17th March 2014, 20:19 | #141 | Link |
Probably ;
défaite : ok tes : ko (seen as "les") Astonishing because in both cases, the t is followed by a e. I don't know if a dictionary is used during OCR, if yes I understand that défaite is not seen as défaile because défaile does not exist in french, while les and tes both exist. |
29th March 2014, 09:27 | #142 | Link |
Nikse555, is it much work to make SE be able to remember, and preferably save and load settings in the SUP export window? It doesn't seem to remember all the settings, even within the same session. At least framerate and shadow alpha channel are defaulted back every time.
13th April 2014, 13:46 | #144 | Link |
Sorry, I cannot change a lot about how Tesseract works - for more info about Tesseract go here: https://code.google.com/p/tesseract-ocr/
I'll try to make SE remember all values from export in next version... SE 3.3.15 is out - sub/idx files created by SE should now work in handbrake + gpac/mp4box - thx Ryan for fixing this (added an extra byte of value 255 in image data |
14th April 2014, 08:29 | #146 | Link |
To make it as close to perfection as it may be, it may also remember the position of the DVB subtitles (by default in the middle). Sometimes the subtitles are placed under the character that speaks, to help better identifying it. Others use different colours.
Born in the USB (not USA) |
19th April 2014, 00:12 | #147 | Link | ||
Windows 8.1 (x64) - German
Subtitle Edit 3.3.15 (NET4) ---> 1) NET 2-3.5 crashed on starting OCR via Tesseract, I had to switch to the NET4-version. Doesn't make any sense since all .NET-versions are included in Windows 8.1 2) Error on using OCR via image compare. Quote:
3) Installed German dictorary, started OCR via Tesseract -> error Quote:
29th April 2014, 17:59 | #148 | Link |
Hi guys,
The "OCR via image compare" is surely broken in SE 3.3.15... sorry about that. I was working on better image->letter splitter + more compact/faster file format. The Tesseract should still work though... just don't install Tesseract via the installer: http://www.nikse.dk/SubtitleEdit/Help#issues Tesseract should not have anything to do with the .net framework - and win 8 strangely only included .net framework 4.5 last I checked. (programs compiled to .net framework 2.0 works on machines with .net framework 2-3.5, programs compiled with .net 4 works on machines with .net framework 4-45 - but perhaps .net programs can compile to native soon: http://msdn.microsoft.com/en-US/vstudio/dn642499.aspx ) |
30th April 2014, 07:00 | #149 | Link |
SUP output not consistent
Hi Nikse555
I encountered playback issues in MPC-HC with SUP files in mkv container. Within the same sup, some lines are displayed, others not. Now, discarding if MPC-HC has some subtitle issues or not, doing some testing I did find that the SUP output of SE is not consistent. I exported an srt file as SUP several times - with exactly the same export settings of course. The output files show different hash-check numbers. Now, I do not know if this has something to do with the problems in MPC-HC. I checked several same outputs of EasySUP and GoSUP and all SUP files show the same hash-check numbers. VLC and my Dune mediaplayer play SE created SUPs without problems though. I also used them while authoring blu-ray. The burned disks play fine; no subtitle problems. Any thoughts, please? Thanks in advance |
13th May 2014, 14:07 | #150 | Link |
Hi Nikse,
- perhaps this asks for a lot of code, but is some kind of "export/import settings" option on the agenda ? - Another problem, using Dutch subtitles, the "Fix common errors..." (Fix common OCR errors) capitalizes instances where a line starts with 't (dutch abbrev. of the English word It), Example : Code:
't Is geen rugzaktoerist, hè? 't Was alsof ik voor 'n afgrond stond. Code:
'T Is geen rugzaktoerist, hè? 'T Was alsof ik voor 'n afgrond stond. Last edited by Betsy25; 13th May 2014 at 14:27. |
13th May 2014, 15:16 | #151 | Link |
I remember a strange behaviour of SE 3.3.13
when loading a .M2TS file with another ending, as it comes from the receiver, it yields an error message that the file is too big. however, should I replace the ending of thet file with .TS it works as intended.
16th May 2014, 13:25 | #152 | Link |
Some more dutch abbrevs.
Doh, Sorry for the incompleteness Nikse,
For dutch language, the same (as 2 posts above) is actually true for the following conditions (same rules apply as for 't abbrevs at start of sentence) 'k : (abbrev. for "Ik" (in English : "I" ) Example : 'k Heb = I have 'm : (special abbrev. for "Hij" (in English : "He" ) Example : 'm Heeft = He has 'n : (abbrev. for "Een" (in English : "An" ) Example : 'n Appel = An apple 'r : abbrev. for "Haar" (in English : "Her" ) Example : 'r Haar = Her hair That's all, no other special abbrevs. exist in dutch language Last edited by Betsy25; 16th May 2014 at 22:01. |
17th May 2014, 20:41 | #153 | Link | |
's Avonds
Roelofs Coaching |
19th May 2014, 14:32 | #155 | Link | |
Roaming profile
I like having parallel installations, in case a new install breaks something, and after installing 3.3.15 (from zip), I cannot start my 3.3.14 installation (image OCR is broken in 3.3.15). 3.3.14 barfs on the 3.3.15 config file. See attachment. |
27th May 2014, 00:04 | #156 | Link |
@Nikse555
what differentiates choose "Box for each line" or "one box" on border style? I see no distinction when export, I have black box in all xml/png regardless of which option I choose. It was nice to see that too in vobsub export option But I think it is better to add this option as an option in the context menu as a tag like italic or bold tag and then when export read this tag and apply the style like italic or bold do when export. Last edited by mood; 27th May 2014 at 00:23. |
27th May 2014, 18:05 | #157 | Link |
@jsa: SE portable should not use the roaming profile... unless you install it under "Program files".
@mood: "Box for each line" makes a box behind each lines where "One box" just makes one box - you can only tell the difference if you have multiple lines. OK, I've added "One box" for vobsub too. It's always been possible to make boxing via SSA/ASS for single lines, but I've added it in the context menu for the list view too (right click in the list view in the export window). thx for testing Compile it from Github or try latest beta here: http://www.nikse.dk/SubtitleEdit.zip |
27th May 2014, 22:15 | #158 | Link | |
If you select other line in list view the "one box" disappears even still the tag <BoxSingleLine> and not see the box in exported sub. when I say add this to context menu a mean in main list view and not in list view on export window. adding this to the list view of export window it is not practical Last edited by mood; 27th May 2014 at 22:17. |
2nd June 2014, 15:18 | #159 | Link | |
C:\Program Files (x86)\Utils\SubtitleEdit\3.3.15\ This is under 'program files', but not where a normal install would place it. This used to work with local settings, but does not any more. I tried moving the folder to a different place (not under 'program files'), and now a local settings.xml file is used. |
5th June 2014, 09:31 | #160 | Link |
I have a little problem when export the subtitle. When I watch the movie (Avatar) with .srt subtitle file, it match at all period. But when I export the subtitle to .sup or xml/png to muxing in Scenarist, the subtitle not match anymore. At the beginning of the movie, it's match. At the middle, the subtitle was late about 1s. And at the end of the movie, the subtitle was late about 3s or 4s.
So please fix that problem. P/S: the subtitle edit still not save the configuration in export xml/png mode. I will try the latest version and report later. |
