24th September 2011, 19:24 | #13104 | Link |
Yes, unchecking things, is something I think I can handle Jd.
But more importantly, I would appreciate your responses here The problem I'm having completing the command line, wouldn't that also occur if I tried to compress LCPM mono, since from what I can gather from the code you gave me Aften would be required for that as well. And the system you set up XP on, might that be a factor if yours was a multi core with large RAM allocations? Last edited by sonate; 24th September 2011 at 19:27. |
24th September 2011, 20:42 | #13105 | Link | |
24th September 2011, 20:48 | #13106 | Link | |
[Edit] The answer is no. Only an estimate is made. The subtitles are still in BD format at the time the encode takes place so their final output size is unknown. In fact, the subs are never a "distinct" entity from which size can be determined at any time, as they are integrated directly from PNG files. Last edited by jdobbs; 24th September 2011 at 20:58. |
24th September 2011, 22:03 | #13108 | Link | |
C:\Documents and Settings\Administrator>c:\accessories\BD_Rebuilder\tools\wavi.e xe "D:\BD REB WORK FOLDER\WORKFILES\AUD_00001_4352.AVS" Yields this Error: Could not find PCM audio track in "D:\BD REB WORK FOLDER\WORKFILES\AUD_00001_4352.AVS". _________________ "AUD_00001_4352.AVS" exists #Created by BD Rebuilder - v0.39.01 (beta) LoadPlugin("C:\accessories\BD_Reb\tools\nicaudio.dll") audio=NicDTSSource("00001.track_4352.dts").Amplify(1.2) ConvertAudioTo16bit(ResampleAudio(audio, 48000)) And "00001.track_4352.dts" exists as well 1.4 gb and is playable. Does this indicate another problem aside from the stdin/out issue? Also ".......aften.exe -v 1 -b 640 -readtoeof 1 -" can you explain this part of the command? Last edited by sonate; 24th September 2011 at 22:29. |
24th September 2011, 22:37 | #13109 | Link | |
"D:\BD REB WORK FOLDER\WORKFILES\TESTER.WAV". |
25th September 2011, 01:05 | #13112 | Link | ||
Aging Video Hobbyist
EDIT: In looking at the .MPLS for the feature, it does appear that the non-Eng audio/subs are properly identified as fra, jpn, spa, etc in there. So maybe this is a quirk of my software program Arcsoft TMT 3; yes, it is. It is not a problem with TMT 5. Sorry jdobbs for wasting your time with this. I'll leave my erroneous comment here for posterity i.e. other TMT3 users may encounter it: Quote:
25th September 2011, 01:41 | #13113 | Link | |
25th September 2011, 18:46 | #13115 | Link | |
If, however, the source is telecined and you have IVTC set -- it will be inverse telecined and become 23.976 progressive. Last edited by jdobbs; 25th September 2011 at 18:51. |
25th September 2011, 19:53 | #13116 | Link | |
Thank you very much. I'll check this out again ;>} |
25th September 2011, 20:14 | #13117 | Link |
Attempting to do a full backup of BOURNE_IDENT, with Edit selected to enable blanking. I would like to test blanking the three warnings and the short 14 second long Deluxe Digital Studios advertisement. The files I want to blank are 00001.m2ts, the 14 second advert, 00003.m2ts, 00004.m2ts and 00005.m2ts, which are the warnings. Only 00001.m2ts is listed in the list available to blank.
( Tree list starts with 00000.m2ts, then 00001.m2ts, then jumps to 00010.m2ts, which is the movie. Then it jumps to VID_00050 and up. ) What am I missing? This is my settings: PHP Code:
25th September 2011, 22:01 | #13119 | Link |
Long time BD Rebuilder user...
Upgraded to latest version, nothing but trouble.. VC-1 errors, X264.exe errors....versions, etc... may be looking for other options.... Downloaded all versions on homepage for recommended versions etc, have fooled with this now for 2 days..... Was working perfectly till i upgraded to latest.... ridiculous.... |
