Old 3rd April 2020, 17:06   #5361  |  Link
pinterf
Just built a new version from mpp, but I will do tests later
pinterf is offline   Reply With Quote
Old 3rd April 2020, 17:18   #5362  |  Link
real.finder
Originally Posted by gispos View Post
MPP requires a 'return last' in the last section for NEO builds.
Have you tried?
Something has changed from the previous version. Could this cause problems for some people?
More information
example 1 (this was still possible without 'return')
LWLibavVideoSource(SourceFile)
return dummy()
function dummy(clip clp){
clp
example 2 (This was possible, not now)
#dummy()
clp
example 3 (MP_Pipeline needs now also return)
MP_Pipeline("""
### inherit start ###
SourceFile = String(ScriptDir()) + "Goblin.mkv"
### inherit end ###
LWLibavVideoSource(SourceFile, cache=False)
### platform: Win32
HDRAGC()
### platform: Win64
audio=LWLibavAudioSource(SourceFile, cache=False)
audioDub(last, audio)
return last
sharpen(0.40)
thanks that seems make it work!
mp_pipeline("""
ColorBars(width=640, height=480, pixel_type="yv12")
admfilter()
Prefetch(4)
return last
My Avisynth Stuff
Old 4th April 2020, 12:04   #5363  |  Link
tormento
Acid fr0g
tormento's Avatar
Would you please create an additional autoload folder "AVSI" on next releases?
I probably suffer from OCD but I'd like to put them in a different directory.
@turment on Telegram
Old 4th April 2020, 12:26   #5364  |  Link
StainlessS
StainlessS's Avatar
Tormento,
AvsInit.avsi allows you to use a GIMPORT directory where avs/avsi scripts are auto loaded (by AvsInit), and makes it possible to have scripts that will load
under avs v2.58/2.60/2.61 Std with GScript, OR, under Avs+, either x86 or x64, and where all can use Gscript style constructs [for/While/If].
Can have a GIMPORT in plugins directory specifically for a single version of Avs, or where using G2K4 Avisynth Universal Installer, a
universal GIMPORT directory used by all avs versions, dont need same identical scripts in all avs version plugins.
Also some other functionality.
AvsInit.avsi :- https://forum.doom9.org/showthread.p...hlight=AvsInit
EDIT: Some functions callable from inside AvsInit or user scripts.
        AvsInit_LoadPlugin(fn)                  Load CPP dll with filename FN, sending debug stuff (success/fail) to DebugView window.
                                                [Avs+ will also load C plugins].
        AvsInit_LoadCPlugin(fn)                 Load C dll with filename FN, sending debug stuff (success/fail) to DebugView window.
        AvsInit_Import(fn)                      Import[GImport() if GScript Present] avs/avsi script with filename FN, sending debug
                                                Directory of files load/Import functions. Return total number of scripts imported,
                                                or dll's loaded,
        AvsInit_DImport(Dir)                    Import[GImport() if GScript Present] All avs/avsi scripts in folder Dir, sending debug
        AvsInit_DLoad(Dir)                      Load all CPP/C plugin dll's in folder Dir, sending debug stuff (success/fail) to
                                                DebugView window.
                                                Both DImport and DLoad, funcs may be of use in user functions to satisfy some script
                                                dependency, where a complex script requires multiple dll's or script loaded.
        The Import style functions use GImport() when GScript is available, otherwise Import(). Any scripts imported should have any
        GScript style wrappers removed, eg
        >>>>    CODE  >>>>
            GScript("""         # <<<<<<<<<<========= REMOVE THIS LINE
                Some gscript stuff, if/else/for/next while etc
            """)                # <<<<<<<<<<========= REMOVE THIS LINE
        <<<< END CODE <<<<
        With GScript wrappers removed and imported via this library, then should be able to use same scripts in any version of avs
        standard(with Gscript plugin) or avs+, whether it be avs v2.58, avs v2.60/2.61 Standard, avs+ x86 or x64.
EDIT: With AvsInit, you only need the AvsiInit.avsi in plugins, all others can be in local or global GIMPORT (or some other name) directory.
I sometimes post sober.
Old 4th April 2020, 13:29   #5365  |  Link
tormento
Acid fr0g
tormento's Avatar
Thanks for your kind reply. I already put my AVSI in plugin64 folder, so they are autoloaded.
A question: why to have such a complicate solution as AvsInit when it would be way easier to have a separate AVSI folder?
Old 4th April 2020, 14:55   #5366  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by StvG View Post
url=https://cloud.owncube.com/s/WdARWHb9epfGRwM]AddGrain[/url] port of the vs version.
Is it the r7 VS version?
Old 4th April 2020, 15:00   #5367  |  Link
pinterf
MP_Pipeline with Avisynth+ colorspace support
https://github.com/pinterf/MP_Pipeli...eases/tag/0.20
0.20 (20200404) pinterf
* Avisynth+ support
  Add version resource
  Build: move to VS2019, v142 and v141_xp toolset
Old 4th April 2020, 15:35   #5368  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
* Avisynth+ support
OMG you have no idea how long I wished for someone to do this.
I tested it on XP as well with 16bit and even 32bit as bit depth along with things like RGBPS and RGBAPS: they all work fine.
Thank you! Thank you! Thank you!! *_*
Now the cherry on the cake would be audio support. After that, MPP is gonna be perfect! Please, I beg you to do that as this way we can leave it as it is for the years to come and it would actually save me time by avoiding to make an additional separate script without MPP, just for the audio.
p.s Ferenc, if you have a LinkedIn account I'll definitely leave you a good recommendation for everything you've done for this community.
Old 4th April 2020, 15:52   #5369  |  Link
real.finder
maybe not audio alone, but also with these https://github.com/SAPikachu/MP_Pipeline/issues/1
My Avisynth Stuff
Old 4th April 2020, 17:35   #5370  |  Link
real.finder
* Avisynth+ support
thanks
but it's still need return last, so it's avs+ test problem? will it stay like this? there are another examples in gispos post in another cases not only mpp
My Avisynth Stuff
Old 4th April 2020, 19:28   #5371  |  Link
StainlessS
StainlessS's Avatar
Main reason for AvsiInit is below in BLUE
AvsInit.avsi v1.09 - 27/Jan/2020
Script to perform some tasks before user script is executed.
Also makes a few script functions later available to any other user scripts.
Also assists in removing AVS+ GScript incompatibilites so that an avsi script may run under Avs+, or when Gscript installed, then also v2.58, v2.60.
You are looking at it with too limited a view, separate script directory loading is incidental.
Old 4th April 2020, 19:33   #5372  |  Link
real.finder
if anyone want to test admfilter (or anything else) with MT, GRunT update is needed http://www.mediafire.com/file/77urom...0.2tst.7z/file
its the one that pinterf made years ago
My Avisynth Stuff
Old 5th April 2020, 07:06   #5373  |  Link
pinterf
Thanks, but I'm collectiing kudos only on Strava
Old 5th April 2020, 07:42   #5374  |  Link
StvG
anyone know why? is the VS version has the same output?
VS version has identical output.
It's a port of r7 VS version.
StvG is offline   Reply With Quote
Old 5th April 2020, 08:06   #5375  |  Link
real.finder
so that mean VS one was already has bug
My Avisynth Stuff
Old 5th April 2020, 09:33   #5376  |  Link
StvG
VS r1 has identical output to AddGrainC 1.71.
The difference comes from here.
Old 5th April 2020, 10:26   #5377  |  Link
Music Fan
I'd like to re-install Avisynth+, I still get an old version, but I don't know if I have to select the simple or the vcredist version.
When should the vcredist version be used ?
That's for Win 7 64.
Music Fan is offline   Reply With Quote
Old 5th April 2020, 11:23   #5378  |  Link
tebasuna51
tebasuna51's Avatar
If you don't have Microsoft Visual C++ 2015-2019 Redistributables installed (Control Panel -> Programs...).
tebasuna51 is online now   Reply With Quote
Old 5th April 2020, 12:32   #5379  |  Link
manolito
manolito's Avatar
Tip:
Always use this All-In-One VC++ redist package from Abbodi and be happy...
https://github.com/abbodi1406/vcredist/releases
Old 5th April 2020, 12:40   #5380  |  Link
Music Fan
Thanks ; if I install this package, does it mean I don't have to take the vcredist version ? No risk of conflict if I install it anyway ?
