#35301 | Link |
after update to madvr .90.2 everything work fine on my system, happy!
![]() just playback a whole movie for test, get some present glitch and frame drop ocasionally, and a massive frame drop during playback at half time, I pause it for some sceconds, it's gone. Last edited by 4h4h270; 14th January 2016 at 08:10. |
#35303 | Link |
Your settings are too aggressive. Try lowering them slightly or using some of the trade quality for performance checkboxes.
#35304 | Link | |
This is on Windows 10 pro and player is jriver MC. Note: I haven't tried MadVR 90.2 yet though. |
#35305 | Link |
Ok - I've had it working twice but not consistently. In all cases I'm getting NV12, 8bit, 4:2:0 (3D) (so LAV is decoding), but most of the time I ether get:
- D3D9 & Side By Side, or - MC Crashes I'll test more tomorrow but no obvious pattern, as after one play it stopped working the second time. |
#35306 | Link | |
#35307 | Link | ||
Yes, it’s fixed in v0.90.2. I guess Direct3D doesn’t allow 10 bit for 3D output. Quote:
1. In India, Blu Rays are mastered at 24 fps and not 23.976 fps. I guess it happens the same in most other PAL countries too. So ideally you should force 23p/ 24p for 3D playback depending upon the source fps, if you aren’t already doing that. 2. When you implement processing of SBS and TBB content, for the broadcasted SBS/ TBB you may want to output 50p/ 60p frame packed 3D. However, such content is rare and 3D is anyway not so popular. I was outputting to only one display – TV. But this problem is fixed in v0.90.2. So no worries. |
#35308 | Link | |
Please install the latest MadVR and lastest LAV (not sure if jRiver uses its own versions though, you might want to use MPC-BE to be able to test the independent versions of LAV and MadVR) and report what MadVR displays in the OSD, just to be sure everything is working as it should. It should report 3D both for content and rendering, which is what it does on my system. Also does your display switch to 1080p24 (FP)? Does it work in 3D with PowerDVD or similar? You can install a demo of PowerDVD if you don't own it, just to make sure your system and display are able to play 3D properly.
#35309 | Link | ||
warpsharpened
Scaling (only) in linear light is only useful for downscaling in case anyone was wondering why the option was replaced. Sigmoidal upscaling actually implies scaling in linear light. Remind us again what's wrong with using the default settings for those? |
#35310 | Link |
madshi - i check latest version, don't work 3D, only side-by-side picture.
I try set TV as primary device, set only only TV in system - don't help. Try reset settings - don't help.
#35311 | Link |
Is 3d supported in the profile rules? Cause watching 3D movies raises my rendertimes to 75ms and I get dropped frames because it selects my 23p profile...
#35312 | Link | |||||
Does any AMD or Intel user have 3D crashes? I think it's limited to NVidia? On my PC it doesn't occur, though (as usual ![]() Quote:
My projector doesn't support frame packed 3D at 50p/60p, AFAIK. I'm not sure if many other display do? Quote:
Do you use some sort of EDID override? It seems to me that your OS doesn't recognize that your display can do 3D. We need to find out why. Maybe if you don't have an EDID override now, it might be worth trying to do one which announces 3D support, so the OS and GPU actually understand that your display can do 3D? Not yet, but probably next weekend. |
#35313 | Link | |
#35314 | Link | |||
#35315 | Link | |
I have a PowerDVD license and uses to use it for 3D viewing but don't really like it, so I swapped to a Mede8er for 3D movies which handles 3D really well, but if I can get a LAV and MadVR combo to work then I'll probably switch to that because the zoom functionality is so seamless in changing aspect ratios on my scope screen. Good idea. I'll try to get some time tomorrow night to install mpc-be as a control just to make sure it isn't can issue with jriver mc and I how I've installed LAV. |
#35316 | Link | ||
https://msdn.microsoft.com/en-us/lib...s.85).aspx#pmp Using that path requires MediaFoundation and uses a special video renderer which you cannot replace and probably runs through different GPU driver routines and uses different APIs. Because of all that what PowerDVD/TMT do is *VERY* different to what madVR does. If we wanted to achieve the same result as PowerDVD/TMT, then MPC-HC/BE would have to use a MediaFoundation 3D splitter and decoder, which would have to be specially code-signed to work inside of the protect media playback path, and MPC-HC/BE would then have to use the stock OS video renderer, because the video renderer can not be replaced in the protected media player path. So this would be the opposite of using madVR. I can only work with the APIs that the OS offers to me, which is Direct3D11, which is the same that games etc can use. I'm pretty sure that games will not be able to output 3D on your PC, either. You didn't answer my question, though: Are you currently using an EDID override of some sorts? You could try going through the GPU control panel to see if anything is set to non-default values. Try "application controlled" everywhere, and default values where "application controlled" is not available. Also disable GSync, FreeSync, or other related extra features. Quote:
Are you really playing an MVC MKV? Or are you playing an SBS encoded MKV? Those are two *totally* different things. The new 3D support is atm only for MVC MKVs, which are straight remuxes from 3D-BluRay to MKV by using MakeMKV. MKVs encoded as side-by-side are not supported atm. |
#35317 | Link |
I not using any EDID override.
#35318 | Link |
About PowerDVD - it's not MediaFoundation. It's use a DirectShow mechanism.
#35319 | Link |
Do I understand it right then that the best practice currently is to have madVR's "forced film mode" set (as the most interlaced sources are telecined and, besides that, DXVA deinterlacing doesn't work properly in a number of cases) and to enable LAV's YADIF video mode deinterlacing when playing natively interlaced videos?
Windows 8.1 x64 Magically yours Raistlin |
#35320 | Link | ||
Ok. Might make sense then to analyze your display's EDID to double check whether it announces 3D support or not. Can you please create a report with this tool: http://www.entechtaiwan.com/util/moninfo.shtm Please use the "real-time" information for your 3D display, and do "File -> Save Report". Quote:
