Old 19th July 2010, 00:36   #8841  |  Link
BD Rebuilder v0.34.05 (beta)
I've updated the first post of this thread with a link to the most recent update of BD-RB (v0.34.05). Changes for this release:
- Added code to generate chapter files to be used with
  X264's "--qpfile" command.  This will assert I frames
  at appropriate points during encoding, should provide
  better continuity with the new open GOP structures,
  and may prevent possible slight delays at chapter
  points during chapter seeking.
- Added an option to the SETUP dialog to enable or
  disable movie-only playback looping.  Unclicking the
  option will result in movie-only discs stopping at the
  end rather than restarting (looping).
- Corrected an error in which conversion to 720p for
  25fps sources was incorrectly setting the value used
  in AssumeFPS().  This could result in "slow motion"
  video and out-of-sync audio when converting to 720p on
  PAL area discs (25fps).
- Added a new hidden option called "KEEP_HD_LPCM".  If
  set to "0" while also keeping HD audio for BD25, only
  DTS and DD HD audio will be kept intact.  LPCM will be
  converted to AC3.  This is meant to help prevent huge
  LPCM audio streams from stealing too much space and
  negatively affecting video quality.  The default value
  is "1".
- Updated the included version of X264.EXE to the
  latest release (r1677).
Old 19th July 2010, 00:40   #8842  |  Link
@Capsbackup
Give me a couple of days and I'll get a test version to you. I'm writing a module to handle this and also DTS Express PiP audio.
I'm going to need more time. I was hoping to finish it today, but have a long way to go. I have company visiting this week, so it may be a while.
Old 19th July 2010, 00:56   #8843  |  Link
Sharc
That's definitely a bug. The "AssumeFPS()" is incorrect. As for the 50fps... I think what I'll do is use the new pulldown feature in X264 to double the framerate. That way you'll just encode the original, but the playback will double the rate. I'll have to test that to see how it works, though.
I just noted that you fixed the AssumeFPS() issue with the new version 0.34.05. Thanks.
I made some tests with --pulldown double in the meantime. It seems to work, however I had to replace in the tsmuxer *.meta the original fps=25 by fps=50 for the video, For the sups I had to keep the original fps=25.
Not sure if the resulting stream is really blu-ray compliant, it however plays on the SONY S357 (=360).
Old 19th July 2010, 01:21   #8844  |  Link
I'll experiment with it. Hmmm... I didn't think about the sups -- I'd better check that.
Old 19th July 2010, 01:25   #8845  |  Link
skylab1
I am getting error on VC-1 encode video, for some reason it stop working. I already reinstall ffshow, avisynth and Matroska Splitter, VC-1 in ffshow is set to wmv9 like before bdrebuilder still won't encode VC-1 video. Does anyone know how to mix this? I am running Windows 7 64bit.
Note: I never had this problem until about few weeks ago.
[14:53:53] BD Rebuilder v0.34.04 (beta)
- Source: THE.NEVERENDING.STORY.BLURAY.1080P.VC-1.DTS-HD.MA5.1-BLUWAVE
- Input BD size: 17.97 GB
- Approximate total content: [01:34:04.597]
- Target BD size: 7.84 GB
- Windows Version: 6.1 [7600]
- MOVIE-ONLY mode enabled
- Auto Quality: Good (Very Fast), Two Pass
- Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
[14:53:53] PHASE ONE, Encoding
- [14:53:53] Extracting A/V streams [VID_00020]
- [15:37:46] Reencoding: VID_00020 (1 of 1)
- [15:37:46] Collecting video information
- Rate/Length: 23.976fps, 135,335 frames
- Bitrate: 10,579 Kbs
- [15:37:47] Reencoding: VID_00020, Pass 1 of 2
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.34.04 (beta)
- HAALI Splitter: Ok
- FFDSHOW: 3124, not recommended version
- WIN7 preferred VC-1 CODEC: Not Set correctly
- WIN7 preferred MPEG2 CODEC: Not Set correctly
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[15:41:21] - Failed video encode, aborted
skylab1 is offline   Reply With Quote
Old 19th July 2010, 01:30   #8846  |  Link
You have to set up according to the first post of this thread. I'm sorry, but I can't respond to self-inflicted injuries.
Old 19th July 2010, 02:11   #8847  |  Link
skylab1
I did followed the instruction, reinstall everything, still the same error:
[17:49:35] PHASE ONE, Encoding
- [17:49:35] Reencoding: VID_00020 (1 of 1)
- [17:49:35] Collecting video information
- [17:49:35] Reencoding: VID_00020, Pass 1 of 2
- AVISYNTH Version: 2.5.7.0, Ok
- FFDSHOW: 3326, Ok
- FFDSHOW MPEG2 set to "libmpeg2": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
What I can't figure out is why VC-1 and Mpeg2 codec isn't set correctly for win 7 when it was working up until now?
Old 19th July 2010, 02:28   #8848  |  Link
The first time you run BD-RB, right click and select "Run as Administrator" and it will set the preferred CODECs automatically. Some other software you've installed probably decided to change them.
Old 19th July 2010, 02:59   #8849  |  Link
Capsbackup
@Capsbackup
No problem, I learned the art of patience long ago!
It is enough to know you are working on it, I appreciate that.
Enjoy your company!
Old 19th July 2010, 03:06   #8850  |  Link
skylab1
Ok thanks, I'll reinstall BD-RB and runs as admin see if this would correct the problem.
Old 19th July 2010, 03:24   #8851  |  Link
Enjoy your company!
Groovy.
Old 19th July 2010, 07:54   #8852  |  Link
Sharc
Something odd here:
The --pulldown double encode plays smoothly with MPC-HC. It is however jerky with VLC and with the S357 / S360. It looks like if the 'wrong' picture would get pulled down, similar effect as wrong field order for interlaced material....
Any idea?
Old 19th July 2010, 18:22   #8853  |  Link
colinhunt
  is "1".
Praise you, Sir! This warrants another donation, methinks!
Old 19th July 2010, 21:00   #8854  |  Link
colinhunt
I have a question about how BD-RB calculates which files it re-encodes and which ones it leaves as-is. I have a disc like this:
SOURCE_SIZE=25345053872
SOURCE_VIDEO_SIZE=25134163968
I did a full back-up, but removed French and Spanish DD5.1 audiotracks from the main feature, thus reducing the total amount of data by 890MB and making it fit on a BD25. I also set output size to Custom/24100MB which has worked perfectly so far. INF says
TARGET_SIZE=25270681600
REDUCTION=.997040988827212
By my reckoning, BD-RB shouldn't have re-encoded anything at all once those two audiotracks were removed. BD-RB left the main feature alone but re-encoded most of the extras and the output came to 22.1GB -- i.e. way under the 24100MB I had set the output for.
What might explain this behaviour?
Old 19th July 2010, 22:26   #8855  |  Link
Here's what BD-RB does for each stream:
1. Extract the audio, subs, and video.
2. Estimate the size of the end-product audio/subs based on:
2a. Actual size if keeping as-is
2b. To-be size (using bitrate if reencoding)
2c. Predicted size after muxing based on type (DTS, DD, LPCM) -- this step limits accuracy as different bitrates, types, etc can result in varying overhead.
3. Calculate the space left for video, amount needed for muxing, and determine bitrate needed to fill that space (using target size).
4. If the extracted video will fit in the remaining space, no encoding is done. If it doesn't... it has to encode.
There is always a small amount of "cushioning" added to avoid oversizing and leave some level of disc-edge unused (because of the higher risk of error on the outer edges).
By the way -- the .997040988827212 tells you that something has to be reencoded or else you will be over your target size. In your case (as it should) BD-RB chose the extras. That's probably because there is a fixed overall level of reduction, and the removed audio is almost always in the feature but not the extras.
Old 19th July 2010, 22:48   #8856  |  Link
colinhunt
But isn't "SOURCE_SIZE=25345053872" the source data with all streams intact? I believe it is since it's also the size of the Blu-ray as reported by Windows. Remove 890MB from that and the total is easily below the 24100MB (25270681600) target... i.e no re-encoding required. Right?
Old 19th July 2010, 23:54   #8857  |  Link
LowDead
Elit Amans
@colinhunt
I have also got that result before on some discs... Try ticking "Quicker encode for extras" and see what happens. I have managed to "trick" BD-RB to actually leave everything untouched before. I am also interested to know how this can be
/LD
Old 20th July 2010, 01:39   #8858  |  Link
It doesn't work that way. The 890MB is subtracted only from the stream in which it resides -- and that stream was kept intact (correctly). The way around this type of processing is to do a lot of full scans before you start -- and that would be unacceptably slow.
I guess it's possible that after completing a "keep intact" I can look for left over space and recompute for those remaining to be encoded. I'll look into it.
Old 20th July 2010, 03:23   #8859  |  Link
stonej01
Anybody know the correct version of matroska splitter to use with the new version. I ran INSPECT and it keeps telling me the version i'm using is not recommended. I used the direct link from page 1 and i have been using the same version since build 33.07. I made sure to search before asking but i got nothing.
stonej01 is offline   Reply With Quote
Old 20th July 2010, 04:28   #8860  |  Link
The one in the link is correct. What you're seeing usually means another version wasn't completely uninstalled and there are files left behind. Since HAALI doesn't include version information in the headers, the only way to check the version is to do a checksum of the folder.
Uninstall, remove the directory (under "Program Files\Haali" or "Program Files (x86)\Haali" for 64 bit Windows) and then install again and you should pass the INSPECT test.
