18th January 2011, 05:36 | #1721 | Link |
@Laeee---
Try this: ■ Update latest version of DirectX http://www.microsoft.com/downloads/e...PF_111SXX02933 ■ Update latest driver of motherboard/sound driver; ■ Uninstall current version of ffdshow; ■ Try to download latest version of ffdshow clsid revision http://sourceforge.net/projects/ffds...d.exe/download Reboot everything... Retry!
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
19th January 2011, 14:05 | #1723 | Link |
RE Chipmunk sounds: As 8ternity suggested, I checked my DirectX version, it was OK, I use DriverMax to keep my drivers up to date and there were no new updates available. I uninstalled FFDShow & reinstalled it. I also re-installed AVSTODVD. None of these helped. Next, per MrC and the FAQ, I installed the Preferred Filter Tweaker. I changed every option from Microsoft to FFDShow – I got a couple of warnings about Microsoft things may not work, and ignored them. When the disk completed, I used VLC media player (since Windows Media Player did not recognize the disk) and it worked! The filters seem to be the issue in Windows 7! Tonight I may reset all of the filters & be a bit more selective on the ones I switch to FFDShow. Thanks to all for the help!
20th January 2011, 03:23 | #1724 | Link |
It's not necessary a fail of windows 7 but only a better compatibiliy to read hd contents from bluray, hddvd and HD contents. It's a good thing that windows has think about that and had codecs for hd contents.
27th January 2011, 17:25 | #1728 | Link |
AVStoDVD Dev
Release 2.3.4 is available to download
Change log: - Some bugs fixed - Added 'Auto Adjust Delay' option in 'Preferences'/'Audio' - Added 'Auto Adjust Delay' option in 'Title Edit'/'Audio' (adjustment is done during Audio encoding step) - Added 'Copy Title Name to DVD Label' command button in 'Title Edit'/'General' - Added FFmpeg as 'AC3 Audio Encoder' in 'Preferences'/'Audio' - Added 'Fix SRT' routine for authored subtitles (mandatory, at runtime) - Added Channels number and BitRate check after Audio encoding. Upon failure, backup Audio encoding routine (FFmpeg based) is started - Added tooltips to Progress Status Window icons - Added Drop Shadows customization for 'Play All' and 'Arrows' buttons in DVD Menu Wizard - Added (again!) ImagoMPEG-Muxer to multiplex AC3 and MP2 Audio streams (instead of FFmpeg) - Moved all Skins but 'Default' as add-on packages at AVStoDVD SourceForge webpage - Moved all Menu Templates but 'Menu in Black' as add-on packages at AVStoDVD SourceForge webpage - Added 'Canny_Suite_100_by_JohnJ' (33 new Menu Templates) as add-on package at AVStoDVD SourceForge webpage (many thanks to JohnJ) - Removed 'cachefile' command when FFMpegSource is used as 'AVS Source Filter' - Improved DVD burning success detection (ImgBurn log parsing) - MediaInfo updated to 0.7.41 - Haali Media Splitter updated to 1.10.348.15 - ImgBurn updated to 2.5.5.0 Suggestions and feedbacks are always welcome Bye |
28th January 2011, 05:27 | #1729 | Link |
FishmanMod Android Dev
Thank You MrC !!!
"Cinderella story, out of nowhere, former greenskeeper, now about to become the Masters champion. It looks like a mirac- it's in the hole!" |
28th January 2011, 22:23 | #1730 | Link |
AVStoDVD Dev
SourceForge links are broken. I will try to fix them shortly. Meanwhile use following links:
AVStoDVD 2.3.4 Installer Package AVStoDVD 2.3.4 NoInstall Package AVStoDVD 2.3.4 Source Code Bye |
29th January 2011, 07:17 | #1731 | Link |
Great, i need to finalised some detailed about some icon i think i need to change and i need some days off to retake some energy.... my backbain is drainning all my energy!..
29th January 2011, 14:51 | #1732 | Link |
Hi Mrc!
I've had an issue about audio has been missing over like the first 15minutes, after that the audio start and it has been a lot desync. Here the log: Code:
<2011-01-29 01:23:33> START PROCESS <> <2011-01-29 01:23:33> PROJECT SETTINGS DVD Video Standard: NTSC DVD Titles number: 1 DVD Size: 4450/4450 MB (100%) DVD Output Setup: DVD Folder DVD Label: DEATH_RACE_2 DVD Menu: No Menu Output Folder: E:\DVD-TEMP Delete Temp Process Files: Yes Delete Working Files: Yes Edit Command Parameters: No Post Process Task: Show Progress Status window PREFERENCES MultiThread: 1 AVS Source Filter: A2DSource AVS UpSize/DownSize Filter: Spline36Resize/Spline36Resize Video Resolution: 0 Video BitRate Min: 2500 Video BitRate Level 1: 6500 Video Profile Level 2: 6500 Video BitRate Max: 8500 Keep DVD Compliant Video: 1 AC3 Audio Encoder: 0 PAL SpeedUp: 0 Force FFmpeg for Long Audio: 1 DVD Audio Format: 0 DVD Audio BitRate: 448 Keep DVD Compliant Audio: 0 Normalize Audio: 0 Auto Delay Audio: 1 DVD Audio Language: FR - French DVD Subs Language: FR - French DVD Subs Font: Tahoma 18pt Bold Chapters Interval: 5 Use Source Chapters: 1 DVD Burning Drive: F: Optiarc DVD RW AD-7241S 1.03 DVD Burning Speed: 4x Auto Erase DVD RW: 1 Save Log file: 1 Save General Settings: 0 Unload ActiveMovie library: 0 Adjust ffdshow mixer: 1 <> <2011-01-29 01:23:33> TITLE 1 SOURCE FILES Video: E:\BLURAY\Death Race 2 FRENCH DTS 720P F DVD5.AVCHD\AVCHD\BDMV\STREAM\00000.m2ts Info: AVC - 5081 kbps - 1280x720 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 1:40:17 hours - 144281 frames Audio 1: E:\BLURAY\Death Race 2 FRENCH DTS 720P F DVD5.AVCHD\AVCHD\BDMV\STREAM\00000.m2ts Info: DTS - 768 kbps - CBR - 6ch - 48000Hz - 24bit - 1:40:17 hours - Internal Subs: [MediaInfoLib - v0.7.41] <> <2011-01-29 01:23:33> AVISYNTH SCRIPT Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi") Video = A2DVideoSource("E:\BLURAY\Death Race 2 FRENCH DTS 720P F DVD5.AVCHD\AVCHD\BDMV\STREAM\00000.m2ts", CacheFolder="E:\Temp", FrameRate=23.976, VFR=false) Audio = A2DAudioSource("E:\BLURAY\Death Race 2 FRENCH DTS 720P F DVD5.AVCHD\AVCHD\BDMV\STREAM\00000.m2ts", CacheFolder="E:\Temp") Video = Video.ConvertToYV12 #Using DGPulldown/HCenc to upsize FPS Video = Video.Spline36Resize(720,480) Audio = Audio.DelayAudio(600) AudioDub(Video, Audio) <> <2011-01-29 01:23:33> START VIDEO ENCODING OPERATIONS Encoding Profile: HCenc VBR 2-pass Target Video FileSize: 4031.8 MB HCenc Parameters: -ini "E:\Temp\DEATH_RACE_2_0_DEATH_RACE_2.HCenc.ini" HCenc ini file: *INFILE E:\Temp\DEATH_RACE_2_0_DEATH_RACE_2_1.avs *AVSRELOAD *OUTFILE E:\DVD-TEMP\DEATH_RACE_2_0_DEATH_RACE_2.m2v *LOGFILE E:\Temp\DEATH_RACE_2_0_DEATH_RACE_2.HCenc.log *MAXBITRATE 9000 *BITRATE 5620 *PROFILE BEST *ASPECT 16:9 *PROGRESSIVE *TFF *PULLDOWN *BIAS 60 *DC_PREC 9 *MATRIX MPEG *AQ 1 *LUMGAIN 1 *SMP *PRIORITY IDLE *WAIT 2 <> <2011-01-29 02:16:02> END VIDEO ENCODING OPERATIONS A2DVideoSource: DirectShowSource Created File: E:\DVD-TEMP\DEATH_RACE_2_0_DEATH_RACE_2.m2v (4032.9 MB) OUTPUT VIDEO INFO: MPEG-2 Video - 5661 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 1:40:17 hours - 144278 frames <> <2011-01-29 02:16:02> START AUDIO ENCODING OPERATIONS (Track 1) Wavi+Aften Parameters: "E:\Temp\DEATH_RACE_2_0_DEATH_RACE_2_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "E:\DVD-TEMP\DEATH_RACE_2_0_DEATH_RACE_2_1.ac3" <> <2011-01-29 02:20:33> END AUDIO ENCODING OPERATIONS (Track 1) A2DAudioSource: DirectShowSource Created File: E:\DVD-TEMP\DEATH_RACE_2_0_DEATH_RACE_2_1.ac3 (353.4 MB) OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6ch - 48000Hz - 16bit - 1:50:17 hours <> <2011-01-29 02:20:33> START DVD AUTHORING OPERATIONS BatchMux Parameters: -arglist "E:\Temp\DEATH_RACE_2_0_BatchMux.ini" BatchMux ini file: -d "E:\DVD-TEMP\DEATH_RACE_2_0\VIDEO_TS" -mxp "E:\Temp\DEATH_RACE_2_0_MuxMan.mxp" -l "E:\Temp\DEATH_RACE_2_0_MuxMan.log" -muxman "C:\Program Files (x86)\AVStoDVD\MuxMan" -prio LOW -v "E:\DVD-TEMP\DEATH_RACE_2_0_DEATH_RACE_2.m2v" -vidmode LB -a1 "E:\DVD-TEMP\DEATH_RACE_2_0_DEATH_RACE_2_1.ac3" -a1lang fr -cellfr "E:\DVD-TEMP\DEATH_RACE_2_0_DEATH_RACE_2_Chapters.txt" -progfr "E:\DVD-TEMP\DEATH_RACE_2_0_DEATH_RACE_2_Chapters.txt" -chapfr "E:\DVD-TEMP\DEATH_RACE_2_0_DEATH_RACE_2_Chapters.txt" <> <2011-01-29 02:25:00> CHECK DVD SIZE DVD Folder (actual) Size: 4440.6 MB vs Estimated Size: 4450 MB -> 0.2% undersize vs Assets Size: 4386.3 MB -> OK <> <2011-01-29 02:25:00> END DVD AUTHORING OPERATIONS Created Folder: E:\DVD-TEMP\DEATH_RACE_2_0 (4440.6 MB) <> <2011-01-29 02:25:00> Log file created by AVStoDVD Release 2.3.4 <>
5th February 2011, 15:35 | #1734 | Link | |
Samething when i click add to search a video; and play in the open box to preview the movie does the same. Media player play wells the dts audio track; but windows media player 12 not play the dts audio track. here the source mediainfo; Code:
General ID : 1 Complete name : E:\BLURAY\Death Race 2 FRENCH DTS 720P F DVD5.AVCHD\AVCHD\BDMV\STREAM\00000.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 4.36 GiB Duration : 1h 40mn Overall bit rate : 6 218 Kbps Maximum Overall bit rate : 35.5 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Duration : 1h 40mn Bit rate mode : Variable Bit rate : 5 081 Kbps Maximum bit rate : 25.0 Mbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.230 Stream size : 3.65 GiB (84%) Writing library : x264 core 104 r1683 62997d6 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5081 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=vbr Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS Format/Info : Digital Theater Systems Duration : 1h 40mn Bit rate mode : Constant Bit rate : 755 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Stream size : 541 MiB (12%) Language : French Text ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Language : French
5th February 2011, 20:20 | #1735 | Link | |
AVStoDVD Dev
Did you try to switch from A2DSource to FFMpegSource? If not, try it, but be patient because FFMS needs to create the file index. Bye |
6th February 2011, 03:07 | #1736 | Link |
What does this mean? Sorry... i've not really understand whats graphedit..
I has the version 3711 of ffdshow clsid revision. I will update it and reboot and retry everything. It's not the first time i say that ffshow revisions add trouble with some video and audio issue.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 6th February 2011 at 03:10. |
6th February 2011, 14:02 | #1737 | Link | ||
AVStoDVD Dev
Bye |
6th February 2011, 19:06 | #1738 | Link |
Hi Mirc,
I've uninstall version 2.3.4 and get back to 2.3.3. and everything are okay. Samething for Death Race 2! http://i480.photobucket.com/albums/r...ph_result1.jpg Thanks... So it work in preview now with 2.3.3 release!
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 6th February 2011 at 19:12. |
