19th April 2010, 23:35 | #7801 | Link |
I have try this change and it works:
- Uninstall/Reinstall ffdshow 3326 - update x264.exe for rev 1542 at 2% now and not crashed. After conversion done, i will retry the old x264.exe. I will give you some news.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
20th April 2010, 00:01 | #7802 | Link |
I've have now been able to back up a number of blu-rays now. For that, thank you very much jdobbs, your work has been great. I am now only having one problem so far, my blu-rays re-encode, burn fine, from what i can tell. On my ps3 and my vizio blu-ray players the movies play and look great. Though its not a big problem but there is one blu-ray which i don't use that much anymore, bdp-s301 that will not play the bd-r25 backups. It says can't play disc, or no disc in tray. At first I ignored it because before the firmware update it said it was not bd-r compliant. The lastest firmware update did state it added this: "Compatibility with BD-R/RE discs burned by the Click to Disc™ and Click to Disc™ Editor software included with some VAIO® computers". I don't have this software but I have a hard time believing that only that software has the capabilities the record data that my blu-ray player can play. Since it's not a much used player it won't be big deal if get it working, just would be nice. Yes it does play original blu-rays
20th April 2010, 00:05 | #7803 | Link | |
The new X264 version has a bug related to sizing when it gets its input from an AVS... next time wait until I upgrade in the release -- that way you know it has been tested. This is a self inflicted injury. Last edited by jdobbs; 20th April 2010 at 00:08. |
20th April 2010, 00:11 | #7804 | Link | |
x264 developer
x264 will weave field-based sources. This is a good thing; previously, they would be interpreted wrong. Do you want the old broken behavior back where field-based sources get interpreted as alternating-field half-vertical-res progressive videos? |
20th April 2010, 00:14 | #7805 | Link | |
I'll PM you, but I have to do it in about an hour (gotta run). I have an example command line, source, and AVS file. You're not implying this is something you wanted to happen are you? I can understand weaving two fields -- but why would you weave what appears to be two frames? |
20th April 2010, 00:17 | #7806 | Link | |
x264 developer
If you set AssumeFieldBased on a frame-based input, you are doing it wrong. |
20th April 2010, 00:49 | #7807 | Link | ||
As per the AVISYNTH docs, I used "AssumeFieldBased()" because that's the only way you can tell AVISYNTH the field order of the source. It didn't cause an issue until now. From the AVISYNTH docs: Quote:
20th April 2010, 00:56 | #7808 | Link | |
x264 developer
a) you are not using AssumeFieldBased b) you are not using weird complex scripts that you don't control and it triggers, post a test case and we'll fix it. I'm pretty sure you're not supposed to do that unless you actually have separate fields. I imagine this could break a lot of filters internally as well.
Follow x264 development progress | akupenguin quotes | x264 git status ffmpeg and x264-related consulting/coding contracts | Doom10 Last edited by Dark Shikari; 20th April 2010 at 00:59. |
20th April 2010, 01:02 | #7809 | Link | |
20th April 2010, 04:10 | #7810 | Link | |
The original is a 40GB move that I shrunk to 25GB – a reduction of 39% according to BD-Rebuilder (after excluding all the unneeded audio and subtitles). I cut a 2 minute segment from the opening sequence when they are crossing the water in boats and getting all shot up. This is a good reference clip because it has facial close-ups, explosions, fast panning, CGI (airplanes strafing the boats), bold colors (explosions, blood) distance shots and text on paper. After stripping all but the video, I ended up with a 500MB file. I then forced encoding using a custom output size to retain the 39% reduction and encoded with 4 different settings (all 2 pass). Encode was set to 0,1,2,3 and 4. The resulting files are about 235MB each (I know the percentages don’t seem to add up, but BD-Rebuilder’s inf files confirmed the target reductions were the same: REDUCTION=.611948951309969 The resulting encode times and min/max bit rates are as follows (from BD-INFO): Length......Avg.Video.Rate.kbps.....Max.1-Sec.Rate.kbps.....Encode_Quality............total.time 01:59.8....32,948.............................47,978..............................Original.clip............N/A 01:59.8....15,008.............................22,730..............................0..........................0:08:26 01:59.8....14,936.............................28,042..............................1..........................0:15:47 01:59.8....14,933.............................28,057..............................2..........................0:17:36 01:59.8....14,950.............................27,692..............................3..........................0:23:47 01:59.8....14,930............................28,106...............................4.........................0:48:33 Encode Quality does spread the average/max bit rates a bit as I expected. My test PC is an Intel E6750 (core 2 duo @2.66GHz), 2GB RAM @667MHz, Windows 7 Ultimate (64 bit). Note that encode level 4 took 6 times as long as level 0. I watched each output clip on an LG BD370 player connected to an LG 50’ 720P plasma TV. (I also have a PS3 connected to a Panasonic AE3000 projector with a 120’ screen I’ll test later EDIT: I also tested with the PS3/AE3000 setup - can't tell between clips.). I had to check the file names to see which encode version I was watching as I could not tell the difference between all 5 clips. Freezing the screen during closeup shots and during explosions allowed me to see MINOR differences (more discernable facial hair, a little more detail in exploded pieces). So –if the extra time is of no consequence, you will get a SLIGHTLY better picture with higher encode values, but only if you scrutinize the image. I know some people will argue that the overall bitrates will suffer and picture quality is therefore inherently worse with lower quality values. The human eye isn’t that good of a detector, even if the numbers indicate a difference. I will gladly FTP the config and .m2ts files to anyone who wants to analyze further (I don’t have ability to capture good photos from the screen). Z PS - I will try compression to equal to DVD-5 and see what that output looks like next. Last edited by Zot; 20th April 2010 at 17:15. Reason: more info |
20th April 2010, 05:31 | #7811 | Link |
Hello jdobbs:
ive converted with version 33.04 *stock* reintall original version; and converted BAD_LIEUTENANT bluray version and all bonus features are too stretched and audio is out of sync. i have restored ffdshow 3326 and stock x264 version. movie is okay, not stretched or out of sync, only bonus features. I see that bonus features are 720 x 480 SDTV resolution. Here example with mediainfos original and converted files: 00009.m2ts (orignal) Code:
General ID : 0 Complete name : E:\BDR\BAD_LIEUTENANT\FULLDISC\BDMV\STREAM\00009.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 2.90 GiB Duration : 31mn 11s Overall bit rate : 13.3 Mbps Maximum Overall bit rate : 48.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Duration : 31mn 11s Bit rate : 12.5 Mbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Standard : NTSC Resolution : 8 bits Colorimetry : 4:2:0 Scan type : MBAFF Bits/(Pixel*Frame) : 1.211 Stream size : 2.73 GiB (94%) Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M Transfer characteristics : BT.601-6 525, BT.601-6 625, BT.1358 525, BT.1358 625, BT.1700 NTSC, SMPTE 170M Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 31mn 11s Bit rate mode : Constant Bit rate : 224 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Stream size : 50.0 MiB (2%) Code:
General ID : 1 Complete name : E:\BDR\BAD_LIEUTENANT\BD REBUILDED\REBUILDED 3304\FULLDISC\BDMV\STREAM\00009.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 842 MiB Duration : 31mn 11s Overall bit rate : 3 776 Kbps Maximum Overall bit rate : 35.5 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Duration : 31mn 9s Bit rate : 3 393 Kbps Width : 720 pixels Height : 960 pixels Display aspect ratio : 0.909 Frame rate : 29.970 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : MBAFF Bits/(Pixel*Frame) : 0.164 Stream size : 756 MiB (90%) Writing library : x264 core 93 r1538 bd72d46 Encoding settings : cabac=1 / ref=1 / deblock=0:0:0 / analyse=0:0 / me=dia / subme=0 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=tff / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=0 / b_bias=0 / direct=1 / wpredb=1 / wpredp=0 / keyint=24 / keyint_min=1 / scenecut=0 / intra_refresh=0 / rc_lookahead=24 / rc=crf / mbtree=0 / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / vbv_maxrate=35000 / vbv_bufsize=30000 / crf-max=0.0 / ip_ratio=1.10 / pb_ratio=1.10 / aq=0 / nal_hrd=vbr Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 31mn 11s Bit rate mode : Constant Bit rate : 224 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Stream size : 50.0 MiB (6%) Language : English / / Code:
----------------------- [23:00:49] BD Rebuilder v0.33.04 (beta) - Source: FULLDISC - Input BD size: 23,28 GB - Approximate total content: [03:12:07.048] - Target BD size: 22,66 GB - Windows Version: 6.1 [7600] - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [23:00:49] PHASE ONE, Encoding - [23:00:49] Extracting A/V streams [VID_00006] - [23:00:50] Reencoding: VID_00006 (1 of 7) - [23:00:50] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 214 frames - Bitrate: 14*585 Kbs - [23:00:50] Reencoding: VID_00006, Pass 1 of 1 - [23:01:00] Video Encode complete - [23:01:00] Reencoding audio tracks (if req'd) - [23:01:00] Multiplexing M2TS - [23:01:01] Extracting A/V streams [VID_00013] - [23:01:04] Reencoding: VID_00013 (2 of 7) - [23:01:04] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 3*837 frames - [23:01:04] Reencoding: VID_00013, Pass 1 of 1 - [23:01:24] Video Encode complete - [23:01:24] Reencoding audio tracks (if req'd) - [23:01:24] Multiplexing M2TS - [23:01:25] Extracting A/V streams [VID_00011] - [23:01:35] Reencoding: VID_00011 (3 of 7) - [23:01:35] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3*649 frames - [23:01:35] Reencoding: VID_00011, Pass 1 of 1 - [23:02:53] Video Encode complete - [23:02:53] Reencoding audio tracks (if req'd) - [23:02:53] Multiplexing M2TS - [23:02:55] Extracting A/V streams [VID_00008] - [23:03:40] Reencoding: VID_00008 (4 of 7) - [23:03:40] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 24*727 frames - [23:03:40] Reencoding: VID_00008, Pass 1 of 1 - [23:06:27] Video Encode complete - [23:06:27] Reencoding audio tracks (if req'd) - [23:06:27] Multiplexing M2TS - [23:06:32] Extracting A/V streams [VID_00012] - [23:07:18] Reencoding: VID_00012 (5 of 7) - [23:07:18] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 37*048 frames - [23:07:18] Reencoding: VID_00012, Pass 1 of 1 - [23:10:21] Video Encode complete - [23:10:21] Reencoding audio tracks (if req'd) - [23:10:21] Multiplexing M2TS - [23:10:26] Extracting A/V streams [VID_00009] - [23:11:54] Reencoding: VID_00009 (6 of 7) - [23:11:54] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 56*084 frames - [23:11:54] Reencoding: VID_00009, Pass 1 of 1 - [23:17:25] Video Encode complete - [23:17:25] Reencoding audio tracks (if req'd) - [23:17:25] Multiplexing M2TS - [23:17:36] Extracting A/V streams [VID_00000] - [23:26:04] Reencoding: VID_00000 (7 of 7) - [23:26:04] Collecting video information - [23:26:04] Keeping original video (no reencode) - [23:26:04] Reencoding audio tracks (if req'd) - [23:26:04] Multiplexing M2TS [23:35:12]PHASE ONE complete [23:35:12]PHASE TWO - Rebuild Started - [23:35:12] Rebuilding BD file Structure [23:35:17] - Encode and Rebuild complete - WORKFILES folder removed. [23:35:18]JOB: FULLDISC finished. Code:
[Status] LABEL=FULLDISC VERSION=v0.33.04 (beta) SOURCE_SIZE=24999965565 SOURCE_VIDEO_SIZE=24807383040 TARGET_SIZE=24326963200 REDUCTION=.972870884288164 RESIZE_1080=0 AUDIO_TO_KEEP=all SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 QUICK=1 ENCODE_STEP=0 COMPLETED=7 REBUILD_COMPLETE=1 [00006] AUDIO=1111 PGS= M2TS_TARGET=19761016 RATE=14585 NSIZE=19826688 FLINK=0 MLINK=0 USE_ORIGINAL=1 [00013] AUDIO=1 PGS= M2TS_TARGET=138392860 NSIZE=45778944 FLINK=0 MLINK=0 [00011] AUDIO=1 PGS= M2TS_TARGET=352841124 NSIZE=141613056 FLINK=0 MLINK=0 [00008] AUDIO=1 PGS= M2TS_TARGET=1453283431 NSIZE=270833664 FLINK=0 MLINK=0 [00012] AUDIO=1 PGS= M2TS_TARGET=1613045205 NSIZE=310444032 FLINK=0 MLINK=0 [00009] AUDIO=1 PGS= M2TS_TARGET=3028043910 NSIZE=883156992 FLINK=0 MLINK=0 [00000] AUDIO=1111 PGS=1 M2TS_TARGET=22462727299 USE_ORIGINAL=1 NSIZE=18000046080 FLINK=0 MLINK=0
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 20th April 2010 at 05:52. |
20th April 2010, 05:50 | #7812 | Link | |
It's with some research that we found and resolved issues. I will submit you with official release from this issue. Thank You.
20th April 2010, 10:29 | #7813 | Link | |
BD-5 & BD-9 burns: Book Type must be "Normal" not "DVD-ROM"
@tandi
Also, make sure your burner drive & DVD+R/+R DL disc's Book Type are set to "Normal" and not "DVD-ROM". Many standalone B-R players cannot read BD-5 (DVD+R) & BD-9 (DVD+R DL) discs with a Book Type of "DVD-ROM". In ImgBurn, to check & change Book Type, go to > Tools > Drive > Change Book Type. This fixed all my playback issues regardless of what brand DVD+R/+R DL I burned on (although I only recommend Verbatim and Taiyo Yuden media). Good luck! @jdobbs U Da Bes! Mahalo brah! |
20th April 2010, 19:31 | #7816 | Link | |
If you mention a title that won't play, then I'm sure one of us will confirm whether it's got java. Once again, if you play the original, and there is a point at the beginning when it has an icon or picture on the screen that either slowly changes colour, gets filled in, or does something for typically 10 to 20 seconds, then that is the java loading. Last edited by drmih; 20th April 2010 at 19:38. |
20th April 2010, 21:31 | #7818 | Link | |
I recommend you take a favorite movie, use TSMUXER to cut a short clip (1-2 minutes) and try different encoding qualities to see what works best in your particular viewing environment. Z Last edited by Zot; 20th April 2010 at 21:47. Reason: typo |
20th April 2010, 23:00 | #7820 | Link | |
BTW - I noticed that even taking a 25GB Blu Ray movie down to AVCHD-5 STILL looks better than the same movie as a DVD on dual layer :-). You've made a great product - many thanks! Z |
