). I am certain ICQ is better than VBR for H264 from PSNR and MSSIM analysis. Some old smartphone has problem decoding H264 with a lot of B-frames, but generally, PC discrete GPU can decode such video just fine. I assume it would be the same for intel HEVC. Anyway, I had been requesting QSV HEVC sample with many b-frames and refs from you for some time now...... |
28th January 2017, 15:23 | #1733 | Link |
ICQ for H.264 is A LOT better than VBR.
No idea regarding HEVC though. After lots of test with Haswell, my opinion is that plain ICQ is the best mode for Haswell H.264 HW encoding.
30th January 2017, 01:57 | #1734 | Link |
Guys,
Which among the resizer is the best for 2160p->1080p?
30th January 2017, 04:19 | #1735 | Link |
Downscaling?
Stick with avisynth default BicubicResize. BicubicResize default value parameters b (0) and c (0.5) = Cubic-Catmull-Rom spline. Hmmm.....for you to learn more about b and c as well as resampling filter.....you must visit http://www.imagemagick.org/Usage/filter/ I propose you to read from the beginning. Critical reading for your question is at Mitchell-Netravali Filter section *Note: don't skip the reading at imagemagick site. Some links at the site had become rotten due to time passing.......May the information can be a help for your question. |
30th January 2017, 04:57 | #1736 | Link |
Thanks john! That's what I did. I used the default settings in staxrip. Do you happen to know as well if the default setting extends to retaining the original aspect ratio?
30th January 2017, 07:11 | #1737 | Link | |
I thought staxrip has Resize's DAR, SAR and PAR settings plus Output Mod for retaining original aspect ratio right next to the "Filters"? |
30th January 2017, 07:16 | #1738 | Link |
Yeah, there is. Not sure how to interpret it. Dunno if the values there indicate same aspect ratio
30th January 2017, 07:40 | #1739 | Link | |
One can click on PAR for more selection: Back in the day when H264 just made it first appearance on satellite/terrestrial broadcast, some broadcaster broadcasted video with frame size 1440x1080 (for bandwidth cost reason), but for video to be properly displayed, it need to be stretched to 1920x1080. Kinda similar method for anamorphic DVD-Video too. I remembered I screwed up with my DVD archives after resizing without noticing the DAR. The good old day of XVID encoding...... |
