Old 24th April 2014, 20:28   #20101  |  Link
Hajnal
- Input BD size: 20.16 GB
- Approximate total content: [02:27:31.808]
- Target BD size: 4.36 GB
- Bitrate: 3,408 Kbs
wtf.....
Hajnal is offline   Reply With Quote
Old 24th April 2014, 20:32   #20102  |  Link
Yordan5
I wanted to see what quality I can expect from FRIM when pushed. It was good, may be not on par with x264 but still very good.
Yordan5 is offline   Reply With Quote
Old 24th April 2014, 21:21   #20103  |  Link
Ch3vr0n
wtf.....
wtf indeed. Where's the rest of the log.
And you do know that you're shrinking a 20GB of data onto a format that can only hold 4.36GB right. In order to achieve that, bdrb has to shrink to a format 5x less the original size. So the bitrate has decrease immensely
Ch3vr0n is online now   Reply With Quote
Old 24th April 2014, 21:25   #20104  |  Link
Yordan5
I've shrank 39Gb movies to 4.36Gb using BD-RB (x264) with very good results so nothing unsusual here. Wanted to put FRIM to the same test.
Old 24th April 2014, 22:33   #20105  |  Link
I think that's fair. I've done movies in that size range to BD-5 before using X264. They're not comparable to the quality you'd get on a BD-25, but they're pretty good. The notable thing is that, once again, the HW mode creates a mess.
Old 25th April 2014, 08:16   #20106  |  Link
AmigaFuture
AmigaFuture's Avatar
Cloud Atlas Subtitle/Chapters Bug?
[04/24/14] BD Rebuilder v0.46.14 (beta)
[21:55:20] Source:  CLOUD_ATLAS_00100
  - Input BD size: 34.67 GB
  - Approximate total content: [02:51:57.432]
  - Windows Version: 6.1 [7601]
  - Mode: MKV, Intact Video, DTS2AC3 or Keep AC3
  - Decoding/Frame serving: DGDecNV [4-way]
[21:55:22] PHASE ONE, Encoding
 - [21:55:22] Processing: VID_00057 (1 of 2)
 - [21:55:22] Extracting A/V streams [VID_00057]
 - [22:02:47] Reencoding video [VID_00057]
 - [22:02:47] Keeping original video (no reencode)
 - [22:02:47] Processing audio tracks
 - [22:06:48] Processing: VID_00058 (2 of 2)
 - [22:06:48] Extracting A/V streams [VID_00058]
 - [22:07:13] Reencoding video [VID_00058]
 - [22:07:13] Keeping original video (no reencode)
[22:07:13]PHASE ONE complete
[22:07:13]PHASE TWO - Rebuild Started
 - [22:07:13] Building ALTERNATE OUTPUT Structure
[22:41:57] - Encode and Rebuild complete
[22:41:57] JOB: CLOUD_ATLAS finished.
The resulting file shows 18 chapters, and the markers for the chapters end in the middle of VLC's seek bar, or any other software players seek area. Because the movie's length is showing as 5 hours plus. My HDTV as well as LG player..same. If I remove the English PGC with MKVMergeGUI the chapters show correctly all across whatever players Seek bar; LG player or Windows, Mac. Meaning, 2h 51m 57s vs 5h34m32s. Looks like a bug?
Noticing a SUP has a 0 size might have something to do with it?
04/24/2014  10:41 PM    <DIR>          .
04/24/2014  10:41 PM    <DIR>          ..
04/24/2014  10:02 PM    27,109,525,867 00057.track_4113.264
04/24/2014  10:02 PM     1,946,125,176 00057.track_4352.dts
04/24/2014  10:02 PM        41,571,513 00057.track_4608.sup
04/24/2014  10:02 PM        31,296,814 00057.track_4609.sup
04/24/2014  10:02 PM        37,301,387 00057.track_4610.sup
04/24/2014  10:07 PM     1,235,212,226 00058.track_4113.264
04/24/2014  10:07 PM                 0 00058.track_4608.sup
04/24/2014  09:55 PM               614 AUD_00057.meta
04/24/2014  10:06 PM       825,395,200 AUD_00057_4352.AC3
04/24/2014  10:02 PM               291 AUD_00057_4352.AVS
04/24/2014  10:06 PM               196 AUD_00058.meta
04/24/2014  10:23 PM               936 mChapters.chp
04/24/2014  10:07 PM               243 MUX_MOVIE_ONLY.meta
04/24/2014  10:02 PM               232 VID_00057.AVS
04/24/2014  10:02 PM               197 VID_00057.CHP
04/24/2014  10:01 PM         5,278,154 VID_00057.DGI
04/24/2014  10:07 PM               232 VID_00058.AVS
04/24/2014  10:07 PM                22 VID_00058.CHP
04/24/2014  10:07 PM           288,860 VID_00058.DGI
Update: I had BD-RB make another MKV output, leaving all the Subtitles enabled (English, French, Spanish) and singles for all.
Old 25th April 2014, 22:26   #20107  |  Link
mparade
Help
Just have reencoded a source (My Monsters, inc BD - SD extra video)using 3:2 pulldown (MPEG-2, 480i, 29,97fps, 153MB) getting the following results:
- converted to 1920x1080i (upresized), CRF=20, without IVTC and deinterlacing, 84,2MB - played back fine in powerdvd and popcorn-hour
- converted to 1920x1080i (upresized), CRF=20, with IVTC enabled, 40,7MB - video played back stalling while the audio was continuous through the timeline in powerdvd and popcorn-hour
- converted to 1920x1080p (upresized), CRF=20, without IVTC, SmoothDeinterlace enabled, 42,8MB - video played back very similarly as the previous
- converted to 1920x1080p (upresized), CRF=20, with IVTC and SD_PROGRESSIVE enabled, 40,4MB - video played back very similarly as the previous 2 ones.
I am a little bit confused about the similar "stalling effect" with all the last 3 results. If someone has an idea, it would be really appreciated.
Thank you!
Old 26th April 2014, 00:30   #20108  |  Link
What are you using for decoding? I've done hundreds of encodes from DVD to BD using iVTC, most with DGDecodeNV, and have had no problems. In fact, I just encoded 40 episodes from a series that were MPEG-2, 480i, 29.97 with iVTC today (resulting in 23.976 output).
Can you post the AVS file of the source that is causing the issue?
Old 26th April 2014, 10:06   #20109  |  Link
AmigaFuture
I haven't done any testing of FIRMEncode/Decode because I thought it is for 3D only. I skipped some of the chatter because I have some 3D+2D movies, but since I don't watch anything in 3D. But, JDobbs, yours comment about 2D is intriguing. So, I'll try it with my i7 930. I've never agreed with the saying, "If it isn't broke, don't modify/fix it." Talk about a recipe for stagnation and same ol' same ol'... ;-) So, on that note...I'll report soon.
Old 26th April 2014, 10:34   #20110  |  Link
mparade
DirectShowSource
I do not use DGdecNV because I do not have a CUDA enabled video card (AMD Firepro V4900).
Please find all the four avs files as a zip attachement from
which 3 causes very similar playback errors in all the 2 player devices I currently have. (PC with Powerdvd and Popcorn-hour C200 with it's own playback software).
I really appreciate your efforts!
Old 26th April 2014, 12:32   #20111  |  Link
mparade
I think the situation with 3:2 pulldown / hard telecined sources has become a kind of "standoff" for me.
DirectShowSource results = stalling video, audio OK
LAVF = cannot be used for frameserving by such sources
DGdecNV = cannot be used for frameserving because not
owning an Nvidia with CUDA video decoding support
FRIMSource = plays fine, but I will never want to use ABR in my encodes....
Old 26th April 2014, 13:59   #20112  |  Link
mparade
It seems that the problem solved:
DirectShowSource enabled for frame serving + set IVTC_TELECIDE=0 in the ini. file + "IVTC sources with 3:2 pulldown" checkbox selected, however the avs script (attached) says nothing about IVTC...
Old 26th April 2014, 14:04   #20113  |  Link
DirectShowSource
I looked at the AVS files you posted. The only odd thing I sees is the "no iVTC with deinterlacing" isn't doing any interlacing. I'll assume that was a mistake.
If you are getting jerky motion with these AVS files, only one of three things might be the reason. 1) The source isn't telecined; 2) The source is hybrid; 3) The players have issues.
Old 26th April 2014, 14:08   #20114  |  Link
It isn't exactly doing "inverse telecining" -- but it is using DirectshowSource to convert the framerate. That makes me think even more that the source either isn't telecined or it is hybrid.
Do you have "IVTC_480i=1" set in your INI file? If so that's the issue. That should only be set when you have a hard-telecined source. It can really screw with non-telecined sources.
Old 26th April 2014, 14:53   #20115  |  Link
mparade
No, I haven't set IVTC_480i, so it must be on it's default value which is 0. I am going to check the 480i source with previewing it in dgmpgdec...but as far as I remember it is
telecined and BD-RB automatically started the IVTC process on this source by selecting the IVTC checkbox in the setup dialogue.
Old 26th April 2014, 16:36   #20116  |  Link
Please post your INI file.
Old 26th April 2014, 19:16   #20117  |  Link
mparade
Please find it enclosed with the info file from DGindex.
Your help is really appreciated.
Old 26th April 2014, 23:30   #20118  |  Link
AmigaFuture
FRIMEncoder is at FPS: 31.xx to 33.xx.
[04/26/14] BD Rebuilder v0.47.05 (beta)
[02:46:55] Source:  CLOUD_ATLAS_00100
  - Target BD size: 23.14 GB
  - MOVIE-ONLY mode enabled
  - Quality: High-Speed Option (BD-25+), Two Pass
  - Decoding/Frame serving: FRIMSource
[02:46:58] PHASE ONE, Encoding
 - [02:46:58] Processing: VID_00057 (1 of 2)
 - [02:46:58] Extracting A/V streams [VID_00057]
 - [02:54:44] Reencoding video [VID_00057]
   - Rate/Length: 23.976fps, 233,455 frames
   - Bitrate: 16,352 Kbs
 - [02:54:44] Reencoding: VID_00057, Pass 1 of 2
 - [02:54:44] Reencoding: VID_00057, Pass 2 of 2
 - [04:52:37] Video Encode complete
 - [04:52:37] Processing audio tracks
 - [04:52:37] Processing: VID_00058 (2 of 2)
 - [04:52:37] Extracting A/V streams [VID_00058]
 - [04:53:07] Reencoding video [VID_00058]
   - Rate/Length: 23.976fps, 13,916 frames
   - Bitrate: 13,286 Kbs
 - [04:53:07] Reencoding: VID_00058, Pass 1 of 2
 - [04:53:07] Reencoding: VID_00058, Pass 2 of 2
 - [04:57:59] Video Encode complete
[04:57:59]PHASE ONE complete
[04:57:59]PHASE TWO - Rebuild Started
 - [04:57:59] Rebuilding BD file Structure
[05:10:49] - Encode and Rebuild complete
[05:10:49] JOB: CLOUD_ATLAS finished.
A Full Backup (2D) with same settings is showing same frame rates.
Next test (2D)...I've switched BD-RB to x264 Encoder. Nothing else changed. With the same parts x264 is getting ~46 FPS. This is for single pass only. More tests to do..
A side note to my previous post about "Cloud Atlas" with English PGS showing as 5+ hours long, I had BD-RB imported the MKV to create a BD. Then played the BD with PowerDVD 12 and my LG. Both showed the move as being 5+ hours. For your information. Again, only way it shows it the correct play time is without the English PGS. I'll try with French or Spanish without English, soon.
Old 27th April 2014, 03:17   #20119  |  Link
You have to set:
SD_PROGRESSIVE=1
If it is set to "0" (as in your INI). When you change it BD-RB is told to insert pulldown flags (via X264) in the output. TSMUXER can't handle 3:2 pulldown (even in MPEG-2), I think it's a PTS/timing issue, but I've never looked at it closely enough to say for sure. That's why the SD_PROGRESSIVE default is "1". The "0" setting is really only useful for output to MP4 or MKV.
I'm pretty much positive that's the source of your problem.
[Edit] Interestingly I just noticed that the HIDDENOPTS.TXT file incorrectly states that the default is "0". That is incorrect -- the default is "1" -- I've updated HIDDENOPTS for the next release.
Old 27th April 2014, 10:42   #20120  |  Link
mparade
You have to set:
SD_PROGRESSIVE=1
Only by using IVTC_TELECIDE=0 in the ini can solve the problem. With SD_PROGRESSIVE set to 1 the video is still being played jerky. Interestingly the filesize is around 71MB
when IVTC_TELECIDE=0, and with the other IVTC attempts when IVTC_TELECIDE=1 and each other settings were unchanged was around 40,5MB. So, much bigger filesize couples with fine playback while the smaller one with a jerky one.
