Old 31st August 2009, 23:10   #241  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Originally Posted by Dark Shikari View Post
I can not believe what I just saw, this is amazing. Can you explane switches?
For example i want to use 4 slices for BD compilancy what to need to set?
Thanks, Thanks,Thanks, Thanks,Thanks, Thanks,Thanks, Thanks
btw what gonna be for NAL HRD patch?
shon3i is offline   Reply With Quote
Old 31st August 2009, 23:14   #242  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Originally Posted by shon3i View Post
OMFG I can not believe what I just saw, this is amazing. Can you explane switches?
--slices 4?
Old 31st August 2009, 23:19   #243  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
--slices 4?
Ok
is there any reason for other two switches?? Is there some rule about?
Old 31st August 2009, 23:21   #244  |  Link
Dark Shikari
x264 developer
Ok
--slice-max-size is useful for RTP streaming on clients which insist on slices smaller than MTU. --slice-max-mbs is useful if you need to specify exact slice sizes instead of a general number per frame.
Old 31st August 2009, 23:39   #245  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
OK one more info
how much quality can drop? what about mt method
Old 31st August 2009, 23:47   #246  |  Link
Lyris
I just choked on my lunch!
Time to give this a whirl!
Lyris is offline   Reply With Quote
Old 1st September 2009, 00:13   #247  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
/cheer!
These are all my personal statements, not those of my employer :)
Old 1st September 2009, 00:42   #248  |  Link
Lyris
Anyone compiled yet? I'm used to getting my software spoon-fed to me and am getting failed hunks following this guide.
Old 1st September 2009, 00:42   #249  |  Link
Dark Shikari
x264 developer
The NAL-HRD patch likely needs updating.
Old 1st September 2009, 00:47   #250  |  Link
Lyris
Yeah, that's the one I was trying to apply. D'oh.
Old 1st September 2009, 01:17   #251  |  Link
Chengbin
Wow, Dark Shikari, you're an amazing guy! You said it was a lot of work, and 2 weeks later we get it! It's the summer of features for x264!
Anything else missing for x264?
Chengbin is offline   Reply With Quote
Old 1st September 2009, 01:19   #252  |  Link
Dark Shikari
x264 developer
I don't think I ever said that slicing was actually that much work...
Old 3rd September 2009, 23:09   #253  |  Link
crypto
@DVBPortal
crypto's Avatar
This is amazing. Thanks Dark Shikari, for the slicing patch.
crypto is offline   Reply With Quote
Old 23rd September 2009, 19:37   #254  |  Link
moviefan
One question that has popped up when I tried to find a workaround for the unfinished nal-hrd patch: Can I encode without the nal-hrd patch and then run the stream through h264info checking only the "Add Picture Structure" option? Or are there any problems with that method?
moviefan is offline   Reply With Quote
Old 25th September 2009, 13:10   #255  |  Link
Trahald
Wewkiee
Trahald's Avatar
As a way to get some software to accept your file maybe. Anything h264info spits out is guaranteed not to be perfect buffer wise because the original stream didnt consider the data being added is buffer calculation. having said that, as long as buffer usage wasnt pinned to max, that shouldnt be an issue for most streams. Best bet will be to wait, but since you are probably just making backups for yourself, you will have to judge if imperfection will be acceptable for you.
...yeah...but...why on earth would I compare apples with apples?
Trahald is offline   Reply With Quote
Old 25th September 2009, 13:16   #256  |  Link
moviefan
Okay, so the patch does not simply add some information to the stream but also influences calculations in the encoding process. I do seek BD compliance rather than the mere acceptance of my stream by some software, so waiting seems the only option. Waiting for a final/corrected version of the patch implies what kind of time range? Days, weeks, months...? I of course don't expect a date, but just a vague estimation... Actually, is there any discussion forum where developers exchange their ideas and where progress of things can be looked at?
Old 25th September 2009, 15:52   #257  |  Link
Trahald
Wewkiee
Trahald's Avatar
IRC is probably the best place right now. #x264dev on freenode
authoring, blu-ray, compliant, verified, x264
