29th June 2020, 08:02 | #1141 | Link |
@GCRaistlin
Use the US English dictionary for OCR, select [Fix OCR errors] and [Try to quess unknow words] as a result of which you will receive your Code:
I'll <i>vafangool</i> you!
Sorry for my mistakes - I'm using a translator. |
16th July 2020, 17:28 | #1145 | Link |
Still having major issues with music notes in the latest beta version for tesseract/binary.
http://www.mediafire.com/file/2pyfyn...ample.sup/file There is a file that I've had the issues on. |
18th July 2020, 09:05 | #1146 | Link |
@Tormento: I've tested your sup file and it works fine... I don't get the strange replacements that you get, so you should probably do a clean install (delete all old SE files before - including those in %appdata%\Subtitle Edit).
EDIT: Also, latest beta has improved casing in OCR for italian letter "Ú": https://github.com/SubtitleEdit/subt...leEditBeta.zip @jwl_4049: You should request better support for music symbols for tesseract here: https://github.com/SubtitleEdit/subt...leEditBeta.zip Or you could try "nOCR" or "Binary image compare"... Last edited by Nikse555; 18th July 2020 at 09:07. |
18th July 2020, 10:00 | #1147 | Link | |
Acid fr0g
You are right about "Es", I have found it in ita_OCRFixReplaceList_User.xml somehow...
The "i" issue comes from ita_OCRFixReplaceList.xml, where "l" is replaced by "i" and sometimes a "I" is OCR as "l". Quote:
We do have ù and Ù.
@turment on Telegram Last edited by tormento; 18th July 2020 at 10:32. |
19th July 2020, 06:35 | #1148 | Link |
A simple save from ASS to SRT
Not hijacking anything. I just need to know if this is the major forum discussion for Subtitle Edit. I am just beginning to do translations. Some online tools are available. But my current need is to get an ASS file which is translated English to Polish saved as SRT or VOB that is recognized by MKVToolnix.
I'm only getting a text save in Subtitle Edit. Please give the steps of getting this kind of save. And thank you for this amazing tool. |
19th July 2020, 07:21 | #1149 | Link | |
I'll look more into it tomorrow when I get off. Sent from my SM-G986U1 using Tapatalk |
19th July 2020, 08:32 | #1150 | Link |
@tormento: I could not find lines where "l" is replaced by "i"... could you give some line numbers? (thx about the italic letter accent U)
@loninapleton: You can open the ASS file and change format in the toolbar to "SubRip (.srt)" (SubRip is the topmost format in the drop down list). You can also convert multiple ASS files to SubRip (.srt) via Tools -> Batch convert or by using command line convert. @jlw_4049: If you cannot see the OCR method "nOCR" then you probably don't use SE 3.5.16? |
19th July 2020, 13:44 | #1155 | Link | |
Acid fr0g
WTF. Apart from wrong É (it should be È) it looks like your OCR hasn’t my same issue. Need to sort this thing out. Perhaps some regional setting? I had problems with an AVS script some time ago.
@turment on Telegram |
19th July 2020, 13:48 | #1156 | Link | |
19th July 2020, 18:52 | #1157 | Link |
@jlw_4049
Here I wrote what needs to be done to access nOCR https://forum.doom9.org/showthread.p...45#post1913645
19th July 2020, 22:56 | #1158 | Link | |
20th July 2020, 16:03 | #1160 | Link |
Acid fr0g
Update: I have tried to write a single line srt manually and to use Fix common errors on it, excluding the OCR process.
I have found that if I save "i" letter to Names (it_names_user.xml), SubtitleEdit wants to change "I" to "i". Usually I save single letter words "i", "a", etc to Names because they can't be found in Italian dictionary and stops the OCR processing. Any idea to solve this issue?
