Old 17th May 2017, 19:52   #43741  |  Link
Asmodian
Originally Posted by ipanema View Post
It seems a bit strange that madVR tries to run the configuration gui just because the input pin is being connected - is this normal behaviour ?
It seems a bit pointless, especially when the gui doesn't even appear.
Did it show up in system tray? The GUI loads minimized.
madVR options explained
Old 17th May 2017, 20:05   #43742  |  Link
This is perfectly normal behavior. You should probably tone down whichever "security" app you use.
Old 18th May 2017, 00:40   #43743  |  Link
ipanema
Thanks. It seems to start up in the tray, and then exits when the madVR is destroyed.
The dialog is not from a security application, it's the standard Windows warning when an unknown exe is executed. Un-ticking the "Always ask before opening this file" gets rid of future warning dialogs for the madHcCtrl.exe
Thanks again.
ipanema is offline   Reply With Quote
Old 18th May 2017, 01:08   #43744  |  Link
70MM
X Cinema Projectionist NZ
I use JR with madvr and it has a section were it automatically selects the different frame rates which I have ticked.
Do I also have to select 1080p23, 1080p24, 1080p50, 1080p59, 1080p60 in display settings in madvr?
If so and since I play everything back in 4K, do I have to write them differently?
70MM is offline   Reply With Quote
Old 18th May 2017, 01:41   #43745  |  Link
johnnylaiyee
johnnylaiyee's Avatar
I prefer Madvr's framerate control. You can type 2160p23 to work in 4k.
JR's framerate control sometimes crashes the playback for me.
johnnylaiyee is offline   Reply With Quote
Old 18th May 2017, 01:48   #43746  |  Link
70MM
So do you leave JRs frame rate switched to auto on or off with using the one on madvr?
So is this what I would do in madvr since everything is scaled to 4k?
2160p23, 2160p24, 2160p25, 2160p50, 2160p30, 2160p60, is that all?
Old 18th May 2017, 01:52   #43747  |  Link
johnnylaiyee
I leave the JR's settings to off.
And yea, those are good enough for all kinds of 4k playback.
BTW, do you use the video clock feature in JR?
Old 18th May 2017, 01:59   #43748  |  Link
70MM
Yes i have always used video clock in JR and it seems to work fine...
Old 18th May 2017, 02:02   #43749  |  Link
johnnylaiyee
Do you find any sound quality difference between bitstreaming and multi-channel PCM?
Old 18th May 2017, 02:07   #43750  |  Link
70MM
Not that I have noticed..
Old 18th May 2017, 06:28   #43751  |  Link
70MM
Is it more correct to set my 1080 video card on resolution to 23 rather than 24?
Old 18th May 2017, 06:45   #43752  |  Link
johnnylaiyee
Yes, 23 is suitable for 23.976 playback
Old 18th May 2017, 18:53   #43753  |  Link
dioxholster
why not 24? Would that produce stutter? 23.976 is an error anyway since its supposed to be 24, why do theyy still use it.
dioxholster is offline   Reply With Quote
Old 19th May 2017, 02:57   #43754  |  Link
i'm pretty sure cameras can do both.
Old 19th May 2017, 03:26   #43755  |  Link
kalston
Has to do with NTSC.
There's some true 24fps blu-rays out there still, just very few.
kalston is offline   Reply With Quote
Old 19th May 2017, 09:36   #43756  |  Link
mzso
Hello!
I've been having hangs using potplayer, when I quickly open files after each other, fast enought so the playback doesn't have time to start.
At last I thoroughly tested it and it apparently it depends on using madVR as a renderer. I reported it to the potplayer dev (with Potplayer and madVR configuration) and he claims it's a madVR bug.
I of course can't tell whether he's right or not, but I thought I'd mention it here.
Old 19th May 2017, 12:32   #43757  |  Link
takenori
just want to ask does anyone have a problem opening madvr settings with windows 10?
its a new build with windows 10 updated to the latest patch, so im wondering if i need to install anything else to make madvr works.
thanks
takenori is offline   Reply With Quote
Old 19th May 2017, 12:52   #43758  |  Link
jkauff
thanks
No problems here, but running the Restore Default Settings batch file has always fixed any madVR problems I've run into after a change to my system.
Just be sure to make a note of all your settings before you run it, if you can get to them. Best bet is to run "madHcCtrl.exe editLocalSettingsDontWait" command from the madVR folder.
Old 19th May 2017, 13:28   #43759  |  Link
takenori
it still wont appear.
i tried both that line and editLocalSettings but still the same.
the apps is running in the task manager and need to be force closed, but the window settings still not appearing
just found this and found the problem with nahimic 2. now it appears.
http://bugs.madshi.net/view.php?id=478
Old 19th May 2017, 19:38   #43760  |  Link
anta777
Rx470 50VT50
How to test the speed of a graphics card for an algorithm NGU sharp ?
Is interested in NVIDIA 1070-1080 vs AMD RX 570-580.
anta777 is offline   Reply With Quote
